Old 1st September 2009, 12:16   #1921  |  Link
whipdancer
Originally Posted by rickatnight11 View Post
Generally the main movie is only one of those m2ts files. The rest are the bonus extras on the disk. Your call, though.
Apparently this is one of those BD movies that doesn't have a single m2ts file for the main movie. It's got about 100 different m2ts files, the largest of which is about 2gb in size.
whipdancer is offline   Reply With Quote
Old 1st September 2009, 12:19   #1922  |  Link
whipdancer
make report
Here's the make report
HDConvertToX v.2.1.465.3552 "Isotta" report
Input File: d:\gran torino\bdmv\stream\00004.m2ts ( D:\GRAN TORINO\BDMV\STREAM\00004.m2ts )
Codec Video: vc-1
Width / Heigh : 1920 / 1080
Framerate / Framecount: 23.976 / 167706
Duration(hh:mm:ss): 1:56:35
Aspect Ratio: 1.7778
Resized resolution: 1920 / 800
Crop Values : 0:140:0:140
Start Video Configuration ->
Encoding Settings: X264 Extreme Quality ; Bitrate= 8000
Encoding Preset: 6
Final Size: 700
Priority: idle
Denoise Level: Super Light
Set Manual Bitrate: 8000
Video Handling: Use Best Decoder
-> End Video Configuration
Start Audio Configuration ->
Audio Codec: Nero AAC Audio
Audio Bitrate/Quality: 64
Audio Channels: Original
MP3 Mode: abr
Normalize: On
Audio handling: Use Eac3to as demuxer
Keep only core: On
-> End Audio Configuration
Full Audio List-> (*** mean selected)
NONE
*** 3: truehd/ac3, english, 5.1 channels, 48khz, dialnorm: -27db
4: ac3, english, 5.1 channels, 640kbps, 48khz, dialnorm: -27db
5: ac3, french, 5.1 channels, 640kbps, 48khz, dialnorm: -27db
6: ac3, spanish, 5.1 channels, 640kbps, 48khz, dialnorm: -27db
7: ac3, portuguese, 5.1 channels, 640kbps, 48khz, dialnorm: -27db
-> End Full Audio List
Full Subtitle List-> (*** mean selected)
*** NONE
8: subtitle (pgs), english
9: subtitle (pgs), french
10: subtitle (pgs), spanish
11: subtitle (pgs), portuguese
12: subtitle (pgs), english
13: subtitle (pgs), french
14: subtitle (pgs), spanish
-> End Full Subtitle List
Encrust Subtitle in Video file: On
Start Advanced AviSynth ->
ColorMatrix: On
-> End Advanced AviSynth
Start Queue ->
prompt $d $t $_$P$G
"C:\Program Files (x86)\hdconvert\applications\eac3to.exe" "d:\gran torino\bdmv\stream\00004.m2ts" 3: stdout.wav  -normalize  | "C:\Program Files (x86)\hdconvert\applications\neroaacenc.exe" -if - -br 64000 -ignorelength -of "C:\Program Files (x86)\hdconvert\analysis\hdencodertox-pid3.mp4"
"C:\Program Files (x86)\hdconvert\applications\x264.exe" --pass 1 --bitrate 8000  --preset medium --trellis 0 --ref 4 --deblock -1,-1 --subme 9 --direct auto --me umh --b-adapt 2 --no-chroma-me  --tune film  --sar 1:1  --output "C:\Program Files (x86)\hdconvert\analysis\hdconverttox_00004.h264" "C:\Program Files (x86)\hdconvert\analysis\hdconverttox_00004.avs"
"C:\Program Files (x86)\hdconvert\applications\x264.exe" --pass 2 --bitrate 8000  --preset medium --trellis 0 --ref 4 --deblock -1,-1 --subme 9 --direct auto --me umh --b-adapt 2 --no-chroma-me  --tune film  --sar 1:1  --output "C:\Program Files (x86)\hdconvert\analysis\hdconverttox_00004.h264" "C:\Program Files (x86)\hdconvert\analysis\hdconverttox_00004.avs"
"C:\Program Files (x86)\hdconvert\applications\eac3to.exe" 1:"C:\Program Files (x86)\hdconvert\analysis\chapters.txt"
"C:\Program Files (x86)\hdconvert\applications\mp4box.exe" -add "C:\Program Files (x86)\hdconvert\analysis\hdconverttox_00004.h264" -fps 23.976  -add "C:\Program Files (x86)\hdconvert\analysis\hdencodertox-pid3.mp4":lang=eng  -chap "C:\Program Files (x86)\hdconvert\analysis\chapters.txt" "C:\Program Files (x86)\hdconvert\hdconverttox_full_00004.mp4"
-> End Queue
AviSynth Script ->
Working with files: C:\Program Files (x86)\hdconvert\analysis\hdconverttox_00004.avs
SetMemoryMax(512)
SetMTMode(2,0)
directshowsource("d:\gran torino\bdmv\stream\00004.m2ts",audio=false)
last = isRGB(last) ? ConvertToYV12(last) : last
last = isYUY2(last) ? ConvertToYV12(last) : last
GaussResize(1920,800,0,140,-0,-140,p=75)
ColorMatrix(mode="Rec.709->Rec.601")
hqdn3d(1)
-> End AviSynth Script
Old 1st September 2009, 13:19   #1923  |  Link
flebber
Practising Schemer
Whipdancer how did you enable HDC to read the IFO chapter files?
