16th April 2014, 04:04 | #42 | Link |
Then you have some kind of Avisynth problem, re-install.
Copy only required plugins to plugins dir, and establish that avisynth is working, no point in trying to get the rest working without working avisynth. You only put 1 of each of the plugs in plugins dir, ie only v.26 version not v2.5. Before install try this Code:
Version() EDIT: Only thing I can think of is that you actually have Avisynth v2.58 installed.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 16th April 2014 at 04:30. |
16th April 2014, 04:52 | #43 | Link |
Hi StainlessS
I tried the version () code (creating a avs with that code and open it in virtualdub), here is the result
AviSynth 2.60, build:Sep 18 2013 [17:36:36] C 2000-2013 Ben Rudiak-Gould, et al. http://www.avisynth.org What I have noticed is that even when I installing Avisynth 2.6 it gets installed inside a folder name Avisynth 2.5, I guess it does not matter The files inside my current avisynth installation directory (C:\Program Files (x86)\AviSynth 2.5\plugins) are: by default: colors_rgb.avsi DirectShowSource.dll TCPDeliver.dll Installed by me FrameSelect26.dll Gscript.dll RT_Stats26.dll I desinstall and reinstall Avisynth 2.6 I get the defult plugins: colors_rgb.avsi DirectShowSource.dll TCPDeliver.dll and I added only the FrameSelect26.dll (84kb) Then I lunched the avs file but get the same error message Avisynth open failure: Script error: there is no function named "FrameSel" (C:\Users\Eduardo\Desktop\FOR AVISYNTH\painting test for avisynth Lagarith_SelectFrames.AVS, line4) I dont know what is wrong with my system, should I try to install AviSynthPlus-r1576.exe?? or AviSynth 2.5.8???? http://avisynth.nl/index.php/Main_Page Thanks Advaced StainlessS Last edited by eduardobedoya; 16th April 2014 at 05:15. |
16th April 2014, 11:17 | #44 | Link |
Oops, sorry.
Seems I may have supplied you with FrameSelect plugin rather than FrameSel plugin. FrameSelect is older version, needed to change args in non compatible way, and so I renamed the plugin to avoid compatibility problems. Delete the older FrameSelect, you need FrameSel plugin, v2.6. See MediaFire below in sig.
16th April 2014, 20:15 | #45 | Link |
Man I dont know if I should laugh or cry
Thanks StainlessS
I was already thinking about installing a virtual machine Thanks man, it worked, I did a TEST>>> First Here is the UNDO Batch Log: Code:
Fsel_Eduardobedoya_Batch.Log CONVYV12=False ldM=1 hdM=1 ldL=0.005000 hdL=0.005000 ldS=0.005000 hdS=0.005000 ldR=0.005000 hdR=0.005000 MAX_LDIFF=0.004000 1/1 ] Processing C:\Users\Eduardo\Desktop\FOR AVISYNTH\painting test for avisynth UTVideoULRG.avi QWIK Scan DBase creation = 49.06 Secs (0.82 Mins) 184,195 Skipping earlier duplicate sequence and UNDOS 368,536 Skipping earlier duplicate sequence and UNDOS 612,706 Skipping earlier duplicate sequence and UNDOS 847,886 Skipping earlier duplicate sequence and UNDOS 910,961 Skipping earlier duplicate sequence and UNDOS 1284,1345 Skipping earlier duplicate sequence and UNDOS 1378,1438 Skipping earlier duplicate sequence and UNDOS 1506,1535 Skipping earlier duplicate sequence and UNDOS 1544,1546 Skipping earlier duplicate sequence and UNDOS 1702,1713 Skipping earlier duplicate sequence and UNDOS 1716,1797 Skipping earlier duplicate sequence and UNDOS 1983,2049 Skipping earlier duplicate sequence and UNDOS 2085,2126 Skipping earlier duplicate sequence and UNDOS 2183,2285 Skipping earlier duplicate sequence and UNDOS MDeltaMax=0 LDeltaMax=0.002777 SDeltaMax=0.001762 RDeltaMax=0.001480 (Above, maximum values of ldM, hdM, ldL, hdL, ldS, hdS, ldR, hdR, that would have worked, but may have been faster) Kept 1474 of 2304 frames [1920x1080 153.60 secs (2.56 Mins) @ 15.00 FPS] QWIK SCAN 127.67 Secs (2.13 Mins) InFPS=18.05 OutFPS=11.55 C:\Users\Eduardo\Desktop\FOR AVISYNTH\painting test for avisynth UTVideoULRG.avi Tot File Time = 177.32 Seconds (2.96 Mins) DONE TOTAL Time = 177.33 Seconds (2.96 Mins) Here is the resulted AVS file: Code:
Avisource("C:\Users\Eduardo\Desktop\FOR AVISYNTH\painting test for avisynth UTVideoULRG.avi") CmdFrames="C:\Users\Eduardo\Desktop\FOR AVISYNTH\painting test for avisynth UTVideoULRG_Frames.txt" (Exist(CmdFrames)) ? FrameSel(cmd=CmdFrames,reject=False) : NOP Return Last Then here is the message that appeared in the command promp when launching VdBatch.bat Code:
