25th June 2010, 17:45 | #8141 | Link |
I know it's there
"Attachments Pending Approval" (which means it can't be opened until it's approved) I just don't understand why you'd put it in a word doc photo attachments may not require approval....or microsoft office but you'd just want to upload to an image hosting site anyways |
25th June 2010, 17:45 | #8142 | Link | |
25th June 2010, 19:57 | #8143 | Link | |
I re-encoded a movie last night using the 100% option. It still too low for my likening. I compared it to another encode of the same movie I did with the latest [spam]. It has by default the AAC audio encode set to 125%. Would you mind considering allowing th euser of your GUI to be able to adjust the audio boost level? (rename it from normalize to audio boost) TIA Last edited by Guest; 25th June 2010 at 21:16. Reason: 5 |
27th June 2010, 07:22 | #8144 | Link |
OK, just installed RB on my new Win 7 64bit machine. When I add an MKV and the streams are demuxed, the correct length and frames are reported. Whem the encode starts, only the first 7000 or so frames are encoded. I've tried 2 or 3 MKVs with the same results. Any ideas?!
G:\>"C:\Program Files (x86)\RipBot264v1.16.1\tools\bepipe\bepipe.exe" --script "import(^G:\temp\RipBot264temp\job1\job1.avs^)" | "C:\Program Files (x86)\RipBot264v1.16.1\Tools\enc_aacPlus\enc_aacPlus.exe" - "G:\temp\RipBot264temp\audio.aac" --lc --br 327680 --mpeg4aac *************************************** BePipe by dimzon *************************************** Script used: # BEGIN import("G:\temp\RipBot264temp\job1\job1.avs") # END Scanning for Audio Stream... Found Audio Stream Channels=6, BitsPerSample=16, SampleRate=48000Hz Writing Header... Writing Data... 0% Done! ******************************************************************** * AACPlus v2 Encoder (using Winamp enc_aacplus.dll and nscrt.dll) * Coding Technologies encoder 8.0.3 * Build Oct 10 2009, 16:03:17 ******************************************************************** Input file: - Output file: G:\temp\RipBot264temp\audio.aac SampleRate: 48000 ChannelCount: 6 BitsPerSample: 16 Bitrate: 320000 ChannelMode: Multichannel Engine: LC-AAC Tune For Speech: No PNS: No MP4 Output: No Encoding... Finalizing... Done G:\>"C:\Program Files (x86)\RipBot264v1.16.1\tools\avs2yuv\pipebuf.exe" "C:\Program Files (x86)\RipBot264v1.16.1\tools\avs2yuv\avs2yuv.exe" "G:\temp\RipBot264temp\job1\job1.avs" - : "C:\Program Files (x86)\RipBot264v1.16.1\tools\x264\x264_x64.exe" --pass 1 --bitrate 235932 --stats "G:\temp\RipBot264temp\job1\job1.stats" --fps 24000/1001 --force-cfr --min-keyint 24 --keyint 240 --frames 6938 --sar 1:1 --level 4.0 --aud --nal-hrd vbr --vbv-bufsize 25000 --vbv-maxrate 25000 --filter 0,0 --ref 3 --bframes 3 --b-adapt 1 --b-pyramid none --subme 7 --aq-mode 1 --trellis 1 --partitions all --me umh --stdin y4m --output "G:\temp\RipBot264temp\video.264" - : 2 y4m [info]: 1920x1080p 1:1 @ 10000000/417083 fps (cfr) x264 [warning]: max bitrate less than average bitrate, assuming CBR x264 [info]: using SAR=1/1 x264 [warning]: VBV bitrate (235932) > level limit (20000) x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 FastShuffle SSE4.2 x264 [info]: profile Main, level 4.0 G:\temp\RipBot264temp\job1\job1.avs: 1920x1080, 