1st February 2003, 04:23 | #62 | Link |
Old fart
Just wanted to report that I got avisynth 2.5 to encode fine after some growing pains, but I am having major sync issues that creating the video the exact same way with 2.07 didn't happen to. I did this by hand and not using DVD2SVCD. This was for a DVD->DVD conversion.
Here is my avs file: LoadPlugin("C:\PROGRA~1\DVD2SVCD\MPEG2Dec\MPEGDecoder.dll") MPEGSource("g:\bourne.d2v") AddAudio() ConvertToYUY2() The d2v file I created using Forced Film with DVD2AVI 1.76. I used the exact same one with the exact same settings with both versions of the avisynth in CCE 2.5 and used Scenerist to author. Mark
Oh no Mr. Bill! |
1st February 2003, 17:07 | #64 | Link | |
miau
Thanks
"... but where are those missing pieces of eternal soul, I can feel them but I can't reach them with my vision" Petition for a software patent free Europe Another vision of what happened at 9/11
1st February 2003, 20:26 | #66 | Link |
miau
Thanks for clarifying that for me
1st February 2003, 23:38 | #67 | Link | |
Old fart
When I have time I will try the other dll instead. Mark
Oh no Mr. Bill! |
2nd February 2003, 12:32 | #70 | Link | |
Piper at theGates of Dawn
I'm using WinXP Pro SP1, and newest versions of everything (just downloaded from sourceforge a few minutes ago)
"Under a government which imprisons unjustly, the true place for a just man is also a prison" Henry David Thoreau, On the duty of civil disobedience, 1849 Last edited by theReal; 2nd February 2003 at 12:38. |
3rd February 2003, 06:27 | #72 | Link |
Old fart
I switched to using mpeg2dec3.dll instead of the mpegdecoder.dll and not only do I see a bit of a speed improvement my first tests are in sync. I have only done one full length movie and a couple of tests, but so far so good.
I have not been using this in DVD2SVCD. I have been doing it by hand. Once I am satisfied it's stable and works well outside I will try an encode with DVD2SVCD to see if I can get it to work. Mark
Oh no Mr. Bill! |
3rd February 2003, 11:17 | #73 | Link | |
avisource(clip.avi).converttoyv12 # results in a green clip avisource(clip.avi).converttoyuy2.converttoyv12 # doesn't result in a green clip The clip can be found here: http://www.geocities.com/wilbertdijkhof/clip_asv.zip |
8th February 2003, 19:30 | #74 | Link |
I'm a bit new to AviSynth but I have been having success with 2.07. I've been using 2.07 on my test machine with no issues then I uninstalled 2.07 and installed 2.50 and all the plugins from the zip file. Using the same AVS file I started to receive the error "This application has failed to start because MSVCRTD.dll was not found. Re-installing the application may fix his problem"
I found this thread when I searched for the error and as stated I deleted imagesequence.dll. Now when opening the AVS file in CCE, CCE just closes with no error. Any idea why it is doing this? PC Specs and AVS file: P4 1.8ghz 384mb Ram WinXP pro SP1 CCE 2.5 AviSynth 2.5 LoadPlugin("C:\WINDOWS\System32\mpeg2dec3.dll") Mpeg2Source("mr_deeds.d2v") Convolution3d (preset="movieHQ") ResampleAudio(44100) d2v file created with DVD2AVI 1.76 with ForcedFilm on. |
8th February 2003, 20:22 | #75 | Link |
I think that mpeg2dec3.dll creates yv12 output which is no problem for avisynth 2.5, but it is a problem for CCE.
Write "converttoyuy2()" at the end of your script. If this doesn't fix your problem, then you're having the same problem as me. CCE 2.5 just won't load any of my avisynth 2.5.0 beta files, I don't know why - tmpeg doesn't have any problems (only if the output is YUY2, of course). btw. I have similar specs (WinXP pro SP1, CCE 2.5, AviSynth 2.5)
"Under a government which imprisons unjustly, the true place for a just man is also a prison" Henry David Thoreau, On the duty of civil disobedience, 1849 |
11th February 2003, 01:30 | #77 | Link |
Ok after adding "addaudio()" I am now able to use CCE. Now I'm having sync issues and the video is choppy. I've tried CCE 2.5 and I downloaded and installed CCE 2.66 trial veraion to test. Using the same d2v (forced film) with vfapi it works fine. Below is my AVS file.
LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\mpeg2dec3.dll") Mpeg2Source("VTS__01_P01_1.d2v") Convolution3d (preset="moviehQ") ConvertToYUY2() addaudio() |