F:\2 AVISYNTH>REM Where to get input file, No terminating Backslash, "." = current directory F:\2 AVISYNTH>set INDIR=".\INPUT" F:\2 AVISYNTH>REM Where to get input files, No terminating Backslash. F:\2 AVISYNTH>set INDIR=".\OUTPUT" F:\2 AVISYNTH>REM Execute Vdub using script, clear command queue, batch mode, source dir, dest dir, process queue, exit F:\2 AVISYNTH>"C:\Program FIles <x86>\VirtualDub-1.10.4""/VDub.exe" \s "C:Program Files <x86>\VirtualDub-1.10.4""\VD.vcf" /c /b ".\INPUT" ".\OUTPUT" /r /x VirtualDub CLI Video Processor Version 1.10.4 <build 35491/release> for 80x86 Copyright <C> Avery Lee 1998-2009. Licensed under GNU General Public License AVI: Opening file "F:\2 AVISYNTH\INPUT\painting test for avisynth UTVideoULRG_SelectFrames.AVS" AVI: Avisynth detected. Extended error handling enabled Beginning dub operation Dub: Input <decompression> format is : XRGB8888. Dub: Output <compression> format is: RGB888. Last edited by eduardobedoya; 16th April 2014 at 21:20. |
16th April 2014, 21:29 | #46 | Link |
About the color output
Thanks a lot StainlessS, it worked!
I used UTVideoULRG because it keep the color very similar to the original in RGB Also I changed this line, of the Undo BATCH.AVS that you provided: Code:
#### CONVYV12 = False # True ConvertTo YV12 in created script, Else False leaves as is #### But when I run the VdBatch.bat the color of the OUTPUT video drastically changed I guessed it depends on the video>compression properties that you choose on Virtualdub (VD.vcf) So I changed Virtualdub compression properties to tscc codec, and then it rendered the video in a good RGB color, Thanks a lot StainlessS, I just have some doubts: Is there a big difference between converting the original tsc2 video to UTVideoULRG or UTVideoULY0 codecs for running the UNDOBatch.avs?? I mean, cuz, the sample tsc2 26mb video converted into UTVideoULRG is 5.2gb and into UTVideoULY0 is 2.7gb, So is there any problem if I convert the original tsc2 into UTVideoULY0 video file in order to run the UNDObatch in YUV and then re-convert it with the VDBatch.bat into RGB again? Do I loss some color information in the final OUTPUT RGB video by doing this way??? Will the batch process be run in YUV colors so it could loss some accuracy in color detection (similar color painting strokes)?? I run the test and it really cut all the UNDOS, but, is there any way to merge all equal frames to a single frame? I mean, cuz, the result video got in fact all the painting strokes without UNDOS, but there is so much space(time)(equal frames) between each different stroke, is there a way to merge all that spaces, so the time between each different painting stroke could be just one frame? For example: the original video was AbcdAbcAbcdeABCDefDefgDefDefgDEFGHijHijkHIJKLMnopMnopMNOPQ the applying your avs it turns into AABCDDDDEFGHHIKJLMMMNOPQ is there a way to turn it into (perhpas using the same batch.avs) ABCDEFGHIJKLMNOPQ Thanks a lot StainlessS!!! Last edited by eduardobedoya; 16th April 2014 at 23:25. |
17th April 2014, 13:56 | #47 | Link | ||
'decompression format' and 'output format to compressor/display' is required, I would be reluctant to go back to TSCC codec, we already established it to be unreliable for eg seeking, suggest find alternative. I dont usually touch HD, I dont have BD player or other source of it, perhaps others could advise on best settings for VD 'decompression format' and 'output format to compressor/display', to pass through RGB untouched to UT_Video ULRG. I dont really see why pulling in RGB and compressing to UT_Video RGB should give a problem. What are you using to judge the 'drastically changed output', did you look at the input to UNDO script too ? UTVideo ULY0 is rec601 YV12, ie half resolution chroma, that is why is is smaller compressed file, half chroma detail gone. Quote:
OK, I'll put it back like that. EDIT: From your last post Code:
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 17th April 2014 at 14:08. |
17th April 2014, 19:39 | #48 | Link | |
Hi StainlessS
compared to ULY0???? |
17th April 2014, 20:12 | #49 | Link |
Yep..
