20th October 2004, 01:54 | #61 | Link |
Junior Member, Optimized!
Zeul, i just finished the multi-episode DVD that i was having menu button problems before, and it is perfect. excellent work once again.
now on to a new hope...
try Turd_Ferguson for broadband... for the internet you hoped you'd never smell. |
20th October 2004, 08:14 | #63 | Link |
Dutch strain
so far positive results over here
What can I do to protect myself against the flu? By far, the single best way to prevent the flu is for individuals, especially persons at high risk for serious complications from the flu, to get a flu shot each fall. |
20th October 2004, 21:19 | #64 | Link |
Hi Zeul,
i'm trying to do sex and the city season 3 disc 1 R2, but numenu4u rc2 b4 crashes while building the scenarist script (as did b2 and b3) it is a multi episode disc with two vts for the menus. happens with every possible combination of the two. Code:
Procedure Name: CheckAudioSource Module Name: AssetProcess Error Number: 53 Error Description: File not found Error Source: Project1 Error Line: 22 Call Stack: CheckAudioSource --> AssetProcess NewGenerateTrackData --> Scenarist_Build CreateSCP --> Scenarist_Build StartNuMenu4u --> ExecuteProgram go_Click --> MainForm tell me if/which files you need. i really appreciate the hard work you are putting into this program, thank you muppets |
21st October 2004, 07:42 | #66 | Link |
@muppets
i had a very similar problem. it resulted from bad or missing registry keys of dvd decrypter. i did a windows re-installion before and this was one of the tools i thought i had re-installed too but i did not - only the folder remained and the registry keys where gone. maybe u have a similar problem. took me a while to find out because everything seemed to be okay. does it always happen - i mean - on every dvd? also check if the other tools needed are in place. im no expert - just a user. htis solved the error 53 for me. _argos |
21st October 2004, 23:45 | #67 | Link |
20/10/04
CCE is now processed in batches of 50 not 75 - CCE would on occasion complain of unsupported frame size or avifileinfo error NTSC_FILM is now derived from the log file instead of internal computations Change to the internal routines for support of multiple bmps per cell fix: if there was > 1 bmp per cell the first bmp did not always have the correct end time / duration fix: if the palette needed to be replaced in the ifo becuase of multiple cell use, then only the video_ts.ifo would have been fixed HMMMM, Actually remembered to include the zipping dll this time! May account for the strange results Found the problem which was resulting in no VOB file in the SUB folder or the audio not being processed. enjoy Zeul |
22nd October 2004, 00:02 | #68 | Link |
wow!
logged on to post about the amazing success i have had with RC2 Build 4 and you go one better tested RC4 on a real problem menu - house of 1000 corpses - and it worked like a dream thankyou zeul for your continual support and improvement of NuMenu4U. you are a legend. rock on j |
22nd October 2004, 02:37 | #69 | Link |
I would just like to add a Well Done Zeul. I just backed up Hidalgo UK Pal version.Re-encoded the menu with a avg of 2800 6pass'knocking about 100mb off the menu down to about 180mb(didnt really wanna drop the bitrate much more as the menu was interlaced) and the menu worked fine.I used Numenu4u RC2 Build 3 to do it.
Nice one. |
22nd October 2004, 04:18 | #70 | Link |
I have for the first time tried to use this program.
Everything runs fine but when Sceanterist has finished successfully the hole process stops. I seems that nothing continues, and the progress bar has stopped at apx 70%. What could be wrong here?? /Julius |
22nd October 2004, 04:35 | #71 | Link |
eriksen,
what version of NuMenu are you using? what are your Scenarist settings? Import, compile, Close? What version of Scenarist are you using? check your NuMenu4U.log file (in your program directory) and see what the last process reported was. cheers j |
22nd October 2004, 07:54 | #72 | Link | |
The settings for Scenarist are import,compile,close I use Sonic.Scenarist.v2.7.0241 Sonic Scenerist just says compile successful but the whole process stops. Like no jobs are given to numenu. I can't find the NuMenu4U.log file in install dir? I use the latest avisynth (2.5.5.0) Maby I should try with version 3.0 but I've read in the forum that this could cause some bugs. Please help.. /Julius /Julius Last edited by eriksen76; 22nd October 2004 at 08:07. |
22nd October 2004, 08:01 | #73 | Link |
sorry mate, forgot to mention that you have to have 'enable LOG File' selected in Default Settings.
personally i would change Scenarist Settings to 'Import' only and see if there are any import errors, then compile (again check for errors) then run the IfoUpdate.bat (or something like that) file. oh and try build 5. if all else fails, use the debug function to send zeul the files cheers j |
22nd October 2004, 08:20 | #74 | Link | |
There is just another thought. I manually tell the program where Scenarist is in the very beginning. But if I tell the program to search for the program it can't find it. This is because it's looking for the installed files in the "c:/..../program files" dir. Both scenarist and numenu are placed in my danish "C:/...../programmer" folder. Could this have a bad effect?? Thanx for your time /Julius Last edited by eriksen76; 22nd October 2004 at 17:24. |
22nd October 2004, 08:21 | #75 | Link |
If scenarist has said compile is successful, then unfortunately it is another Automate_Scenarist problem. To fix just close scenarist, and then in your running processes stop Automate_Scenarist. Once this is closed NuMenu4u will carry on as normal.
22nd October 2004, 15:24 | #77 | Link | |
If this is a problem, is there a way to fix it so everything goes automaticly? Or maby the new version will solve the problem. I could also try the new version of Scenarist - What do you think? /Julius |
22nd October 2004, 15:29 | #78 | Link | |
/Julius |
22nd October 2004, 16:14 | #79 | Link |
Edited: My mistake - I forgot to delete the old folder with processed files. Sorry!
God damn - New problem now. I can't start progress after I have installed the new version. If I press start it asks me if I want to quit????? I get this error: Procedure Name: Item Module Name: Settings Error Number: 5 Error Description: Invalid procedure call or argument Error Source: ErrorHandler Error Line: 5 Call Stack: Item --> Settings CheckSystemTray --> MainForm go_Click --> MainForm What is wrong now?? /Julius Last edited by eriksen76; 22nd October 2004 at 16:36. |
