Old 18th January 2015, 15:16   #22121  |  Link
DVD Maniac
Originally Posted by gonca View Post
Your settings are off. Try re-installing LAVFILTERS.
Tried that with the 0.63 versions. I get the same Inspect output. If LAV is installed correctly, what should the Inspect output be?
DVD Maniac is offline   Reply With Quote
Old 18th January 2015, 16:05   #22122  |  Link
jdobbs
What are you using to install them? They aren't showing as installed in the system registry. Use the link on the first page of this thread for installation.
If it is installed correctly you will see "- LAVFILTERS: Ok" in INSPECT, and none of the FFDSHOW settings will be checked.
Website: www.jdobbs.net
Old 18th January 2015, 17:01   #22123  |  Link
DVD Maniac
Hi jdobbs,
I'm using the install link supplied on this forum link, v0.63. What's really bizzare is I have run successful backups on another PC with the exact same source, exact same setup (LAV only) and exact same output settings and the mkv output file plays perfectly on any machine on my LAN. AND the INSPECT output does NOT show any reading on LAV filters as you state above. Here is the INSPECT output on the PC producing a correctly playing output -
- Windows Version: 6.1 [7601]
- AVISYNTH Version: [2.5.8.0], Ok
- HAALI Splitter: Not installed
- FFDSHOW doesn't appear to be installed
- FFDSHOW Audio doesn't appear to be installed
- WIN7 preferred AVC CODEC: Not Set correctly
- WIN7 preferred VC-1 CODEC: Not Set correctly
- WIN7 preferred MPEG2 CODEC: Not Set correctly
- FFDSHOW VC-1 set incorrectly: [0]
- FFDSHOW MPEG2 set incorrectly: [0]
- FFDSHOW AVC set incorrectly: [0]
- AnyDVD settings check: Ok.
- BD-RB v0.50.0.2, not current
and yet HKEY_CURRENT_USER in the registry clearly shows a LAV entry. What the hell????
Old 18th January 2015, 18:15   #22124  |  Link
gonca
Any codec packs installed? Is it possible your A/V is interfering with BD_RBs attempts at setting LAVFILTERS as preferred.
gonca is offline   Reply With Quote
Old 18th January 2015, 18:57   #22125  |  Link
DVD Maniac
Nope.Just LAV. And I use WIN7DSFilter Tweaker to se LAV as default for all file types. What's so annoying is I sorted this issue before by removing all unecessary codecs and sticking with LAV only. Suddenly the problem has come back and i'm out of ideas troubleshooting the issue. Short of an OS reinstall I don't see what I can try next?
Old 18th January 2015, 19:48   #22126  |  Link
musiclover
@DVD Maniac
You have to use the INSPECT under the Help menu and NOT the stand alone INSPECT program.
musiclover is offline   Reply With Quote
Old 18th January 2015, 20:08   #22127  |  Link
DVD Maniac
Originally Posted by musiclover View Post
@DVD Maniac
Oh OK thanks. That gives -
[01/18/15] Checking System Settings
- BD-Rebuilder v0.50.02
- Working Path Free Space: 100.82GB
- AVISYNTH Version: 2.5.8.0, Ok
- LAVFILTERS: Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
- FRIMEncode: Ok
- FRIMDecode: Ok
[01/18/15] Systems Settings Check complete
On the PC not behaving and -
- Working Path Free Space: 632.08GB
- LAVFILTERS: Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
- FRIMEncode: Ok
- FRIMDecode: Ok
On the one that does. So now what???
Old 18th January 2015, 21:08   #22128  |  Link
g00g
Hello,
since version 0.50.0.2 alternate output doesn't work for me. I tried to encode mp4-1280*720-acc by setting 2 pass encoding with a fixed size (third option). When I start encoding a pop up appears telling me that the audio is too big to fit into the fixed size and suggests crf. The same happens if i choose the 2 pass encoding with fixed bitrate (second option).
In the moment I use version 0.50.01 for alternate encoding.
additionally if i tried to upscale an imported dvd and encode it to mp4-1280*720-acc a pop up appears telling me about an h.264 error. Is it possible that's because the imported format is interlaced?
g00g is offline   Reply With Quote
Old 18th January 2015, 21:43   #22129  |  Link
DVD Maniac
Originally Posted by g00g View Post
Hello,
Well latest test with the "working PC" has produced a dodgy output. Cannot skip forwards / backwards or chapter surf without any player crashing...
Old 18th January 2015, 22:34   #22130  |  Link
gonca
DVD Maniac
Post your config file and I will run a test with my system.