19th April 2014, 01:05 | #50 | Link |
OK, I've added framecount limiting for static sequences, with KEEPMAX==1 (default) will produce output clip with
148 frames (on your sample, I think) with no pauses between edits. setting to eg 15 will give max 1 second pause between edits when 15FPS clip. Added a ranges.txt file, created during resultant avs load, informational only. Removed ConvertToYV12 functionality. Reduced number of tolerance settings (+ve and -ve tolerances set same). here: LINK REMOVED script here: Code:
# ############################ # Fsel_Eduardobedoya_Batch.avs, by StainlessS # Remove Undos from painting captures # ############################ # Alter below to Config ######################################################################## ######################################################################## ######################################################################## ScanAheadSecs = 10 * 60 # Search ahead range in seconds #### BELOW SETTINGS WORK FINE WITH SUPPLIED SAMPLE WITH A LITTLE LEEWAY. # Below settings, as close to zero as possible (faster but might miss matches), used by QWIK scan routines to identify possible match frames. dM = 1 # INT, Max diff (+ve and -ve tolerance) of YMedian between i frame and possible duplicate (may vary with clip, 0.0 for EXACT match) # dL = 0.005 # Float, Max diff (+ve and -ve tolerance) of AverageLuma between i frame and possible duplicate (may vary with clip, 0.0 for EXACT match) # dS = 0.005 # Float, Max diff (+ve and -ve tolerance) of YPlaneStdev between i frame and possible duplicate (may vary with clip, 0.0 for EXACT match) # dR = 0.005 # Float, Max diff (+ve and -ve tolerance) of YInRange between i frame and possible duplicate (may vary with clip, 0.0 for EXACT match) #### #### # Below used to identify if candidate frames found by QWIK SCAN routines are good match. MAX_LDIFF = 0.004 # Float, LumaDifference between candidate frame and duplicate (average pixel diff rather than frame diff, 0.0 Exact match) #### # Maximum number of frames to keep per static sequence (0 = no limit) KEEPMAX=1 #### ######################################################################## ######################################################################## ######################################################################## FSEL_TITLE="Select AVI files" FSEL_DIR="." FSEL_FILT="Avi files|*.avi" FSEL_MULTI=True AVIFILE_LIST = RT_FSelOpen(title=FSEL_TITLE,dir=FSEL_DIR,filt=FSEL_FILT,multi=FSEL_MULTI) Assert(AVIFILE_LIST.IsString,"RT_FSelOpen: Error="+String(AVIFILE_LIST)) NFILES=RT_TxtQueryLines(AVIFILE_LIST) # Query Number of lines in String ie number of files. myName="Fsel_Eduardobedoya_Batch: " LOG="Fsel_Eduardobedoya_Batch.Log" RT_WriteFileF(LOG,"%s\n",LOG,Append=False) S=RT_String("dM=%d dL=%f dS=%f dR=%f MAX_LDIFF=%f",dM,dL,dS,dR,MAX_LDiff) RT_WriteFileF(LOG,"%s",S,Append=True) S=RT_String("KeepMax=%d",KeepMax) RT_DebugF("%s",S,name=myName) RT_WriteFileF(LOG,"%s\n",S,Append=True) GSCript(""" TOTSTART = RT_Timer For(i=0,NFILES-1) { START = RT_Timer FN=RT_TxtGetLine(AVIFILE_LIST,i) # Filename of avi file i S=RT_String("\n%d/%d ] Processing %s",i+1,NFILES, FN) RT_DebugF(S,name=myName) RT_WriteFileF(LOG,"%s",S,Append=True) DropUndoSequences(FN,ScanAheadSecs,dm=dM, dL=dL, ds=dS, dr=dR,LDThresh=MAX_LDIFF, log=LOG, keepmax=KEEPMAX) T = RT_Timer - START S=RT_String("%s Tot File Time = %.2f Seconds (%.2f Mins)",FN, T,T/60.0) RT_DebugF(S,name=myName) RT_WriteFileF(LOG,"%s",S,Append=True) } T = RT_Timer - TOTSTART S=RT_String("\n\nTOTAL Time = %.2f Seconds (%.2f Mins)\n",T,T/60.0) RT_DebugF(S,name=myName) S=RT_String("\n\nDONE\n\n%s\n",S) RT_WriteFileF(LOG,"%s",S,Append=True) S=RT_StrReplace(S,Chr(10),"\n") """) Return blankclip(length=24*60*60*24).Subtitle(S,Align=5,Y=100,lsp=0,Size=30) Function DropUndoSequences(String "AviName",Float "ScanAheadSecs",int "dM",Float "dL",Float "dS",Float "dR",Float "LDThresh",String "Log",int "KeepMax") { myName="DropUndoSequences: " ScanAheadSecs=Float(Default(ScanAheadSecs,10.0*60.0)) dM = Default(dM,1) dL = Float(Default(dL,0.005)) dS = Float(Default(dS,0.005)) dR = Float(Default(dR,0.005)) LDThresh = Float(Default(LDThresh,0.004)) LOG = Default(LOG,"DropUndoSequences.LOG") KeepMax=Default(KeepMax,0) # 0 = no limit Assert(Exist(AviName),myName+AviName+" Does Not Exist") Avisource(AviName).ConvertToYV12() # So we use the same settings whether orig RGB or YV12 Assert(ScanAheadSecs>0.0,myName+"ScanAheadSecs Must be greater than zero") Assert(dM>=0, myName+"ldM Must be greater than or equal to zero") Assert(dL>=0.0,myName+"ldL Must be greater or equal to zero") Assert(dS>=0.0,myName+"ldS Must be greater or equal to zero") Assert(dR>=0.0,myName+"ldR Must be greater or equal to zero") Assert(KeepMax>=0,myName+"KeepMax Must be greater or equal to zero") PathAndNode = RT_FilenameSplit(AviName,7) # Drive + Dir + Name CMDFrames=PathAndNode+"_Frames.txt" Ranges=PathAndNode+"_Ranges.txt" ScriptFile=PathAndNode+"_SelectFrames.AVS" ScanAheadFrames = Int(ScanAheadSecs*FrameRate) DB=PathAndNode+".DB" PNDB=PathAndNode + "_Prev.DB" RT_FileDelete(CMDFrames) # Delete any existing frames file RT_FileDelete(Ranges) # Delete any existing Ranges file ### TEMPLATE script FrameSel_Select=""" fn="%s" Avisource(fn) PathAndNode="%s" CmdFrames=PathAndNode+"_Frames.txt" Ranges=PathAndNode+"_Ranges.txt" Ex=Exist(CmdFrames) (Ex) ? FrameSel_CmdReWrite(Ranges,cmd=CmdFrames,reject=False) : NOP # Informational ONLY (Ex) ? FrameSel(cmd=CmdFrames,reject=False) : NOP Return Last """ ### Select_S = FrameSel_Select Select_S = RT_StrReplaceDeep(RT_StrReplace(Select_S,Chr(9)," ")," "," ") # TAB and SPACE compact Select_S = RT_String(Select_S,AviName,PathAndNode) # Insert filenames and ConvertToYV12 START = RT_Timer RT_QwikLumaScanCreateDB(DB,prevdb=PNDB,nextdb="",debug=true) T= RT_Timer - START S = RT_String("QWIK Scan DBase creation = %.2f Secs (%.2f Mins)",T,T/60.0) RT_WriteFileF(LOG,"%s",S,Append=True) OCNT=0 GSCript(""" START = RT_Timer LastFrame=FrameCount-1 FivePercFrames = Round(0.05 * FrameCount) RT_DebugF("QWIK Scanning file ... Please Wait",name=myName) MDeltaMax = 0 LDeltaMax = 0.0 SDeltaMax = 0.0 RDeltaMax = 0.0 Kept = 0 For(i=0,LastFrame) { WrStart = i WrEnd = i # Init to keep 1 frame (if