10000000/417083 fps, 6938 frames x264 [info]: frame I:78 Avg QP:10.25 size:420331 x264 [info]: frame P:4114 Avg QP:10.33 size:402686 x264 [info]: frame B:2746 Avg QP:10.72 size:275529 x264 [info]: consecutive B-frames: 31.8% 41.0% 10.5% 16.7% x264 [info]: mb I I16..4: 41.5% 0.0% 58.5% x264 [info]: mb P I16..4: 44.2% 0.0% 0.0% P16..4: 26.1% 0.0% 0.0% 0.0% 0.0% skip:29.8% x264 [info]: mb B I16..4: 13.6% 0.0% 0.0% B16..8: 39.6% 0.0% 0.0% direct:11.4% skip:35.4% L0:20.6% L1:22.2% BI:57.2% x264 [info]: coded y,uvDC,uvAC intra: 92.4% 85.5% 74.9% inter: 46.8% 38.8% 24.3% x264 [info]: i16 v,h,dc,p: 11% 8% 57% 24% x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 12% 16% 23% 5% 13% 6% 8% 6% 10% x264 [info]: i8c dc,h,v,p: 56% 20% 15% 9% x264 [info]: Weighted P-Frames: Y:0.8% x264 [info]: kb/s:67623.28 encoded 6938 frames, 40.10 fps, 67623.28 kb/s G:\>"C:\Program Files (x86)\RipBot264v1.16.1\tools\avs2yuv\pipebuf.exe" "C:\Program Files (x86)\RipBot264v1.16.1\tools\avs2yuv\avs2yuv.exe" "G:\temp\RipBot264temp\job1\job1.avs" - : "C:\Program Files (x86)\RipBot264v1.16.1\tools\x264\x264_x64.exe" --pass 2 --bitrate 235932 --stats "G:\temp\RipBot264temp\job1\job1.stats" --fps 24000/1001 --force-cfr --min-keyint 24 --keyint 240 --frames 6938 --sar 1:1 --level 4.0 --aud --nal-hrd vbr --vbv-bufsize 25000 --vbv-maxrate 25000 --filter 0,0 --ref 3 --bframes 3 --b-adapt 1 --b-pyramid none --subme 7 --aq-mode 1 --trellis 1 --partitions all --me umh --stdin y4m --output "G:\temp\RipBot264temp\video.264" - : 2 y4m [info]: 1920x1080p 1:1 @ 10000000/417083 fps (cfr) x264 [warning]: max bitrate less than average bitrate, assuming CBR x264 [info]: using SAR=1/1 x264 [warning]: VBV bitrate (235932) > level limit (25000) x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 FastShuffle SSE4.2 x264 [warning]: target: 235932.00 kbit/s, expected: 67628.47 kbit/s, avg QP: 10.0000 x264 [warning]: try reducing target bitrate or reducing qp_min (currently 10) x264 [info]: profile High, level 4.0 G:\temp\RipBot264temp\job1\job1.avs: 1920x1080, 10000000/417083 fps, 6938 frames x264 [info]: frame I:78 Avg QP:10.26 size:360239 x264 [info]: frame P:4114 Avg QP:10.34 size:362305 x264 [info]: frame B:2746 Avg QP:10.67 size:251862 x264 [info]: consecutive B-frames: 31.8% 41.0% 10.5% 16.7% x264 [info]: mb I I16..4: 29.7% 56.7% 13.6% x264 [info]: mb P I16..4: 4.3% 34.5% 9.0% P16..4: 10.0% 8.0% 2.9% 0.7% 0.5% skip:30.0% x264 [info]: mb B I16..4: 0.9% 8.3% 4.4% B16..8: 21.3% 13.7% 7.6% direct: 7.1% skip:36.6% L0:37.9% L1:29.6% BI:32.6% x264 [info]: 8x8 transform intra:70.0% inter:46.0% x264 [info]: coded y,uvDC,uvAC intra: 93.6% 89.7% 81.2% inter: 40.1% 35.5% 22.6% x264 [info]: i16 v,h,dc,p: 31% 10% 30% 28% x264 [info]: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 8% 10% 39% 7% 8% 7% 8% 7% 8% x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 10% 14% 22% 9% 10% 8% 9% 8% 10% x264 [info]: i8c dc,h,v,p: 54% 20% 15% 10% x264 [info]: Weighted P-Frames: Y:0.8% x264 [info]: ref P L0: 58.0% 13.1% 20.7% 8.2% 0.1% x264 [info]: ref B L0: 83.0% 17.0% x264 [info]: kb/s:61104.27 encoded 6938 frames, 9.09 fps, 61104.27 kb/s G:\>"C:\Program Files (x86)\RipBot264v1.16.1\tools\mp4box\mp4box.exe" -tmp "G:\temp\RipBot264temp" -add "G:\temp\RipBot264temp\video.264":name="Coll" -fps 23.976 -add "G:\temp\RipBot264temp\audio.aac":lang=eng -mpeg4 -new "G:\Coll.mp4" AVC-H264 import - frame size 1920 x 1080 at 23.976 FPS Import results: 6938 samples - Slices: 78 I 4114 P 2746 B - 7012 SEI - 73 IDR AAC import - sample rate 48000 - MPEG-4 audio - 6 channels Saving G:\Coll.mp4: 0.500 secs Interleaving ------------------------- Elapsed Time: 00h:16m:54s Last edited by rendez2k; 27th June 2010 at 09:40. |
