Old 26th February 2021, 14:36   #1341  |  Link
Nikse555
Originally Posted by von Suppé View Post
Hi Nikse
...Therefor, could you implement a column/box in the text-editor where one can "check forced" the desired lines? In such a way, that during SUP/XML-PNG export, these will be auto-checked as forced?
Something like this?
https://github.com/SubtitleEdit/subt...leEditBeta.zip
Nikse555 is offline   Reply With Quote
Old 26th February 2021, 16:09   #1342  |  Link
von Suppé
von Suppé's Avatar
Thanks for quick response, but I can't find what I'm looking for. Can you direct me?
Old 26th February 2021, 16:16   #1343  |  Link
Nikse555
There should be check boxes in the edit bd sup list view...
Old 26th February 2021, 17:31   #1344  |  Link
von Suppé
von Suppé's Avatar
Oh damn, I see now. You put them in the Import --> "Sup for edit" window. But it's not where I meant them to be (besides, there is already a forced check-box in that window, so it's a bit double).
I meant the checkboxes to be possible in the main list view in text editor mode. So that the checked lines will be auto-checked as forced in the File --> Export --> Blu-ray SUP (or XML-PNG) export window.
Old 1st March 2021, 12:58   #1345  |  Link
Easymanandvan
Thanks, that worked for me as well
Easy man&van
Easymanandvan is offline   Reply With Quote
Old 6th March 2021, 14:07   #1346  |  Link
tormento
Acid fr0g
tormento's Avatar
Just noticed that I can't find source view anymore...
Where has it gone?
@turment on Telegram
Old 6th March 2021, 17:31   #1347  |  Link
von Suppé
von Suppé's Avatar
Rightclick in list-view, it's there. Or press F2.
Old 11th March 2021, 22:59   #1348  |  Link
nekrovski
nekrovski's Avatar
I have a file like this
General
Complete name                            : C:\Users\User\Desktop\h\zz.ts
Format                                   : MPEG-TS
File size                                : 170 MiB
Duration                                 : 11 min 24 s
Overall bit rate mode                    : Variable
Overall bit rate                         : 2 086 kb/s
Video
Menu ID                                  : 1 (0x1)
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format profile                           : Main@L3.1
Format settings                          : CABAC / 4 Ref Frames
Format settings, CABAC                   : Yes
Format settings, Reference frames        : 4 frames
Codec ID                                 : 27
Bit rate mode                            : Constant
Nominal bit rate                         : 1 800 kb/s
Width                                    : 960 pixels
Height                                   : 540 pixels
Display aspect ratio                     : 16:9
Frame rate                               : 29.970 (30000/1001) FPS
Bit depth                                : 8 bits
Scan type                                : Progressive
Bits/(Pixel*Frame)                       : 0.116
Audio
Menu ID                                  : 1 (0x1)
Format                                   : AAC LC
Format/Info                              : Advanced Audio Codec Low Complexity
Format version                           : Version 4
Muxing mode                              : ADTS
Codec ID                                 : 15-2
Duration                                 : 11 min 23 s
Bit rate mode                            : Variable
Channel(s)                               : 2 channels
Channel layout                           : L R
Sampling rate                            : 44.1 kHz
Frame rate                               : 43.066 FPS (1024 SPF)
Text #1
ID                                       : 256 (0x100)-CC1
Menu ID                                  : 1 (0x1)
Format                                   : EIA-608
Muxing mode                              : SCTE 128 / DTVCC Transport
Muxing mode, more info                   : Muxed in Video #1
Stream size                              : 0.00 Byte (0%)
CaptionServiceName                       : CC1
Text #2
ID                                       : 256 (0x100)-1
Menu ID                                  : 1 (0x1)
Format                                   : EIA-708
Menu
Menu ID                                  : 1 (0x1)
List                                     : 256 (0x100) (AVC) / 257 (0x101) (AAC)
Service name                             : Service01
Service provider                         : FFmpeg
Service type                             : digital television
Why can't Subtitle edit read the subtitles from this file?
A ffmpeg command successfully converts them to a .srt so I made sure they are actually in the file but what needs to be done for Subtitle Edit to be able to read these kinds of subtitles?
nekrovski is offline   Reply With Quote
Old 13th March 2021, 07:36   #1349  |  Link
Nikse555
@nekrovski: SE only supports DVB/BD images and teletext from ts files.
I did not even know that other subtitle types were possible in ts files.
Could you supply a link to the file? (PM or email is also fine)
Old 15th March 2021, 09:48   #1350  |  Link
tormento
Acid fr0g
tormento's Avatar
@Nikse555
I think you forgot the French characters menu during OCR: à, â, è, é, ê, ë, î, ï, ô, œ, Œ, ù, û, ç, Ç.
Old 24th March 2021, 08:57   #1351  |  Link
tormento
Acid fr0g
tormento's Avatar
Originally Posted by Nikse555 View Post
@nekrovsk
Where are you?
Old 24th March 2021, 11:24   #1352  |  Link
Hidson
Timing messed up when saving at .sub
I am creating subtitles on Subtitle Edit, and when I save them at the .sub format and next time I open the file, the timing is all messed up. What could it be?
EDIT: It doesn't happen if I work on and save the same file as .srt.
Hidson is offline   Reply With Quote
Old 24th March 2021, 19:59   #1353  |  Link
locotus
Instead of save use export vobsub (sub-idx)
locotus is offline   Reply With Quote
Old 26th March 2021, 13:12   #1354  |  Link
Hidson
That generates a binary file instead of an editable subtitle.
What I'm doing is working on the .SRT and only saving as .sub in the end.
Old 5th April 2021, 12:20   #1355  |  Link
Ghitulescu
Ghitulescu's Avatar
IDX/SUB is binary and "less" editable.
Why do you need to "edit" it anyway, as you already said that you do the wotk in SRT and only to the end save as IDX/SUB?
Is there any life after death?
Born in the USB (not USA)
Old 5th April 2021, 12:24   #1356  |  Link
Ghitulescu
Ghitulescu's Avatar
Originally Posted by nekrovski View Post
Text #1
Format : EIA-608
Format : EIA-708
[/code]
This is closed caption and useless anywhere outside USA.
They are not part of any stream, but rather embedded in the video stream.
Since they use only capitals and they are "narrow" (what, 16 chars/line up to 4 lines) I use them only as a timing guidance for real subtitles.
There are two major ways to extract them, see the relevant section in the tools/software.
Old 7th April 2021, 10:19   #1357  |  Link
jmj
I would guess this to be the text based MicroDVD format and not IDX/VOBSUB.
jmj is offline   Reply With Quote
Old 8th April 2021, 01:08   #1358  |  Link
Hidson
Apparently the studio needs it editable. In the end, it's better to keep saving as SRT and just "save as" the preferred .sub format that remains editable.
Old 16th April 2021, 06:57   #1359  |  Link
loninapleton
Hello,
I upgraded to Subtitle Edit 3.6 and the icon .ico is changed to bright red.
Can I get a link to the old .ico file for my shortcut in the task bar?
I could pick a random one but I'm used to looking for the old one when needed.
loninapleton is offline   Reply With Quote
Old 17th April 2021, 10:27   #1360  |  Link
von Suppé
von Suppé's Avatar
Here you go. Think Nikse won't mind.