not found) EndLimit = Min(i + ScanAheadFrames,LastFrame) # Searching Endlimit to i+1 inclusive (downwards) # Scan for static sequence FindStart = i + 1 for(k=FindStart,EndLimit) { dif=RT_LumaDifference(Last,Last,n=i,n2=k) if(dif <= LDThresh) { WrEnd = k } Else { FindStart = k k = EndLimit # break } } # Here:- WStart to WrEnd are similar, search from EndLimit downward to FindStart for later dupe sequence For(j=EndLimit,FindStart,-1) { # Search for i frame dupe nearest to EndLimit but higher than FindStart j = RT_QwikLumaScanGetNear(DB,PNDB,j, \ ldm = dM, ldl = dL, lds = dS, ldr = dR, \ maxdistance=j-FindStart, Inclusive=True, \ findframe=i) if(j > FindStart) { # We found a candidate frame dif=RT_LumaDifference(Last,Last,n=i,n2=j) # Ave pixel diff between i frame and candidate if(dif <= LDThresh) { # We found a single duplicate frame and will drop earlier sequence, look for start of similar frames in this sequence DupeEnd = j DupeStart = j for(k=j-1,FindStart+1,-1) { tdif=RT_LumaDifference(Last,Last,n=i,n2=k) if(tdif <= LDThresh) { DupeStart = k } Else { k = FindStart # break } } RT_DebugF("%d,%d --> %d,%d Matched LumaDif=%f",WrStart,WrEnd,DupeStart,DupeEnd,dif,name=myName) S=RT_String("%d,%d Skipping earlier duplicate sequence and UNDOS",WrStart,DupeStart-1) RT_debugF("%s",S,name=myName) RT_WriteFileF(LOG,"%s",S,Append=True) RT_Ystats(Last,i,flgs=$78,lo=64,hi=192,Prefix="I_") # Default DBase create, YInRange lo and hi RT_Ystats(Last,j,flgs=$78,lo=64,hi=192,Prefix="J_") I_yInRng = I_yInRng * 255.0 J_yInRng = J_yInRng * 255.0 # Make range same as other YStats (YInrange is 0.0->1.0) MDelta=Abs(I_yMed-J_yMed) LDelta=Abs(I_yAve-J_yAve) SDelta=Abs(I_yStdev-J_yStdev) RDelta=Abs(I_yInRng-J_yInRng) MDeltaMax=Max(MDeltaMax,MDelta) LDeltaMax=Max(LDeltaMax,LDelta) SDeltaMax=Max(SDeltaMax,SDelta) RDeltaMax=Max(RDeltaMax,RDelta) RT_DebugF("MDelta=%d LDelta=%f SDelta=%f RDelta=%f",MDelta,LDelta,SDelta,RDelta,name=myName) WrStart = DupeStart WrEnd = DupeEnd j = 0 # Early break } } } Keep = (WrEnd-WrStart+1) if(KeepMax>0 && Keep>KeepMax) { # Limit frames to keep RT_DebugF("KeepMax Limiting: %d frames limited to %d (%d,%d -> %d,%d)",Keep,KeepMax,WrStart,WrEnd,WrEnd-KeepMax+1,WrEnd,name=myName) Keep = KeepMax WrStart=WrEnd-Keep+1 } Kept = Kept + Keep if(Keep == 1) { RT_WriteFileF(CMDFrames,"%d",WrStart,Append=True) } else { RT_WriteFileF(CMDFrames,"%d,%d",WrStart,WrEnd,Append=True) } i = WrEnd If(i > (OCNT+FivePercFrames)) { T= RT_Timer - START RT_DebugF("%d ] Progress = %.2f%% InFrames=%d OutFrames=%d InFPS=%.2fFPS OutFPS=%.2f", \ i,(i+1)*100.0/(LastFrame+1),i+1,Kept,(i+1)/T,Kept/T,name=myName) OCNT=i } } RT_WriteFileF(ScriptFile,"%s",Select_S,Append=False) RT_FileDelete(DB) RT_FileDelete(PNDB) S=RT_String("MDeltaMax=%d LDeltaMax=%f SDeltaMax=%f RDeltaMax=%f",MDeltaMax,LDeltaMax,SDeltaMax,RDeltaMax) RT_debugF("%s",S,name=myName) RT_WriteFileF(LOG,"%s",S,Append=True) S="(Above, maximum values of dM, dL, dS, dR, that would have worked, but may have been faster)" RT_debugF("%s",S,name=myName) RT_WriteFileF(LOG,"%s",S,Append=True) T = RT_Timer - START FT=FrameCount / FrameRate S=RT_String("Kept %d of %d frames [%dx%d %.2f secs (%.2f Mins) @ %.2f FPS]", Kept, FrameCount,Width,Height,FT,FT/60.0,FrameRate) RT_DebugF(S,name=myName) RT_WriteFileF(LOG,"%s",S,Append=True) S=RT_String("QWIK SCAN %.2f Secs (%.2f Mins) InFPS=%.2f OutFPS=%.2f", T,T/60.0,FrameCount/T,Kept/T) RT_DebugF(S,name=myName) RT_WriteFileF(LOG,"%s",S,Append=True) """) Return 0 }
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 17th December 2014 at 21:43. |
20th April 2014, 04:08 | #51 | Link |
Thanks StainlessS
Thanks StainlessS I will try this last script with my 30min videos.
Did you see my last PM? I did a summary of all most subtle strokes in a 46mb video, I was wondering which strokes are posible to process, and which are not. Thanks advanced. |
20th April 2014, 15:09 | #52 | Link | |
Yes I DL your clip from last PM, thank you.
Am in process of converting to 3 channel fingerprint rather than Luma only. Not working as good as Luma only as yet. EDIT: Quote:
and its usually quite different to whatever its overlaying.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 20th April 2014 at 18:55. |
20th April 2014, 20:00 | #53 | Link |
yes man, the cursor its a pain, there is no way to remove it, I did my best to kinda hide it, so I set the app to display only four little white dots (kinda pixel size) in crossshape that always appear on the screen.
Some times it changes to a circular or eliptical white shapes, but those can be removed by me, I mean I can set the app to avoid display those circular and eliptical cursors, so you can deal only with the crossshape one. I will see if I can figure out a way to get rid of the crossshape cursor, because if I delete it, then I could not see where I am actually positioning the brush in the screen. Thanks advanced. Last edited by eduardobedoya; 20th April 2014 at 20:15. |
20th April 2014, 20:26 | #54 | Link |
I've implemented a new function RT_LumaPixelsDifferent() for this problem, gives a pixel count of number of pixels
that are different in any way (RGB converted to Luma_Y before compare). Here output of test of a few frames from your original clip, 1st two numbers are frame numbers compared Code:
00000076 432.54067993 [3936] RT_DebugF: 172:173 ] CDif=0.000000 LDif=0.000000 CNT=0 00000077 432.61959839 [3936] RT_DebugF: 172:174 ] CDif=0.000000 LDif=0.000000 CNT=0 00000078 432.69915771 [3936] RT_DebugF: 172:175 ] CDif=0.000340 LDif=0.000838 CNT=108 00000079 432.77612305 [3936] RT_DebugF: 172:176 ] CDif=0.000447 LDif=0.000912 CNT=189 00000080 432.85601807 [3936] RT_DebugF: 172:177 ] CDif=0.000433 LDif=0.000894 CNT=179 00000081 432.93295288 [3936] RT_DebugF: 172:178 ] CDif=0.000440 LDif=0.000899 CNT=188 00000082 433.00939941 [3936] RT_DebugF: 172:179 ] CDif=0.000348 LDif=0.000727 CNT=163 00000083 433.08856201 [3936] RT_DebugF: 172:180 ] CDif=0.001467 LDif=0.002735 CNT=659 is an edit, 189 pixels changed just looks to me like a cursor move. Frame 180 is a smallish edit.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 20th April 2014 at 20:30. |
20th April 2014, 22:56 | #55 | Link |
It seems to be very accurate
a particular solution for a particular problem?
