5th April 2004, 17:17 | #42 | Link |
First chapter audio problem
1. DVD-RB v0.30 and 0.29
2. ReJig 0.5e 3. Using eclCCE? N 4. Audio becomes out of sync near the end of the 1st chapter. At the start of the 2nd chapter it is corrected. I have done three movie and get the same thing. I'm not sure if it was there in 0.28 or not. |
5th April 2004, 17:19 | #43 | Link | |
Re: First chapter audio problem
5th April 2004, 18:13 | #44 | Link |
Outstanding work, jdobbs, thanks for all the hard work you are putting into this great tool.
1. DVD-R Version: 0.30 2. Encoder being used: CCE 2.50 3. Using eclCCE? Y 4. Bug encountered: Chapter stutter--depends on which player I play the burned project in. It plays flawlessly on the DVD drive in my computer, but stutters at chapter breaks in my cheapo Norcent DVD player (though the Norcent has no trouble with other 1:1 or DVDShrink titles.) Also, of course, the original DVD does not stutter at chapters in the Norcent. Exact same thing happens in v0.29: plays fine on my computer, stutters at chapter breaks in my Norcent. All my testing has been with the same DVD title (The Last Starfighter.) I had problems not encoding but playing back stills as well, but since they were all in one separate VTS, I just copied the VOB/IFO over instead of using the ones Rebuilder made and they work fine. Last edited by HanSolo00; 5th April 2004 at 18:42. |
5th April 2004, 18:18 | #45 | Link | |
Retired
Title Set (Movie) attributes: Video: MPEG-2 720x576 (PAL) (PAL 625/50) (4:3) (not specified perm.display) Audio 1: Deutsch (Dolby AC-3) 2ch 48Kbps DRC (ID: 0x80) PGC_1 (program chain): [Title(TTN): 1] [00:01:55.09 / 25 fps] (Programs: 2) (Cells: 3) (uses VOB-IDs: 1,2,3) [Ch 01] [Pg 01] [Cell 01] [V/C Id: 1/ 1] : time: 00:01:54.14 / 25 fps [Pos: 00:01:54.14] [Frames: 2864] [Cell 02] [V/C Id: 2/ 1] Layer Br.: time: 00:00:00.10 / 25 fps [Pos: 00:01:54.24] [Frames: 2874] [Ch 02] [Pg 02] [Cell 03] [V/C Id: 3/ 1] Layer Br.: time: 00:00:00.10 / 25 fps [Pos: 00:01:55.09] [Frames: 2884] PGC_2 (program chain): [Title(TTN): 2] [00:01:59.16 / 25 fps] (Programs: 2) (Cells: 3) (uses VOB-IDs: 4,5,6) [Ch 01] [Pg 01] [Cell 01] [V/C Id: 4/ 1] : time: 00:01:58.21 / 25 fps [Pos: 00:01:58.21] [Frames: 2971] [Cell 02] [V/C Id: 5/ 1] Layer Br.: time: 00:00:00.10 / 25 fps [Pos: 00:01:59.06] [Frames: 2981] [Ch 02] [Pg 02] [Cell 03] [V/C Id: 6/ 1] Layer Br.: time: 00:00:00.10 / 25 fps [Pos: 00:01:59.16] [Frames: 2991] PGC_3 (program chain): [Title(TTN): 3] [00:02:07.11 / 25 fps] (Programs: 5) (Cells: 5) (uses VOB-IDs: 7) [Ch 01] [Pg 01] [Cell 01] [V/C Id: 7/ 1] : time: 00:00:15.02 / 25 fps [Pos: 00:00:15.02] [Frames: 377] [Ch 02] [Pg 02] [Cell 02] [V/C Id: 7/ 2] : time: 00:00:05.18 / 25 fps [Pos: 00:00:20.20] [Frames: 520] [Ch 03] [Pg 03] [Cell 03] [V/C Id: 7/ 3] : time: 00:01:15.10 / 25 fps [Pos: 00:01:36.05] [Frames: 2405] [Ch 04] [Pg 04] [Cell 04] [V/C Id: 7/ 4] : time: 00:00:30.21 / 25 fps [Pos: 00:02:07.01] [Frames: 3176] [Ch 05] [Pg 05] [Cell 05] [V/C Id: 7/ 5] : time: 00:00:00.10 / 25 fps [Pos: 00:02:07.11] [Frames: 3186] Code:
#------------------ # AVS File Created by DVD Rebuilder # VOBID:05, CELLID:01 #------------------ mpeg2source("E:\DVD2DVD-R\PROJECTS\MAN ON THE MOON\REBUILDER\D2VAVS\V02A.D2V") trim(5837,5837) ConvertToYUY2() #------------------ # AVS File Created by DVD Rebuilder # VOBID:06, CELLID:01 #------------------ mpeg2source("E:\DVD2DVD-R\PROJECTS\MAN ON THE MOON\REBUILDER\D2VAVS\V02A.D2V") trim(5838,5837) ConvertToYUY2() Code:
7 0 12866 2 2 2 2 2 2 2 2 2 2 2 2 2 7 0 128DF 2 2 2 2 2 2 2 2 2 2 2 2 2 7 0 1294F 2 2 2 2 2 2 2 7 0 12999 2 |
5th April 2004, 18:35 | #46 | Link |
Run time 5 with QuEnc during rebuild
DVD-RB: Ver .30