27th June 2010, 10:19 | #8145 | Link | |
What's audio duration reported in ripbot
BTW. What is this??? Quote:
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 27th June 2010 at 10:34. |
27th June 2010, 10:41 | #8146 | Link |
OK, I re-installed RB in case there was an issue. I then re-added the MKV as I didn't notice the audio length before. Audio is correctly being reported. But now, it just sits there initializing and not starting the encode!
As for the bitrate, I've no idea. All I told RB to do is a 2-pass encode, fit to HD res and DL DVD size. Edit: OK, looks like the initaliaztion issue is due to me changing the output path or the location of RipBot? Does it store settings in the registry? G:\>"C:\Program Files (x86)\RipBot\tools\bepipe\bepipe.exe" --script "import(^G:\temp\RipBot264temp\job1\job1.avs^)" | "C:\Program Files (x86)\RipBot\Tools\enc_aacPlus\enc_aacPlus.exe" - "G:\temp\RipBot264temp\audio.aac" --lc --br 327680 --mpeg4aac The system cannot find the path specified. G:\>"C:\Program Files (x86)\RipBot\tools\avs2yuv\pipebuf.exe" "C:\Program Files (x86)\RipBot\tools\avs2yuv\avs2yuv.exe" "G:\temp\RipBot264temp\job1\job1.avs" - : "C:\Program Files (x86)\RipBot\tools\x264\x264_x64.exe" --pass 1 --bitrate 9173 --stats "G:\temp\RipBot264temp\job1\job1.stats" --fps 24000/1001 --force-cfr --min-keyint 24 --keyint 240 --frames 172535 --sar 1:1 --level 4.0 --aud --nal-hrd vbr --vbv-bufsize 25000 --vbv-maxrate 25000 --filter 0,0 --ref 3 --bframes 3 --b-adapt 1 --b-pyramid none --subme 7 --aq-mode 1 --trellis 1 --partitions all --me umh --stdin y4m --output "G:\temp\RipBot264temp\video.264" - : 2 The system cannot find the path specified. G:\>"C:\Program Files (x86)\RipBot\tools\avs2yuv\pipebuf.exe" "C:\Program Files (x86)\RipBot\tools\avs2yuv\avs2yuv.exe" "G:\temp\RipBot264temp\job1\job1.avs" - : "C:\Program Files (x86)\RipBot\tools\x264\x264_x64.exe" --pass 2 --bitrate 9173 --stats "G:\temp\RipBot264temp\job1\job1.stats" --fps 24000/1001 --force-cfr --min-keyint 24 --keyint 240 --frames 172535 --sar 1:1 --level 4.0 --aud --nal-hrd vbr --vbv-bufsize 25000 --vbv-maxrate 25000 --filter 0,0 --ref 3 --bframes 3 --b-adapt 1 --b-pyramid none --subme 7 --aq-mode 1 --trellis 1 --partitions all --me umh --stdin y4m --output "G:\temp\RipBot264temp\video.264" - : 2 The system cannot find the path specified. G:\>"C:\Program Files (x86)\RipBot\tools\mp4box\mp4box.exe" -tmp "G:\temp\RipBot264temp" -add "G:\temp\RipBot264temp\video.264":name="Coll" -fps 23.976 -add "G:\temp\RipBot264temp\audio.aac":lang=fre -mpeg4 -new "G:\Coll.mp4" The system cannot find the path specified. ------------------------- Elapsed Time: 00h:00m:00s Last edited by rendez2k; 27th June 2010 at 10:53. |
28th June 2010, 23:29 | #8147 | Link |
I tried to convert anime with Ripbot and it still does not work.