Looks very accurate, Thanks StainlessS The main cursor is a cross shape of four pixelsize white dots, I could get rid of it, but then I could not see where I am actually positioning the brush in the screen Some times the cursor is shown as a circular or eliptical white shapes, I can easily set the program so they dont appear anymore, so that you can focus on dealing with the main cross shape cursor. PD: I have a bunch of recorded painting sesions already trimmed by hand, I would like to test them out with your new script. Last edited by eduardobedoya; 20th April 2014 at 23:09. |
20th April 2014, 23:41 | #56 | Link |
This shows changes from previous frame (including eg cursor movement)
SHOW=True aviName="D:\avs\avi\in\painting test for avisynth.avi.AVI" Avisource(AviName) Prev=DeleteFrame(FrameCount-1).SelectEvery(1,-1) Clipdelta(Prev,Last,true,SHOW) ScriptClip("""RT_SubTitle("%d",current_frame)""") return Last # Return Clip Difference of input clips (amp==true = Amplified, show==true = show background) Function ClipDelta(clip clip1,clip clip2,bool "amp",bool "show") { amp=Default(amp,false) show=Default(show,false) c2=clip1.levels(128-32,1.0,128+32,128-32,128+32).greyscale() c1=clip1.subtract(clip2) c1=(amp)?c1.levels(127,1.0,129,0,255):c1 return (show)?c1.Merge(c2):c1 } EDIT: Oh dear!, seems when you do an undo, it leaves some rubbish in the undo region. This compares all frames with frame 372, play from 372 and see the rubbish left after undos. Code:
FRAME=372 aviName="D:\avs\avi\in\painting test for avisynth.avi.AVI" Avisource(AviName) A=trim(FRAME,-1) A=A.FreezeFrame(1,Last.FrameCount-1,0) Clipdelta(a,Last,true) ScriptClip("""RT_SubTitle("%d",current_frame)""") return Last # Return Clip Difference of input clips (amp==true = Amplified, show==true = show background) Function ClipDelta(clip clip1,clip clip2,bool "amp",bool "show") { amp=Default(amp,false) show=Default(show,false) c2=clip1.levels(128-32,1.0,128+32,128-32,128+32).greyscale() c1=clip1.subtract(clip2) c1=(amp)?c1.levels(127,1.0,129,0,255):c1 return (show)?c1.Merge(c2):c1 }
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 21st April 2014 at 00:22. |
21st April 2014, 02:41 | #57 | Link |
so, now the script is looking better than I?
I never realize of that rubbish left areas
The circular and eliptical cursor will not appear anymore. I am still looking for a way get rid of the crossshape cursor, if the avs script will be more accurate by removing the crossshape cursor, then I will try find a way to get rid of it. Last edited by eduardobedoya; 21st April 2014 at 18:06. |
26th April 2014, 14:05 | #58 | Link | |
I have not forgotten you, I am still working on a solution, hopefully within a few days I can have something that mostly works OK, even with the cursor and undo rubbish present.
26th April 2014, 17:35 | #59 | Link |
Thanks StainlessS
of course, Ill wait until your next release
I am still looking for a way to get rid of the crossshape cursor, I have made a post in superuser and stackoverflow, asking for a third party appplication that could show a cursor (ico file) in the screen always, so I can disable the paint program crossshape cursor. Once I have only a ico file cursor I can tell camtasia to not record it. (I just dont know why this option just does not work with the crossshape cursor). I will submit any news. Thanks StainlessS EDIT> I kinda get rid of the cloud crossshape cursor, message sent. Last edited by eduardobedoya; 27th April 2014 at 18:25. |
24th May 2014, 04:09 | #60 | Link |
Saw that you were on-line yesterday.
I'm still working on this and have not forgotten you, (although I have had a few excursions doing other things just because my head hurts when I keep banging it against the wall). I have not as yet moved on to try your later clip with the single 3x2 pixel cursor, I'm still banging away at the more difficult 1st clip you provided. Anyway, just thought I'de let you know that I have not (as yet) given up totally
avisynth, detection, duplicated, frames, trim |
