27th May 2018, 16:04 | #6082 | Link | |
27th May 2018, 20:41 | #6084 | Link | |
2858 [Video Encoder] removed input/output settings from the command line preview 2857 [x265] replaced avs4x26x with ffmpeg 2856 [x264] replaced avs4x26x with ffmpeg |
28th May 2018, 06:57 | #6087 | Link |
Is there a way to still have the choice (FFMPEG or avs4x26x) ? I just encode from standard Blu-Ray Disc, 1080p with AVC, and I don't really need high bit depth, AFAIK, and I'm really satisfied with the current tool ^^
28th May 2018, 08:45 | #6088 | Link |
I'll try and get a sample uploaded.
I think this is possibly a DSS issue. I often try the crop with m2ts loaded in DSS and index after. Same sample I tried now gave me different crop when loaded with DSS and when loaded indexed. It didn't happen that often in the past though. Last edited by mini-moose; 28th May 2018 at 08:56. |
29th May 2018, 07:53 | #6092 | Link | |
Please wait with the full implantation of ffmpeg. Just yesterday evening a full encode with an selfmade heavy avisynth script crawls to the bone after circa a hour. From 4.5fps to 1.2fps. At start taskmanager shows 100% cpu load on all 4 cores. After a hour or so it was circa 25%. I aborted the encode then. The script I'm using is somewhat demanding, but I used it for years now without hazzles in MeGui. Maybe it was just coincidence, it was a hot summer day. The cpu was not throttling. The temperatures 55° celsius on all cores. How to implant avs4x26x in this build for testing purposes? I will happily test whether it's a flaw with ffmpeg or something else. Thank you. Edit: Today the same encode finishes unexpected at about a quarter of the expected filesize and length without throttling the cpu . Original length: 28.15min, encoded 6.51min. Mediaplayer shows full length, but stops playback at 6.51min. Last edited by Taurus; 29th May 2018 at 10:04. Reason: Strange behaviour |
29th May 2018, 17:52 | #6093 | Link |
If you want to test the old behaviour you have to go back to version 2855 (http://megui.org/auto/megui-core-2855-32.7z - or 64 if you are using the 64 one).
Do you mind to share the log of the encode with the unexpected end? |
29th May 2018, 19:06 | #6094 | Link |
@Zathor
I sended the logfile via PM. And I will happily test the older version.... EDIT: I just noticed that I deleted the source file which struggles. But I will investigate on similar stuff with both versions of MeGui. Maybe the source file was somewhat bonkered. It played ok in any mediaplayer and via an avisynth script in Virtualdub and MPC-HC. If you want me to explore this a little more, feel free to tell so. Last edited by Taurus; 29th May 2018 at 19:13. Reason: Forgot |
30th May 2018, 12:13 | #6096 | Link | |
Strange! I will test different settings with and without Avisynth+ and report back. But it's to hot at the moment....maybe this evening 33° Degrees and no cloud in sight... |
31st May 2018, 16:51 | #6097 | Link |
When I try to encode my 10bit files, I now get "---[Error] [31.05.2018 17:44:52] x265 [error]: y4m: frame header missing"
I think it has something to do with: "2857 [x265] replaced avs4x26x with ffmpeg" What do I need to know or change? My file: Code:
Video ID : 1 Format : VC-3 Commercial name : DNxHR HQX Format version : Version 3 Format profile : RI@HQX Codec ID : AVdh Codec ID/Info : Avid DNxHR Duration : 10 s 978 ms Frame rate : 59.940 (60000/1001) FPS Color space : YUV Chroma subsampling : 4:2:2 Bit depth : 10 bits Code:
LSMASHVideoSource("Premiere.mov", format="YUV420P10") Code:
--preset slow --crf 19.0 --input-depth 10 --no-sao --profile main10 Code:
[Error] Log -[Information] Versions --[Information] MeGUI: 2858 x64 --[Information] Update Check: development update server --[Information] System Information ---[Information] Operating System: Windows 10 Pro 1803 x64 (10.0.17134.81) ---[Information] .NET Framework: 4.0 (4.0.0.0) ---[Information] .NET Framework: 4.7 (4.7.03056) ---[Information] Redistributables ----[Information] Microsoft Visual C++ 2010 x64: 10.0.40219 ----[Information] Microsoft Visual C++ 2010 x86: 10.0.40219 ---[Information] DPI: 100% (96/96) ---[Information] Monitor 1 ----[Information] Resolution: 1920x1200 ----[Information] Primary Screen: True --[Information] Component Information ---[Information] Haali Media Splitter: 1.13.138.14 (14-04-2013) ---[Information] Haali DSS2: (14-04-2013) ---[Information] ICSharpCode.SharpZipLib: 0.85.5.452 (07-08-2008) ---[Information] MediaInfo: 18.05.0.0 (08-05-2018) ---[Information] SevenZipSharp: 0.64.3890.29348 (02-01-2011) ---[Information] 7z: 9.20 (18-11-2010) --[Information] AviSynth Information ---[Information] AviSynth Wrapper ----[Information] Version: 1.0.2847.0 ----[Information] Date: 06-05-2018 ----[Information] Interface: 3 ---[Information] AviSynth ----[Information] File Version: 0.1 ----[Information] Date: 28-03-2018 ----[Information] Name: AviSynth+ 0.1 (r2664, MT, x86_64) ----[Information] Version: AviSynth+ 0.1 (r2664, MT, x86_64) ----[Information] AviSynth+: true ----[Information] MT: true ----[Information] Status: active ---[Information] AviSynth portable ----[Information] File Version: 0.1 ----[Information] Date: 28-03-2018 ----[Information] Name: AviSynth+ 0.1 (r2664, MT, x86_64) ----[Information] Status: inactive -[Information] