8th December 2006, 11:01 | #441 | Link |
Okay, this is what I do when I record DVB.
That's why it'd be nice if AutoMKV can deal with ProjectX-style filenames. |
8th December 2006, 11:12 | #442 | Link | |
HDConvertToX author
BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
8th December 2006, 15:42 | #443 | Link |
Just curious... Is there a reason you're using XviD as opposed to x264? Do you need the files to play on a set-top box or something?
"Some cultures are defined by their relationship to cheese." |
8th December 2006, 17:39 | #446 | Link |
Still no go with AC3/MP2/mp2 in TS file .... AC3 is demuxxed correctly with ProjectX but audio1.mp4 is only 5 KB in Size ... 8(
I think it has to do with bepipe or delaycut fixed1.ac3 is not generated ... even the file is not there only fixed2.mp2 and fixed3.mp2 ... will try to find the error ... hold on ..8) Last edited by fogbav; 8th December 2006 at 17:41. |
8th December 2006, 19:04 | #447 | Link | |
Life's clearer in 4K UHD
8th December 2006, 19:27 | #448 | Link |
Thanx SMD !
One Question : Is Delay cut nessesary when ProjectX has already demuxed the Audio Video ? Never had Sync-Problems in the past when directly enconding Audio video and then muxxing with mp4box. MayBe a new "Switch" is a good idea ... [] do not Delaycut AudioTracks 8) |
8th December 2006, 19:33 | #449 | Link |
Possibly not, with Project X.... But yes with DGIndex...
8th December 2006, 23:05 | #450 | Link |
also getting following error when muxing.bat is started :
D:\ACE3.0\tmp\temp>"D:\ACE3.0\exe\matroska\mp4box.exe" -add "D:\ACE3.0\tmp\temp\ movie.avi"ar=2.415094 -chap "D:\ACE3.0\exe\chapters.txt" "D:\ACE3.0\tmp\temp \audio1.mp4" -add "D:\ACE3.0\tmp\temp\audio2.mp4" -add "D:\ACE3.0\tmp\temp\aud io3.mp4" -fps 25.000000 "D:\ACE3.0\tmp\temp\movie.mp4" Error - 2 input names specified, please check usage Is there a -add missing at first audio track ? |
8th December 2006, 23:39 | #451 | Link |
By-the-way FogBav,
What application did you use to capture the ".TS sample" you provided? It's a bit odd because it does not have any PAT/PMT Table information! Are all your captured streams like this?
9th December 2006, 09:24 | #452 | Link |
Yes SMD,
i think it has to do with the DBOX2 from Nokia, its the most established receiver here in germany. I am capturing with WinServer, but i can try ll the other programs i tried before ... 8) How can i detect if a TS stream is good (which program) ? |
9th December 2006, 10:19 | #453 | Link |
HDConvertToX author
update www.64k.it/andres/data/a/AutoMKV062c.exe
ADDED: is now possible to deny the use of DelayCut (advanced setting), default value is to use ADDED: use of delaycut in Save Settings FIXED: muxing more that one audio into mp4 EDIT: FIXED: one possible crash on wmv when audio is multichannel BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 Last edited by buzzqw; 9th December 2006 at 10:34. |
9th December 2006, 11:24 | #454 | Link |
MPEG-2Repair, HDTVtoMPEG2 and DGIndex (v1.4.8 Final) are all capable of indicating there's a problem with the .TS source
However, DGIndex is able to provide more information
9th December 2006, 19:58 | #456 | Link |
there's one tiny GUI improvement I'd like to have in AutoMKV if it's possible...
when recording ts streams with my dbox2 I've got sometimes the problem that autogk as well as automkv do not use the audio tracks I'de like to - I don't know if that's a problem with DGIndex or with the ts files - and it does not really matter -> to get around this problem, it would be nice to be able to choose the audio tracks as (seperate) files from harddisk (demuxed with projectx or anything else before) instead of only choosing between the files integrated into a container? |
9th December 2006, 22:07 | #457 | Link |
Hey guys,
I grabbed the latest versions of everything and now when I try to encode WMV, I get this error: http://consumeroo.com/files/wmv-error.png I have the VC1 codec installed (WM 9.5 SDK + WMP11) ... not really sure what to check. Anyone got an idea? Last edited by travisbell; 9th December 2006 at 23:49. |
9th December 2006, 23:49 | #458 | Link |
Played around a bit with .62c, can't make it do anything, thought.
For MKV, no files and strange error message. For avi, same error message and crash in the avi muxer. Tried playing a bit with advanced settings but no effect. |
10th December 2006, 01:09 | #459 | Link |
OK, after some more testing, like you buzzqw were saying, the WMV enocder crashes when I attempt to encode 5.1 WMA audio... if I take her back down to stereo, everything encodes properly.
I wonder how we can nail this problem down? |
10th December 2006, 09:20 | #460 | Link |
HDConvertToX author
@Nico.Laus.2001
it is already possible just demux your ts file to m2v (video) and mpa/ac3 (audio) elementary streams Open AutoMKV, as input choose the m2v file, automkv will ask to browse for till 2 audio files. Make your choice or click cancel at seconda audio track. @Barleyman post the log, attachment need to be approved... and some days could pass before it happen @I wonder how we can nail this problem down? i want to know too BHH
