29th July 2017, 20:59 | #22021 | Link |
LAV just decodes the video to its native resolution, anything that happens beyond that is not quite related to LAV Video.
30th July 2017, 10:38 | #22022 | Link | |
Juste a waste of GPU power when applying it to video playback IMHO.
HTPC: Windows 10 22H2, MediaPortal 1, LAV Filters/ReClock/madVR. DVB-C TV, Panasonic GT60, Denon 2310, Core 2 Duo E7400 oc'd, GeForce 1050 Ti 536.40 |
31st July 2017, 22:29 | #22024 | Link |
How mpc-hc builds their copy of LAV is unrelated to what I do. But I still have no plans to apply any such hacks, and as stated before LAV will quite likely also drop XP support in the next release.
31st July 2017, 23:02 | #22025 | Link |
MPC-HC doesn't support WinXP anymore, so their version of LAVFilters doesn't support it too.
https://github.com/mpc-hc/mpc-hc/com...185719814dbaf3 |
31st July 2017, 23:28 | #22026 | Link |
nevcairiel, I still hope you'll change your opinion and will implement h265 10bit 'hack' in your LAV Filters before you drop XP support and I (and many other SAT amateurs who use WinXP with GM206-based videocards) will use that last pre-release version of LAV Filters and will remember you with good words
1st August 2017, 02:15 | #22029 | Link | ||
Windows 7 Ultimate 64-bit MPC-BE.1.5.1.2745.x64 madVR v0.91.11 LAVFilters-0.70.2-7 NVIDIA 385.12 Trying to play this file using DXVA2 (copy-back) results in dropped frames and presentation glitches in madVR. Works fine with NVIDIA CUVID. Quote:
1st August 2017, 04:10 | #22030 | Link |
@nevcairiel
Just see it as a last minute favor, before abandoning for good WinXP support, for all these people with poor incomes or great peculiarity who insist on that OS. If it's not a great deal of work for you, it will be the last time involving with that Windows version.
Win 10 x64 (19042.572) - Core i5-2400 - Radeon RX 470 (20.10.1) HEVC decoding benchmarks H.264 DXVA Benchmarks for all |
1st August 2017, 07:23 | #22032 | Link |
That should hopefully be resolved.
1st August 2017, 09:17 | #22033 | Link | |
If say more exact - people (mostly SAT amateurs) that don't want spend any extra money (for newer then WinXP version of Windows -> Hardware -> unlimited Internet -> Antivirus ->... -> World)) to achieve great results (if it's achievable at all) - Aleksoid1978 proves that h265 10bit hardware acceleration via CUVID works quite well in WinXP with this https://github.com/Nevcairiel/LAVFilters/issues/145 patch code and he hasn't WinXP and GM206-based videocard as clsid too). So most of work was done.
May be you're right but I'm sure nevcairiel (if he'll wish) will workable implement that code from the first time. Quote:
Besides, nevcairiel has implemented h265 10bit hardware acceleration via CUVID and switching off DXVA processing (to remove artifacts on some streams) for Win7 and newer I'm talking about in last year but don't want implement for WinXP - it's not logical on my own. Last edited by VictorLS; 1st August 2017 at 09:24. |
6th August 2017, 05:43 | #22035 | Link |
https://www.sendspace.com/file/dibo8i
blackscreen |
6th August 2017, 16:10 | #22036 | Link |
That file seems broken:
[hevc @ 00000000004a3080] Overread SPS by 8 bits [hevc @ 00000000004a3080] SPS 0 does not exist. [hevc @ 00000000004a3080] Overread SPS by 8 bits [hevc @ 00000000004a3080] SPS 0 does not exist. [hevc @ 00000000004a3080] PPS id out of range: 0 [hevc @ 00000000004a3080] Error parsing NAL unit #3. [hevc @ 00000000004a3080] PPS id out of range: 0 [hevc @ 00000000004a3080] Error parsing NAL unit #0. ... |
7th August 2017, 15:02 | #22037 | Link | |
http://forum.doom9.org/showthread.ph...35#post1814235 I thought it was an issue after updating the nvidia drivers. |
7th August 2017, 17:16 | #22038 | Link |
This issue was not related to drivers and has already been resolved in more recent versions of LAV.
8th August 2017, 08:03 | #22040 | Link | |
Was watching GOT last night and that small freeze happened again. But it was much shorter than before. About 1 or 2 seconds instead of 4 or 5 seconds like before. - Windows 10 x64 v10.0.15063 - nVidia v385.12 - MPC-BE (64-bit) v1.5.1 (build 2363) - madVR v0.91.11 [fullscreen exclusive mode, 1080p @23.976hz] - LAV v0.70.2.12 [DVXA2 (copy-back)] [10-bit P010] Tried with NVIDIA CUVID and didn't see that small freeze. Last edited by FDisk80; 8th August 2017 at 08:20. |