1-- Ive tried editing the script to 23.976 like you told me to it didn't work. 2-- Decimate it didn't work. 3-- Assume FPS it didn't work. 4-- Inverse Telecine it didn't work. 5-- Convert FPS it didn't work. Would you mind encoding it! Sample http://www.mediafire.com/download.php?knqojyzmzmy Rip http://www.mediafire.com/download.php?nmynzmewljq |
28th June 2010, 23:58 | #8148 | Link |
video=DirectShowSource("C:\Users\Dawid\Desktop\NS93_[SAMPLE].mkv",audio=false,convertfps=true).ConvertToYV12()
29th June 2010, 00:31 | #8150 | Link |
http://www.mediafire.com/file/mmfwdz1zmyg/NS93_[SAMPLE].mp4
29th June 2010, 00:53 | #8151 | Link | |
29th June 2010, 01:11 | #8152 | Link |
why don't you encode yourself? I just added convertfps=true so you can do the same.
29th June 2010, 01:16 | #8153 | Link | |
Do you want me to upload the modified script and the encode!! Last edited by fAy01; 29th June 2010 at 10:38. |
29th June 2010, 14:49 | #8154 | Link |
i searched this thread, and saw versions of this question asked, but never found a solid answer. is it possible to encode to 720p without black bars?
i notice the black bars on fixed on the outputted file, making it exactly 1280x720. what if you don't want black bars at all? for example, i was converting a 1080p movie rip that i calculated to be a 1280x544 image (without black bars) when 720p. i selected the high profile (4.0) then under properties i go to "do not crop" and "size = custom (x,xx:1)" and i input 1280x544. the resulting file just squishes the picture and makes the black bars larger, instead of just encoding the video stream itself down to 1280x544, without black bars. what am i doing wrong? does ripbot add the black bars just to make it easier to encode for the user as i've read in previous posts, or is there some benefit to the monitor/screen to have it perfectly 1280x720 already? i just know if i'm watching something in windowed mode on my laptop, i'd rather not have the black bars, they take up extra space that's unnecessary. side question: ripbot 1.16.0 & 1.16.1 won't take my demuxed .264 video files, nothing happens when i load them, i have to use 1.15.1 to encode HD stuff, but 1.16.0&1 take my .vob files just fine. any ideas? |
29th June 2010, 15:07 | #8155 | Link |
Crop borders and then select custom (2.35:1)
29th June 2010, 18:31 | #8157 | Link | |
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 29th June 2010 at 18:47. |
29th June 2010, 22:21 | #8159 | Link | |
Check your job's AVS file, and see whether it contains something like: Code:
LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\VSFilter\VSFilter.dll") video=TextSub(video,"C:\video\mysub.ass") Code:
LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\SupTitle.dll") video=FFVideoSource("M:\jobs\akira.mkv").ConvertToYV12() video=SupTitle(video, "M:\jobs\akira_exp.sup", forcedOnly=false, swapCbCr=false, relocate=true, relocOffset="0,0,0,0") return video
Gorgeous, delicious, deculture! |
