26th February 2011, 04:32 | #1 | Link | |
FFV1: ffms [error] x264
Im having problems decoding a FFV1 source in x264 r.1867 through ffms:
FFV1 15mb: http://www.sendspace.com/file/oaptgp
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread |
26th February 2011, 13:55 | #4 | Link | |
I made some tests with the default x264-r.1867 x32 build from x264.nl and the 1867 JEEB patch:
Source same as post#1 but a trim of 696 frames: lavf: 7:10seg ffmpg 7:15seg avs: 7:20seg avs: Quote:
PSNR of ffmpg and avs were 52.1831dB and lavf 52.1614 My eye told me me ffmpg was slightly the most accurate. Depending where I look at lavf also looks better, in any case there's more speed gain than quality loss, so I will stick to lavf for now.
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread Last edited by Dogway; 26th February 2011 at 14:15. |
26th February 2011, 16:11 | #5 | Link |
Mr. Sandman
why 1867? get a newer revision.
26th February 2011, 16:15 | #6 | Link |
yes, well, that's what I had been using for testings lately, its only for consistency. For the last encoding I use to use the most recent build.
26th February 2011, 17:24 | #7 | Link | |
PSNR of [what] against [what] ?
26th February 2011, 17:46 | #8 | Link |
lossless FFV1 against encoded file through lavf,ffmpg, and avs ffms2 decoders. Fidelity to the original lossless. Im assuming that encoding a file twice (with exact same settings) would give me a 1:1 similarity. Tell me if Im wrong.
For ssim and psnr I load them with ffms2 in avisynth.
26th February 2011, 19:02 | #9 | Link |
Derek Prestegard IRL
Lossless is lossless. You can encode the file as many times as you want, and if decoded properly will be mathematically identical to the original, uncompressed source.
If this is not the case, something in your workflow is not lossless Derek
These are all my personal statements, not those of my employer :) |
26th February 2011, 19:45 | #10 | Link |
Maybe I lacked to say I lossy encoded to h.264 through lavf,ffmpg, and avs. But everything else is exactly the same.
FFV1--->lossy mp4 through --->lavf---> comparison: ffms2 decoded ffmpg avs
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread Last edited by Dogway; 26th February 2011 at 19:51. |
26th February 2011, 20:05 | #11 | Link |
So you want to test the same h264 decoder three times (assuming you use lavc through avisynth)?
x264 log explained || x264 deblocking how-to preset -> tune -> user set options -> fast first pass -> profile -> level Doom10 - Of course it's better, it's one more. |
26th February 2011, 20:12 | #12 | Link |
Ahh, yes. This makes sense now
You should get identical (or VERY close to identical) results regardless of how you get the video into x264, provided all other settings are matched. Your metric scores could be hugely thrown off by an extra or missing frame. I'm guessing this is part of the reason you're doing this test? Derek
26th February 2011, 21:07 | #13 | Link |
so x264 doesn't produce identical encodes runned 2 times?
My test was only for decoding accurateness, but as you say (and I recall reading), once decoded is accurate quality wise. So now I don't know... Maybe there is a mismatch between r.1867 and r.1867 JEEB builds. But avs, and lavfc decoded encodes are also different, and I used the exact same build. Must precise they are identical in the upper half of the image only.
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread Last edited by Dogway; 27th February 2011 at 18:04. |
28th February 2011, 16:39 | #14 | Link |
just wanted to say that the guilty for not producing 2 identical encodes was gradfun2db. probably addgrainc.
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread Last edited by Dogway; 28th February 2011 at 16:55. |
error, ffms, ffv1, x264 |
