7th June 2006, 02:04 | #21 | Link | |
Actually I'd like to recompress audio and make it an mp4. It's trivial to make it a matroska file, but how can I remux video into an mp4? Can mp4box open a mov file and ignore audio? [edit] Haha yes it can Code:
MP4Box.exe -add SupremeCommander_E3_Trailer_BigHD_SupremeCommanderHQ.com.mov test.mp4 IsoMedia import - skipping track ID 1 (unknown type 'sowt') IsoMedia import - track ID 2 - Video (size 1280 x 720) Saving to test.mp4: 0.500 secs Interleaving Last edited by sysKin; 7th June 2006 at 02:10. |
7th June 2006, 11:20 | #23 | Link |
x264 & XviD rules! ;-)
Try renaming it to .hdmov if you use QT Alternative. It will enable the use of directshow filters such as CoreAVC and CoreAAC instead of QT's poor decoders.
x264 with mb-tree is kicking my ass!! :o Recommended Codec : Latest x264 revision build for everything. Unrecommended Codecs: everything else. |
7th June 2006, 12:03 | #24 | Link |
ffdshow fan
You have to nothing except to set this here to DirectShow (yeah the thing in the back are dropdown fields if you click them), it's set per default to Quicktime and will make MPC use the Quicktime ActiveX to play the videos. (in Zoomplayer this is the same, under video rendering options you'll find an option "Use Quicktime ActiveX" which is checked per default, uncheck this to make Zoomplayer use DirectShow instead.) All that Quicktime Alternative does is to add a filetype .hdmov under Others, and others is set to DirectShow per default, so it will handle the .movs. Nero Splitter usually breaks playback nicely, it's better to block all Nero filters that try to deal with this, especially the famous NDParser.ax ones. Windows should come with a mov splitter that should work fine, at least my Windows XP had one to begin with. Of course gabest one might be better to use. Absolut no renaming required and usual DirectShow Playback. The problem with the missing sound is probably due to some other crap on the system. On http://www.cccp-project.net/ you can find a tool named Insurgent, use this and export your installed filters or give us a test rendering of the files in question. Too many people install crappy codecs packs and any filter they can find anywhere, many try to fuck around with merits or try to surpress other filters, commercial filters seem to be usually very aggressive in this. The goal of most commercial packs like Nero, Cyberlink etc. is to ruin your videoplayback as much as possible to that you think only their apps are the right ones so that you keep buying their stuff. Just boycott this companies and spend your money for less aggressive and non-hostile filters like the Core Products, or just stick to open and free software. Twos audio is indeed PCM afaik. "sowt" is twos audio, ffdshow only recently added support for this. Please update to a more recent version. Twos audio was introduced in revision 2542 of ffdshow.
[ ffdshow-tryouts website ] [ ffdshow-tryouts forum ] [ ffdshow-tryouts changelog ] Last edited by videomixer9; 7th June 2006 at 12:13. |
8th June 2006, 21:39 | #25 | Link |
Ok.
videomixer9, I changed the settings in MPC as you showed. I then installed the latest ffdhow (ffdshow-rev2546-SSE2.exe) (http://ffdshow.faireal.net/#ffdshow) (because the audio codec missing error was still there.) With the PCM Uncompressed option enabled in ffdshow's audio decoder, MPC no longer gives an error about the audio. The video plays extremely slowly, however. Basically MPC freezes up. I even have to kill it in taskman. Did ffdshow actually work for you? I do have Nero on here. And I uninstalled all of its components other than Nero Burning ROM itself. I have CoreAVC installed (MPC is using it). edit: I just tried your latest SSE build with the same result. Last edited by swaaye; 8th June 2006 at 21:49. |
9th June 2006, 14:44 | #27 | Link |
All has been said : there are multiple techniques.
The one i prever is converting mov->mkv using mkvmerge(gui) and then playback using mpc + coreAVC (alpha) I have an Athlon XP 2000+ and 720p trailers from apple play fine. |
9th June 2006, 18:18 | #28 | Link | |
This one does not work because the audio in this MOV is in a very strange format that nothing seems to play back. |
9th June 2006, 18:34 | #29 | Link |
Does it really matter?
There is a method you might be able to use.
Convert the file to mkv using mkvmerge. Open the file in Virtualdubmod Demux the audio to .wav Set the audio to disabled Use direct stream copy to save to mkv (video only) Encode .wav to aac (mp4) merge to either mkv or mp4 (video and audio) This might work. |