Old 18th January 2015, 23:03   #22131  |  Link
gonca
Just finished a quick test
[01/18/15] BD Rebuilder v0.50.02
[16:50:39] Source:  00800_00000
  - Input BD size: 7.62 GB
  - Approximate total content: [00:30:00.590]
  - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled
  - Mode: MKV Container, 1920x1080, Intact Audio
  - Decoding/Frame serving: DirectShow
  - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640
[16:50:39] PHASE ONE, Encoding
 - [16:50:39] Processing: VID_00000 (1 of 1)
 - [16:50:39] Extracting A/V streams [VID_00000]
 - [16:51:13] Reencoding video [VID_00000]
   - Rate/Length: 23.976fps, 43,171 frames
 - [16:51:14] Reencoding: VID_00000, Pass 1 of 1
 - [16:55:56] Video Encode complete
 - [16:55:56] Processing audio tracks
[16:55:56]PHASE ONE complete
[16:55:56]PHASE TWO - Rebuild Started
 - [16:55:56] Building ALTERNATE OUTPUT Structure
[16:56:12] - Encode and Rebuild complete
[16:56:12] JOB: 00800 finished.
Plays fine in MPC-HC, including skipping through chapters
Old 19th January 2015, 02:39   #22132  |  Link
1Bullet
Having an issue with BD Rebuilder v0.50.02 it think?
I rip my own disc of The Equalizer using DVDFab 9.1.7.1
I will start by saying when I installed BD v0.50.02 id said my set up was not correct and it could correct it. So I let it?
Now running Inspect shows this:
- AVISYNTH Version: 2.5.8.0, not recommended version
- HAALI Splitter: Ok
- FFDSHOW: 4504, not recommended version
- WIN7 preferred AVC CODEC: Ok
- WIN7 preferred VC-1 CODEC: Ok
- WIN7 preferred MPEG2 CODEC: Ok
- FFDSHOW VC-1 set to "wmv9", Ok
- FFDSHOW MPEG2 set to "libavcodec": Ok
- FFDSHOW AVC set to "libavcodec": Ok
- BD-RB vUNKNOWN, not current
I haven't even gone into my issue yet
Just trying to get my set up correct ?
What AVISYNTH version is recommended?
And what about FFDshow ?
And I don't remember BD version ever showing as unknown and not current?
All my issue just might be do to the above setup?
I am experiencing video freezing and video was not touched? Movie only mode converting DTS MA to AC3
[Status]
LABEL=THE_EQUALIZER
VERSION=v0.50.02
SOURCE_SIZE=26777235456
SOURCE_VIDEO_SIZE=26777235456
TARGET_SIZE=25690112000
REDUCTION=.959401206379712
RESIZE_1080=0
RESIZE_1440=0
AUDIO_TO_KEEP=eng;
KEEP_HD_AUDIO=0
SUBS_TO_KEEP=eng;
BACKUP_MODE=1
MOVIEONLY_TYPE=0
USE_LAVF=0
INSTANCES=1
DGDECNV=0
DGDECIM=0
FRIMSOURCE=0
FFMS2=0
SSIF_MODE=0
QUICK=0
ENCODE_STEP=0
COMPLETED=10
REBUILD_COMPLETE=1
[00002]
AUDIO=1
PGS=01
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=275281894
USE_ORIGINAL=1
NSIZE=0
FLINK=-1
MLINK=0
[00003]
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=374505039
USE_ORIGINAL=1
[01/17/15] BD Rebuilder v0.50.02
[18:58:00] Source: THE_EQUALIZER_00000
- Input BD size: 24.94 GB
- Approximate total content: [02:12:02.914]
- Target BD size: 23.93 GB
- MOVIE-ONLY mode enabled
- Auto Quality: Good (Very Fast), ABR
- Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640
[18:58:01] PHASE ONE, Encoding
- [18:58:01] Processing: VID_00002 (1 of 10)
- [18:58:01] Extracting A/V streams [VID_00002]
- [19:12:53] Reencoding video [VID_00002]
- [19:12:53] Keeping original video (no reencode)
- [19:12:53] Processing audio tracks
- Track 4352 (eng): Reencoding audio to AC3...
