Old 20th November 2015, 23:55   #34321  |  Link
e-t172
What do you mean? It enhances, of course.
e-t172 is offline   Reply With Quote
Old 21st November 2015, 00:36   #34322  |  Link
it enhances mostly things like "noise" it makes small "stuff" more noticeable.
on an anime you enhance mostly compression artefact's.
Old 21st November 2015, 01:22   #34323  |  Link
JarrettH
Hahahaha
Old 21st November 2015, 02:01   #34324  |  Link
Warner306
Originally Posted by dansrfe View Post
What exactly does enhance detail do?
It is not that bad. At settings of 1.0 or less, I find it enhances details like people's faces more than grain and artifacts. It is definitely an enhancement if you find the image is too flat. I have been experimenting with this shader with SuperRes and I'm not certain if I like it or not, but it does give the entire image a lift, rather than just the edges of objects.
Old 21st November 2015, 02:38   #34325  |  Link
Nullack
When using the current madVR on a 4K UHD display with high DPI say 300%, the madVR CTRL J renderer stats are too small to read.
Nullack is offline   Reply With Quote
Old 21st November 2015, 02:46   #34326  |  Link
Warner306
It has always been this way to keep the stats from covering the image. And the amount of information in this panel necessitates small writing. But I can agree they are hard to read.
Old 21st November 2015, 07:42   #34327  |  Link
x7007
Originally Posted by djsolidsnake86 View Post
madshi have you found how fix the stuttering when open a file and go to fullscreen?
no one experienced this? i'm on windows 10, with 2 monitors cloned
What stuttering do you mean ? I had stuttering fixed it using PreRender 3 in Nvidia Control Panel and Madvr PreRender 4
x7007 is offline   Reply With Quote
Old 21st November 2015, 07:58   #34328  |  Link
Warner306
Is there any benefit to using thin edges with sharpen edges? I am wondering if the two cancel each other out.
Old 21st November 2015, 09:55   #34329  |  Link
ryrynz
ryrynz's Avatar
There's no cancelling, they all work together. Thinning and edge sharpening work very well together, just don't go too high.
Old 21st November 2015, 12:55   #34330  |  Link
aufkrawall
Yep. I just wouldn't use it together with SuperRes with a strength of 3 for high scaling factors, this will make aliasing a problem for thin sctructures.
Instead, a strength of 2 for SR and a higher sharpen edges value looks better to me.
I must say that SR + a low enhance detail strength really looks nice for filmed content.
Old 21st November 2015, 15:29   #34331  |  Link
truexfan81
truexfan81's Avatar
not sure what the new algos are running, but the only one i can use with my gtx650 is enhance detail, all the others turn it into a slideshow.
truexfan81 is offline   Reply With Quote
Old 21st November 2015, 15:39   #34332  |  Link
aufkrawall
It should be faster than Adaptive Sharpen with your GPU though:
http://forum.doom9.org/showpost.php?...ostcount=34265
However, Adaptive Sharpen isn't very cheap either, so it might be normal that you are quite limited with these shaders.
Old 21st November 2015, 15:40   #34333  |  Link
truexfan81
truexfan81's Avatar
yeah on mine its the other way around lol i can use adaptive sharpen easily
Old 21st November 2015, 15:42   #34334  |  Link
aufkrawall
Hm, that's weird. Maybe the GPU load was so low during madshi's benchmark with AS that it downclocked and so the rendering times are misleading.
Old 21st November 2015, 15:53   #34335  |  Link
truexfan81
truexfan81's Avatar
possibly, i use dxva2-cb so i have mine set to stay at full power 24/7
Old 21st November 2015, 15:59   #34336  |  Link
madshi
You sure you're on v0.89.17? Maybe still running v0.89.16?
Old 21st November 2015, 18:30   #34337  |  Link
omarank
I was adjusting levels of some badly encoded videos. I found that there is no change in black level when I go from black level -8 to -9 using shortcut key. From -9 onwards again the levels change properly. Similarly there is no change in white level when going from -6 to -7. This is seemingly a bug. Shall I post it in the bug tracker? Or I am missing something here?
omarank is offline   Reply With Quote
Old 21st November 2015, 18:54   #34338  |  Link
this works fine for me.
Old 21st November 2015, 20:02   #34339  |  Link
truexfan81
truexfan81's Avatar
v0.89.17 according to the settings SS attached
Old 21st November 2015, 20:48   #34340  |  Link
aufkrawall
DXVA2 CB doesn't let the GPU stay in maximum clock state, CUVID does (but that doesn't mean it would be faster).