flebber is offline   Reply With Quote
Old 1st September 2009, 15:19   #1924  |  Link
prospeed
x264 stalled?
Hey Guys,
Wondering if I could get some advice as to what has happened with this encode as x264 seems to have stalled...
Input File: d:\dayaftertomorrow\bdmv\stream\00001.m2ts ( D:\DAYAFTERTOMORROW\BDMV\STREAM\00001.m2ts )
Codec Video: avc
Framerate / Framecount: 23.976 / 574508
Duration(hh:mm:ss): 6:39:22
Resized resolution: 1920 / 1072
Crop Values : 0:4:0:4
Encoding Settings: X264 Extreme Quality ; Bitrate= 1498
NMT Compatibility: On
Encoding Preset: 7
Final Size: 8704
Priority: idle
Video Handling: Force DirectShowSource2 (Haali)
Audio Bitrate/Quality: 224
Audio Channels: 6 (5.1)
MP3 Mode: abr
Normalize: On
Keep only core: On
NONE
*** 3: dts master audio, english, 5.1 channels, 24 bits, 48khz, -14ms
*** 4: ac3, english, 2.0 channels, 224kbps, 48khz, dialnorm: -27db, 4ms
NONE
*** 5: subtitle (pgs), english
*** 6: subtitle (pgs), english
Mux Subtitle in MP4/MKV file: On
ColorMatrix: On
Start Queue ->
prompt $d $t $_$P$G
"C:\Users\ \Downloads\HDConvertToX_2.0.424.3356\applications\eac3to.exe" "d:\dayaftertomorrow\bdmv\stream\00001.m2ts" 5:"C:\Users\ \Downloads\HDConvertToX_2.0.424.3356\job1\hdencodertox__subs_5.sup" 6:"C:\Users\ \Downloads\HDConvertToX_2.0.424.3356\job1\hdencodertox__subs_6.sup"
"C:\Users\ \Downloads\HDConvertToX_2.0.424.3356\applications\eac3to.exe" "d:\dayaftertomorrow\bdmv\stream\00001.m2ts" 3: stdout.wav  -normalize  -down6 | "C:\Users\ \Downloads\HDConvertToX_2.0.424.3356\applications\neroaacenc.exe" -if - -br 224000 -ignorelength -of "C:\Users\ \Downloads\HDConvertToX_2.0.424.3356\job1\hdencodertox-pid3.mp4"
"C:\Users\ \Downloads\HDConvertToX_2.0.424.3356\applications\eac3to.exe" "d:\dayaftertomorrow\bdmv\stream\00001.m2ts" 4: stdout.wav  -normalize  -down2 | "C:\Users\ \Downloads\HDConvertToX_2.0.424.3356\applications\neroaacenc.exe" -if - -br 224000 -ignorelength -of "C:\Users\ \Downloads\HDConvertToX_2.0.424.3356\job1\hdencodertox-pid4.mp4"
java -jar "C:\Users\ \Downloads\HDConvertToX_2.0.424.3356\applications\BDSup2Sub.jar" "C:\Users\ \Downloads\HDConvertToX_2.0.424.3356\job1\hdencodertox__subs_5.sup" "C:\Users\ \Downloads\HDConvertToX_2.0.424.3356\job1\hdencodertox__subs_5.idx" /res:1080p
java -jar "C:\Users\ \Downloads\HDConvertToX_2.0.424.3356\applications\BDSup2Sub.jar" "C:\Users\ \Downloads\HDConvertToX_2.0.424.3356\job1\hdencodertox__subs_6.sup" "C:\Users\ \Downloads\HDConvertToX_2.0.424.3356\job1\hdencodertox__subs_6.idx" /res:1080p
"C:\Users\ \Downloads\HDConvertToX_2.0.424.3356\applications\x264.exe" --pass 1 --bitrate 2598  --preset medium --bframes 3 --trellis 0 --ref 3 --deblock -1,-1 --subme 9 --direct auto --me umh --b-adapt 1 --no-chroma-me  --sar 1:1  --output "C:\Users\ \Downloads\HDConvertToX_2.0.424.3356\job1\hdconverttox_00001.h264" "C:\Users\ \Downloads\HDConvertToX_2.0.424.3356\job1\hdconverttox_00001.avs" --level 4.0