Quenc .45 error : run time 5 during rebuild Options: one click Convert to YuY2() dyn bit rates Audio Dub no warnings appears to be a still frame near the end of the disk vob:3 cell:1 trim 229329,229329 Convrt to Yu() This same source runs through with ReJig ok. Really looks good. This is a very exciting program. |
5th April 2004, 18:59 | #49 | Link |
Retired
I'll answer for jdobbs
The Trim() statement is used in all DVD-RB AVS files. Without that line, the AVS would refer to the entire VTS. But DVD-RB reencodes at the cell level, so Trim() is used to cut a cell out of the large video stream. In my case however, the Trim() statement seems to be set up incorrectly. |
5th April 2004, 19:44 | #51 | Link | |
5th April 2004, 20:04 | #52 | Link |
The stutter is a single pause of about 0.2 seconds or so at each chapter break, so I'm guessing it is several frames but not sure. It definately is noticable when viewing the movie, I don't have to look for it. And it ONLY seems to happen on my Norcent DVD player; it plays fine on my computer's DVD drive. It can't be the media, because other 1:1 backups work fine.
Incidentally, I haven't noticed any of the audio sync problems others are having in the long chapters that I've checked so far. Other than the chapter pauses, everything is perfect. Last edited by HanSolo00; 5th April 2004 at 20:08. |
5th April 2004, 20:17 | #53 | Link |
Posts: n/a
jdobbs prolly has ideas for that pause thing but heres something to look at:
-The player jumping/freezing for the audio to come back and thus pausing the video till it does. (the audio gap problem reversed sort of) -Too high bitrate causes pause -Too low bitrate causes pause btw what is the lowest bitrate allowed for a DVD? |
5th April 2004, 20:18 | #54 | Link | |
It only did it on my cheap player but my decent player and computer played it fine. My Sony has played discs from every version of DVD-RB perfectly. I am doing it again with 031 now. |
5th April 2004, 20:28 | #55 | Link |
It pauses for a fraction of a second in my cheap DVD player on every single chapter of the title I converted with DVDRB 0.30. Other compressed titles done by release groups which I've tried on the same media in the same player have no such pauses... so it must be some minor little thing at chapter points that is causing some players hickups. Frustrating to debug though because it only seems to show up after you burn and test it in the player.
One other minor bug, which may have already been fixed by now, is in the settings dialog for CCE 2.50. I selected 6 pass VBR (and it's still there now as a default), but when I looked in the Rebuilder.ecl it has VBR_Pass=5 on every cell. No biggy, 5-pass is fine anyway, but just thought I'd point that out. |
5th April 2004, 20:39 | #57 | Link | |
No chapter stutter AND.... IT PLAYS PERFECTLY OK ON MY PHILIPS ALSO!!!!!!! (This was a bug that only yours truly had reported a long time ago, was present in every otherwise perfect backup, and prevented me from actually keeping a backup. From past experience, I am almost 99,999% sure that since it plays on the Philips, it can play anywhere. Or at least, the structure is solid! So you got rid of two bugs with one shot!!!! Bravo!! (Just to be absolutely sure, I'll re-do the Stargate DVD with 0.31, to confirm) Last edited by loosenut; 5th April 2004 at 20:42. |
5th April 2004, 21:33 | #59 | Link |
Hello jdobbs....
Thanks for sharing your program with us..... Just for feedback Version = 0.31 Encoder = CCE 2.67.00.08 (but it nevers gets there) Eclee = No Roxette The Complete Collection. DVD contains 4 VTS folders.... VTS02 contains 36 PGC... When doing the preparing its stopped (in VTS02) at aprox. 75% saying Runtime error 9 Subscript out of range. Maybe this tiny little feedback will help you to get get your program to get even better..... Crawl |
5th April 2004, 22:11 | #60 | Link | |