- [19:18:21] Processing: VID_00003 (2 of 10)
- [19:18:21] Extracting A/V streams [VID_00003]
- [19:18:49] Reencoding video [VID_00003]
- [19:18:49] Keeping original video (no reencode)
- [19:18:49] Processing: VID_00004 (3 of 10)
- [19:18:49] Extracting A/V streams [VID_00004]
- [19:21:07] Reencoding video [VID_00004]
- [19:21:07] Keeping original video (no reencode)
- [19:21:07] Processing: VID_00005 (4 of 10)
- [19:21:07] Extracting A/V streams [VID_00005]
- [19:23:46] Reencoding video [VID_00005]
- [19:23:46] Keeping original video (no reencode)
- [19:23:46] Processing: VID_00006 (5 of 10)
- [19:23:46] Extracting A/V streams [VID_00006]
- [19:28:19] Reencoding video [VID_00006]
- [19:28:19] Keeping original video (no reencode)
- [19:28:19] Processing: VID_00007 (6 of 10)
- [19:28:19] Extracting A/V streams [VID_00007]
- [19:29:55] Reencoding video [VID_00007]
- [19:29:55] Keeping original video (no reencode)
- [19:29:55] Processing: VID_00008 (7 of 10)
- [19:29:55] Extracting A/V streams [VID_00008]
- [19:31:40] Reencoding video [VID_00008]
- [19:31:40] Keeping original video (no reencode)
- [19:31:40] Processing: VID_00009 (8 of 10)
- [19:31:40] Extracting A/V streams [VID_00009]
- [19:37:11] Reencoding video [VID_00009]
- [19:37:11] Keeping original video (no reencode)
- [19:37:11] Processing: VID_00010 (9 of 10)
- [19:37:11] Extracting A/V streams [VID_00010]
- [19:39:58] Reencoding video [VID_00010]
- [19:39:58] Keeping original video (no reencode)
- [19:39:58] Processing: VID_00011 (10 of 10)
- [19:39:58] Extracting A/V streams [VID_00011]
- [19:45:35] Reencoding video [VID_00011]
- [19:45:35] Keeping original video (no reencode)
[19:45:35]PHASE ONE complete
[19:45:35]PHASE TWO - Rebuild Started
- [19:45:35] Rebuilding BD file Structure
[20:11:10] - Encode and Rebuild complete
[20:11:10] JOB: THE_EQUALIZER finished.
The weird part burned Movie to a dual Layer BD 50GB and no freezing. Burned BD single layer after just converting Audio and have the freezing. That why think it a BDRD issue.
1Bullet is offline   Reply With Quote
Old 19th January 2015, 02:54   #22133  |  Link
Ch3vr0n
Which avisynth and ffdshow are recommend? How about the ones that are linked in the very first must?
Verstuurd vanaf mijn Nexus 7 met Tapatalk
Ch3vr0n is offline   Reply With Quote
Old 19th January 2015, 03:42   #22134  |  Link
1Bullet
@ Ch3vr0n if you asking me that's what I am using of front page. Downloading BDRB again just in case mine was a corrupt download.
Old 19th January 2015, 03:47   #22135  |  Link
Lathe
Lathe's Avatar
I think what Ch3vr0n means is that if you look carefully on the first post, you not only download BDRB there, but there are also links for Avisynth and the other things you need. You probably just missed them...
Lathe is offline   Reply With Quote
Old 19th January 2015, 04:01   #22136  |  Link
1Bullet
Nope I have the links off front page Even went further and Downloaded Avisynth 2.6.0 5 its not recommend either? Going back to v258 now and after redownloading BDRB 0.50.02 and reinstalling made no change either
- AVISYNTH Version: 2.6.0.5, not recommended version
Old 19th January 2015, 04:36   #22137  |  Link
jdobbs
Are you sure you're executing the EXE you think you are? It's pretty hard for BD-RB to find the wrong version of itself. You'll need to uninstall AVISYNTH and FFDSHOW first, then then install the versions linked in the first post. Somehow the system isn't seeing the new install.
Old 19th January 2015, 08:01   #22138  |  Link
1Bullet
After I remove the Avisynth 2.6.0.5 and then went back to Avisynth 2.5.8.0 everything straightened out. My original Avisynth 2.5.8.0,must have been corrupted.
Old 19th January 2015, 08:05   #22139  |  Link
Ch3vr0n
We'll there's likely your problem, 2.6.0.5 is not the official recommended version. As such bug reports with unsupported versions are not accepted, to the disc again with the supported versions. If you will have the same problem, then come back.
Old 19th January 2015, 08:19   #22140  |  Link
1Bullet
But if you read my first post I had Version: 2.5.8.0 installed in beginning wasn't looking for help on something not supported.
Won't know if it cause Video to freeze untill I redo again tomorrow.
