12th August 2007, 22:21 | #101 | Link |
Coder
You have to give the video stream number because xport makes the PTS offset from the first video PTS.
xport Transport Stream Demuxer 0.96+ Usage: xport <-pavtdszgh2uj> <infile> <program number> <video stream number> <audio stream number> <subtitle stream number> Options: p = parse only, do not demux to video and audio files a = dump audio PTS v = dump video PTS u = dump subtitle (PGS) PTS t = GOP timecode mode, count repeated fields/frames d = dump all PID's (useful for debugging muxers, but tons of output) s = suppress TS rate dumping (useful when piping output to a file) z = demux to PES streams (instead of elementary streams) g = dump ATSC PSIP information h = input file is in HDMV (AVCHD and Blu-ray) format (192 byte packets) 2 = only extract 2 channels of HDMV LPCM audio from multi-channel tracks j = just demux subtitle stream |
12th August 2007, 22:29 | #102 | Link |
where is 0.96+
i only have 0.96 from his site, i just downloaded a 0.97 version now from his site but that still doesnt have the j option Code:
H:\>xport -hj Z:\GHOST_RIDER_BR\BDMV\STREAM\00066.m2ts 1 1 0 1 xport Transport Stream Demuxer 0.97 Usage: xport <-pavtdszgh2> <infile> <program number> <video stream number> <aud io stream number> Options: p = parse only, do not demux to video and audio files a = dump audio PTS v = dump video PTS t = GOP timecode mode, count repeated fields/frames d = dump all PID's (useful for debugging muxers, but tons of output) s = suppress TS rate dumping (useful when piping output to a file) z = demux to PES streams (instead of elementary streams) g = dump ATSC PSIP information h = input file is in HDMV (AVCHD and Blu-ray) format (192 byte packets) 2 = only extract 2 channels of HDMV LPCM audio from multi-channel tracks Last edited by woah!; 12th August 2007 at 22:37. |
12th August 2007, 22:41 | #103 | Link |
Coder
You can download from my page:
http://pel.hu/down/xportsup096+.zip |
12th August 2007, 23:00 | #104 | Link |
yep there is a problem with tsremux demux by the look of it. heres the 1st sub info using xport:
00000002: PTS=004B7DF2 (00:00:54,972) 0000000A: PCS (13) state: 2 0000002A: WDS1 (0A) id: 0 [674,876] - [1254,1025] 00000041: PDS (142) 64 palettes 00000190: ODS (6931) 580 x 149 00006ACE: END 00006AD3: PTS=005012FE (00:00:58,308) 00006ADB: PCS (0B) state: 0 00006AF3: WDS1 (0A) id: 0 [674,876] - [1254,1025] 00006B0A: END 54secs start will see if i can author it and will let you know. thx |
12th August 2007, 23:26 | #109 | Link |
Pelican9, seems there is still a bug in processing the Face/Off subtitles.
Line 19 of the bitmap shows corruption in the image - seems two lines on that screen are running into each other and also combing! anyways, thanks for this new version... |
12th August 2007, 23:32 | #110 | Link |
well i think tsremux needs to use the video stream aswell when extracting the sub, i tried in xport with no video/audio picked and it output the same timings as tsremux did before. with the video/audio streams 1 1 1 1 in xport it then gave me the correct timings.
12th August 2007, 23:40 | #111 | Link | |
Coder
What was the file name (if yes)? Edit: I've just found it. Strange. Didn't I fix this bug at around version 0.4? I'll try to fix it again tomorrow. Last edited by Pelican9; 13th August 2007 at 00:08. |
13th August 2007, 08:22 | #112 | Link |
Embedded Coder
Pelican9:
Thanks for help. I think "bits0001.sup" is subtitle file and does not contain any Presentation Graphics Stream PGS. I wish to have PGS sample stream. It will be nice if some one can provide it. Thanks, Ahmguy. Addition : May be I was wrong. [/off] I am vary much new to subtitle and PGS. I was trying to compare stream with doc and it did not work.[/off] Thanks, Viral Last edited by ahmguy; 13th August 2007 at 08:45. |
13th August 2007, 17:56 | #113 | Link | |
Coder
Read this and the HD subtitle ripping thread and you can find the structure of the sup file. And please do not ask PGS again and again and again. |
14th August 2007, 11:43 | #114 | Link | |
Embedded Coder
Sorry if u felt, I ask u too many times. |
15th August 2007, 21:41 | #115 | Link |
Hello,
I'm trying to rip a BD movie. And I've finally gotten the right subtitle stream. Through xsport. The only problem remaining is, that the imagesubs aren't OCR'd that great. This is a result I get: Code:
·· ··: :· ··· ·:·· :·-·:···, ?····· ··· :····. Is there any way to fix that? The OCR method of Subrip is easier, you put in the letters one by one, for the ones he doesn't know. And eventually it will OCR without me typing. Another 'error' I have, is that the timing is doubled, it is correct. But this is the beginning of my srt file: Code:
1 00:00:56,431 --> 00:00:57,431 Was any of this for good or bad? I really couldn't say. 2 00:00:57,432 --> 00:00:58,432 Was any of this for good or bad? I really couldn't say. 3 00:00:58,433 --> 00:00:59,433 Was any of this for good or bad? I really couldn't say. 4 00:00:59,434 --> 00:01:00,434 Was any of this for good or bad? I really couldn't say. 5 00:01:00,435 --> 00:01:01,435 Was any of this for good or bad? I really couldn't say. 6 00:01:01,436 --> 00:01:01,687 Was any of this for good or bad? I really couldn't say. 7 00:01:02,771 --> 00:01:03,771 But like most people, I guess... Is there any way to fix that? Except for manual editing that is... Thanks in advance. |
16th August 2007, 20:45 | #117 | Link | |
I can't connect to his website! Thanks alot in advance! |
16th August 2007, 23:54 | #119 | Link |
Thanks a bunch!
Let me take this opportunity to thank you also for your devotion in making such applications as EVOdemux! If it weren't for guys like you and drmpeg, guys like me would be helpless in setting the first steps in exploring high definition content. So again: thank you very much for all of your work! |
17th August 2007, 00:17 | #120 | Link |
OK, you can get it here:
http://files-upload.com/files/439799/bits0001.rar Please let me know what you can do with it. |
