Old 10th March 2011, 15:59   #2061  |  Link
Skinleech
A.K.A Mangoat
FYI, anyone who is still struggling with bitstreaming DTS-HD MA with Haali, it's easily fixed.
Open Mkvmerge Gui & select Header Editor from the File menu. Open your mkv, and under default duration for the audio track(s) Add Element and enter 10666666. Save the header and you're done. I've done a bunch of my files and they all work fine in Haali now.
I stumbled upon this on a random forum last week (can't recall where now) so it may be old news already.
Skinleech is offline   Reply With Quote
Old 10th March 2011, 16:05   #2062  |  Link
SamuriHL
SamuriHL's Avatar
It is. I think Mosu made a change in mkvmerge to fix it automagically.
Old 10th March 2011, 16:13   #2063  |  Link
robpdotcom
The change in mmg only fixes new files though - to fix one made before the change, the header editor is MUCH faster than remuxing.
BTW: I've had a few THD files that play out of sync with Haali. Adding 833333 to the default duration seemed to fix those.
Originally Posted by SamuriHL View Post
automagically.
BTW2: Typo, or play on words?
Windows 7 x64
i7 870
16GB RAM
AMD 6870
robpdotcom is offline   Reply With Quote
Old 10th March 2011, 16:20   #2064  |  Link
SamuriHL
SamuriHL's Avatar
Ah, yes, you're right, of course.
Hmm, hadn't seen that one. Neat!
No typo. I use that word a lot. I'm a software engineer, so, a lot of what I do is magic.
Old 10th March 2011, 23:06   #2065  |  Link
Skinleech
A.K.A Mangoat
Ah, seems I'm .3 versions out of the latest, so yeah I guess it's fixed. I stopped caring as I stopped using Haali but when I saw the fix thought I'd try.
Guess I should update mmg
Old 10th March 2011, 23:08   #2066  |  Link
SamuriHL
SamuriHL's Avatar
I haven't been using haali lately either. LAVF has gotten to a point now where I find it quite usable. And we know where to find Nev if it breaks. Anyway, yea, you should upgrade mmg.
Old 11th March 2011, 00:47   #2067  |  Link
robpdotcom
The only reason I use Haali is because I started backing up seamless branching BluRays with ordered chapter mkv's - and so far, only Haali will play them correctly.
Other than that, LAVF is my new splitter of choice.
Windows 7 x64
i7 870
16GB RAM
AMD 6870
Old 11th March 2011, 00:49   #2068  |  Link
SamuriHL
SamuriHL's Avatar
Maybe Nev will add support for that. He wants to work on BD support next I think. You can always ask.
Old 11th March 2011, 03:01   #2069  |  Link
robpdotcom
I've mentioned it, and I think he said it's low on the priority list. Understandably so, since I don't hear of many other users messing around with ordered chapters. Although, from what I've read, it does seem to be catching on in the Anime/torrent world.
I think when someone starts to work on menus for Matrsoska people will start to utilize the ordered chapters a bit more. Imagine being able to back up an entire Bluray such as Avatar, with the director's cut, extended, and theatrical version, and have full menu support - all in one mkv file that is much smaller than what would be needed if you saved each version separately. Imo, that should be one of the ultimate goals.
Anyway, don't want to drive this topic any further off topic.
And btw, thanks for my new favorite word: Automagically
Windows 7 x64
i7 870
16GB RAM
AMD 6870
Old 29th March 2011, 09:33   #2070  |  Link
ontherocks
Originally Posted by albain View Post
What needs to be fixed or improved :
- Dolby Digital Plus bitstream on ATI 5xxx : this is likely due to a driver issue (ATI drivers don't support DD+ yet)
Any updates on this?
ATI Catalyst version 10 and above, does support bitstreaming Dolby Digital Plus. Have successfully tested it with Splash Player Pro.
ontherocks is offline   Reply With Quote
Old 29th March 2011, 13:39   #2071  |  Link
SamuriHL
SamuriHL's Avatar
I haven't seen ANY player that is able to bitstream DD+ on an AMD card, regardless of what the driver claims to support. IMO, it lies. You're absolutely positive you're getting DD+ with SPP?
Old 6th April 2011, 21:26   #2072  |  Link
Andy o
Just installed the trial of SP Pro, and no workie. TrueHD yes, DD+ no. From m2ts from the Dolby demo bluray. 5770 with both Realtek 2.55 and the one that comes with Cat 11.3
Andy o is offline   Reply With Quote
Old 6th April 2011, 21:38   #2073  |  Link
SamuriHL
SamuriHL's Avatar
Yea I haven't seen any REAL reports of DD+ working on an AMD card. I've seen PDVD's unique bug where it displays DD+ but it's not really.
Old 6th April 2011, 21:42   #2074  |  Link
Andy o
Well luckily no REAL blu-rays have DD+!
Old 6th April 2011, 21:48   #2075  |  Link
SamuriHL
SamuriHL's Avatar
Not so lucky is that the broadcast industry is moving to the DD+ standard "someday".
Old 6th April 2011, 21:51   #2076  |  Link
Andy o
Yeah, but unless they support 7.1, I don't think I'll mind just doing regular DD.
Old 6th April 2011, 21:54   #2077  |  Link
SamuriHL
SamuriHL's Avatar
That's an interesting question. I don't know what the plans are for their rollout of DD+. I suspect they'll want it for VOD and that type of stuff. Netflix and Vudu are already doing DD+ but I'm not sure about 7.1.
Old 6th April 2011, 22:00   #2078  |  Link
Andy o
Do you know any Netflix movies that have DD+? I haven't run into any and I wanna check it out.
I don't watch movies on NF instant though... quality sucks sucks sucks. Especially those starz movies.
Old 6th April 2011, 22:02   #2079  |  Link
dbone1026
I am having issues with my 5670 GPU.... oh wait, sorry, saw you guys and I thought this was the 'ATI HD 5000 Series Known Problems' thread on AVS
Cheers,
Damian
Blog - http://www.adigitalhomeblog.com
MSS.net blog (contributing editor) - http://www.mediasmartserver.net
dbone1026 is offline   Reply With Quote
Old 6th April 2011, 22:06   #2080  |  Link
SamuriHL
SamuriHL's Avatar
These were instant view. And through my PS3 the quality is good good good. But NOT the same on the 360 or PC streaming. Whatever they're doing on the PS3 client the quality is much higher than anywhere else. I can look later if I have time and try to find one that has DD+.
