Old 16th September 2005, 21:03   #1  |  Link
hank315
HCenc author
HC encoder, release 016
Thanks for the feedback, most issues are solved now:
- hangs while running minimized
- wrong GOP size for some fixed GOPs
- artifacts at the right side of some frames
The artifacts were caused because motion vectors could point out of the frame by half a pixel, some decoders don't like that...
Still one issue left, using Avisynth DirectShowSource with the WMV decoder sometimes won't read the stream correct during the second pass, it can skip frames or even jump back.
HC016 latest release at: http://hcencoder.bitburners.com/
hank315 is offline   Reply With Quote
Old 16th September 2005, 22:09   #2  |  Link
Amnon82
Paldo-GNU/LinuxMaintainer
Amnon82's Avatar
It is a great work till now. When I find time I'll play a little with Your new version Keep up the good work.
Mirror for HC016TR2_16-09-2005
P.S.
If You need help with the prediction mode, tell me
Take a look at AutoCQ
Originally Posted by hank315
Some news about HC016.
I wanted to release it also with an updated GUI version but the old GUI isn't flexible enough,
it's too big, just can't fit the new buttons in it anymore (and it's ugly also )
So there will be a completely new GUI but that will take some time to finish...
But thanks to all comments/feedback the HC016batch version is now final:
http://hank315.dyndns.org/HCbatch_016.zip
- fixes the playback on some strict players (Pioneer)
- pulldown issue is fixed, streams can be pulldowned for PAL and NTSC GOP lengths
- updated 1 pass CQ_MAXBITRATE run, should result in better prediction
- autoq2 matrix replaced with avamat6 and avamat7 (both by Amnon82)
Some of this is already in the latest test releases but not all.
For those who use DBD-RB with HC, just replace and rename the exe file with this one.
Amnon82 is offline   Reply With Quote
Old 20th September 2005, 14:15   #3  |  Link
ljpp
Another mirror
ljpp is offline   Reply With Quote
Old 20th September 2005, 15:57   #4  |  Link
Mr. Monte
I take it jdobbs will put this into his RC6b downloads as of now, or will he wait for RC7 or 1.1?
Mr. Monte is offline   Reply With Quote
Old 20th September 2005, 21:18   #5  |  Link
Boulder
Pig on the wing
Boulder's Avatar
I've had no problems with the new test release
One small feature request for 016 though: would it be possible to set the path for the database file or possibly create it in the same directory as the encoded video? At the moment I've got all my video tools on a partition which doesn't have much free space left (only about 500MB), and sometimes the dbs file gets so large that the encoding doesn't proceed to the end of a long video.
Old 21st September 2005, 05:11   #6  |  Link
TheCreamCrackerBoy
Is there a GUI version, like in HC 0.15?
Thank you,
TheCreamCrackerBoy
TheCreamCrackerBoy is offline   Reply With Quote
Old 21st September 2005, 06:54   #7  |  Link
Boulder
Pig on the wing
Boulder's Avatar
I'm sure a GUI version will be available as soon as the official 016 is released. Besides, the commandline version isn't hard to use.
Old 21st September 2005, 07:35   #8  |  Link
Marius-the-Mad
Marius-the-Mad's Avatar
Hank, could you check whether HC writes correct information about colour matrix used ? I mentioned that problem to you and it's unclear whether the culprit lies within DGIndex' or HC's code.
<edit> Solved! Thank you very much for your assistance, Hank!
Marius-the-Mad is offline   Reply With Quote
Old 21st September 2005, 23:34   #9  |  Link
hank315
HCenc author
No, not yet.
But if this batch version runs pretty stable I will create a GUI version.
All development I do is always done on the batch version, it's faster for testing purposes, also it's easier to maintain because it needs less windows stuff.
Old 21st September 2005, 23:37   #10  |  Link
Prodater64
@hank315: How the state of giving back to the stream the bitrate cutted by cq_maxbitrate option?
Prodater64
Prodater64 is offline   Reply With Quote
Old 26th September 2005, 19:18   #11  |  Link
rhayman
Thanks for this release, hcbatch 15_a was crashing in the latest version of dvdrebuilder but this one works fine.
rhayman is offline   Reply With Quote
Old 26th September 2005, 20:55   #12  |  Link
feedback
Gold (Au) Member
feedback's Avatar
I've been using HCbatch 15_A with DVD Rebuilder Pro. with no problem myself. But I always look forward to Hank315's latest and greatest version of his HC encoder.
Regards,
Don't assume anything...Verify!
It's as easy as 3.14159265
The Problem is Usually found between the Chair and the Keyboard!
feedback is offline   Reply With Quote
Old 27th September 2005, 04:08   #13  |  Link
Sounddude
Movie Junky
Is the GUI version ready yet?
Sounddude is offline   Reply With Quote
Old 27th September 2005, 09:42   #14  |  Link
Sunhillow
If hank did not announce it, it isn't
Sunhillow is offline   Reply With Quote
Old 27th September 2005, 14:11   #15  |  Link
DD51
Hank,
Just FYI...
I've backed up a few Discs so far:
All of Season 1 of "LOST"
All of Season 2 and 3 of "24"
5 movies of "Movie only"
I have had absolutley "NO PROBLEMS" whatsoever yet
except that the final size are "ALL" 4.31Gigs!
Just letting you know my experience so far with test release 2.
Regards,
DD51 is offline   Reply With Quote
Old 28th September 2005, 02:49   #16  |  Link
writersblock29
@DD51
You mean, using HC with DVD Rebuilder? 4.31 is Rebuilder's default target setting, so it's not HC's fault. If using Rebuilder isn't what you meant, sorry 'bout that!
Isn't it a bit unnerving that doctors call what they do "practice?"
--George Carlin
writersblock29 is offline   Reply With Quote
Old 28th September 2005, 22:08   #17  |  Link
DD51
Originally Posted by writersblock29
@DD51
Correct...I'm using HC with Rebuilder. 4.31 is good for me...I thought it was 4.33 the default. Thanks for setting me straight.
I love HC!
Thanks Hank for all your hard work
Old 28th September 2005, 22:55   #18  |  Link
writersblock29
@DD51
Sure thing! Actually, Rebuilder's set for 4.31GB for safety. Certain projects will tend to run over that boundary + or - a few MBs. CCE will sometimes oversize a bit, too. That's probably where you've been seeing a few 4.33GB filesizes from. Jdobbs just wanted a safety net to keep people from having to totally re-encode because of oversizing. You can manually tweak this so that you're using more of the blank disk... but doing so only adds a very marginal amount of bitrate to your project and the difference isn't noticable just by watching it.
HC's becoming more impressive with each release. It's making me wish I'd have saved my money when I decided to buy CCE a few years back. Where where you then, Hank?
--George Carlin
Old 8th October 2005, 14:28   #19  |  Link
Pasqui
Hi hank315,
as test release 2 seems to work fine, when do you expect to release final version ?
Regards,
Pasqui is offline   Reply With Quote
Old 9th October 2005, 03:44   #20  |  Link
dragongodz
dragongodz's Avatar
it will be ready when its ready. hank315 has a lot going on in real life at the moment, seems we all do this time of year( ) plus there are all sorts of advanced things he is looking at for HC. since there is no way to be exact it is often better to not put a release date and then have people asking where is it.
Narrator: And of course, with the birth of the artist came the inevitable afterbirth - the critic. (History of the World part 1)
dragongodz is offline   Reply With Quote