"C:\Users\ \Downloads\HDConvertToX_2.0.424.3356\applications\x264.exe" --pass 2 --bitrate 2598  --preset medium --bframes 3 --trellis 0 --ref 3 --deblock -1,-1 --subme 9 --direct auto --me umh --b-adapt 1 --no-chroma-me  --sar 1:1  --output "C:\Users\ \Downloads\HDConvertToX_2.0.424.3356\job1\hdconverttox_00001.h264" "C:\Users\ \Downloads\HDConvertToX_2.0.424.3356\job1\hdconverttox_00001.avs" --level 4.0
"C:\Users\ \Downloads\HDConvertToX_2.0.424.3356\applications\eac3to.exe" "d:\dayaftertomorrow\bdmv\stream\00001.m2ts" 1:"C:\Users\ \Downloads\HDConvertToX_2.0.424.3356\job1\chapters.txt"
"C:\Users\ \Downloads\HDConvertToX_2.0.424.3356\applications\mkvmerge.exe" -o "D:\DAYAFTERTOMORROW\BDMV\STREAM\DAY_AFTER_TOMORROW.MKV" --default-duration 0:23.976fps  "C:\Users\ \Downloads\HDConvertToX_2.0.424.3356\job1\hdconverttox_00001.h264"   --language -1:eng "C:\Users\ \Downloads\HDConvertToX_2.0.424.3356\job1\hdencodertox-pid3.mp4"  --language -1:eng "C:\Users\ \Downloads\HDConvertToX_2.0.424.3356\job1\hdencodertox-pid4.mp4" --default-track -1:no   --language -1:eng "C:\Users\ \Downloads\HDConvertToX_2.0.424.3356\job1\hdencodertox__subs_5.idx"   --language -1:eng "C:\Users\ \Downloads\HDConvertToX_2.0.424.3356\job1\hdencodertox__subs_6.idx"  --chapters "C:\Users\ \Downloads\HDConvertToX_2.0.424.3356\job1\chapters.txt"  --title "Done with HDConvertToX v.2.1.465.3552 _Isotta_"
-> End Queue
AviSynth Script ->
Working with files: C:\Users\ \Downloads\HDConvertToX_2.0.424.3356\job1\hdconverttox_00001.avs
DSS2("d:\dayaftertomorrow\bdmv\stream\00001.m2ts",fps=23.976)
LanczosResize(1920,1072,0,4,-0,-4)
hqdn3d(1)
Also:
Writing C:\Users\Downloads\HDConvertToX_2.0.424.3356\job1\hdencodertox__subs
_6.idx
Conversion of 1 file(s) finished
Tue 01/09/2009 12:04:14.26
C:\Users\Downloads\HDConvertToX_2.0.424.3356\job1>"C:\Users\Downloads\HD
--me umh --b-adapt 1 --no-chroma-me  --sar 1:1  --output "C:\Users\Downloads
\HDConvertToX_2.0.424.3356\job1\hdconverttox_00001.h264" "C:\Users\Downloads
avis [info]: 1920x1072 @ 23.98 fps (574505 frames)
x264 [info]: using SAR=1/1
x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 FastShuffle SSE4.1 Cach
e64
x264 [info]: cabac=1 ref=1 deblock=1:-1:-1 analyse=0x1:0 me=dia subme=2 psy_rd=0
.0:0.0 mixed_ref=0 me_range=16 chroma_me=0 trellis=0 8x8dct=0 cqm=0 deadzone=21,
11 chroma_qp_offset=0 threads=3 nr=0 decimate=1 mbaff=0 bframes=3 b_pyramid=0 b_
adapt=1 b_bias=0 direct=3 wpredb=1 keyint=250 keyint_min=25 scenecut=40 rc=abr b
itrate=2598 ratetol=1.0 qcomp=0.60 qpmin=10 qpmax=51 qpstep=4 ip_ratio=1.40 pb_r
atio=1.30 aq=1:1.00
x264 [info]: profile Main, level 4.0
[0.0%] 60/574505 frames, 24.40 fps, 15.20 kb/s, eta 6:32:22
prospeed is offline   Reply With Quote
Old 1st September 2009, 16:25   #1925  |  Link
Adub
Fighting spam with a fish
Adub's Avatar
It does it automatically. Just be sure to select the IFO file when converting your DVD.
FAQs:Bond's AVC/H.264 FAQ
Site:Adubvideo
Old 1st September 2009, 18:41   #1926  |  Link
Sharc
This helps. All vobs are included now. Thanks!
Old 1st September 2009, 21:42   #1927  |  Link
whipdancer
Are you referring to when I convert a DVD? I simply select the Video_TS.ifo (i think that's it) when picking the file. After that I get a prompt from HDC indicating that it's analyzed the ifo file and found the movie/soundtrack.
Old 1st September 2009, 23:30   #1928  |  Link
flebber
Practising Schemer
So when I select Multi Episodes DVD it will automatically read episode chapter files and apply them to muxed output without enabling anything? Or do I need to enable autochapter in hidden options?
Old 2nd September 2009, 07:20   #1929  |  Link
buzzqw
HDConvertToX author
thanks fixed, use live update
just select your vts_xxxx.ifo
if you select video_ts.ifo, chapter wouldn't be extracted
autochapter is in hdconverttox.ini...
Originally Posted by prospeed View Post
Hey Guys,
hqdn3d(1)
you are using DirectShowSource.
Most probably dss isn't feeding frames to encoder.
make sure you have a working decoder for your video
BHH
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
Old 2nd September 2009, 12:31   #1930  |  Link
flebber
Practising Schemer
BHH
so if I change my ini to autochapter=1 then extracted chapters from vts.ifo will be automaticaly applied to final output during muxing?
Old 2nd September 2009, 13:46   #1931  |  Link
prospeed
BHH
Thanks buzzqw
Old 2nd September 2009, 14:15   #1932  |  Link
buzzqw
HDConvertToX author
in advanced options there is the autochapter check
BUT if you want that autochapter is alwasy ON, you must use the ini
anyway, you don't have to check autochapter when working with ifo.
select the correct ifo and hdc will extract the chapter file
if you check autochapter it will overwrite the chapters of dvd
BHH
Old 2nd September 2009, 14:25   #1933  |  Link
flebber
Practising Schemer
Thanks Buzzqw I fully understand now, you are making it too easy...
Old 2nd September 2009, 22:54   #1934  |  Link
Sharc
Thanks buzzqw for adding -par x:y to the XviD command line.
Anamorphic encoded XviD streams are now always played back with the correct AR.
Old 3rd September 2009, 01:32   #1935  |  Link
Chengbin
buzzqw, could you add a function to HDC?
Could you allow multiple videos to be loaded at once? Many times I have to cut a video into multiple parts (as many as 86 once). It is NOT fun building a 86 job queue in HDC (took an hour). You don't need to analyze a script anyway.
Even for videos, a bulk analyze is much more sane (for the lack of better word). This is especially helpful if I'm encoding multiple videos with the same settings.
Oh, don't tell me to use Avisynth, because I need to use different settings for them.
Chengbin is offline   Reply With Quote
Old 3rd September 2009, 02:42   #1936  |  Link
Crono141
As someone who just spent about an hour adding 26 episodes to a queue, I must second Chengbin's request. I'll be doing something similar with a 50+ episode set of anime, and I'm not looking forward to the queueing.
Any possibility of mirroring MediaCoder's queue system, or something similar?
But not ripbot's. Takes way to damn long to analyze, and you have to do it one at a time. Blarg...
Crono141 is offline   Reply With Quote
Old 3rd September 2009, 07:39   #1937  |  Link
buzzqw
HDConvertToX author
and i should suppose that every files loaded share the same proprieties ? (lenght, fps, width/height, kind of streams...)
BHH
Old 3rd September 2009, 11:57   #1938  |  Link
buzzqw
HDConvertToX author
very beta build: http://www.64k.it/andres/data/hdconv...rtToX-beta.exe
added support for "quick queqing"
after first file, HDC will ask if next loaded file(s) share same proprieties as file before
BHH
Old 3rd September 2009, 12:39   #1939  |  Link
Chengbin
buzzqw, thank you
Is this possible in "quick queuing" mode?
Old 3rd September 2009, 12:57   #1940  |  Link
buzzqw
HDConvertToX author
not now, you must add one file at time
BHH
bluray, hdc, hdconverttox, m2ts, network media tank, playstation, x264 gui
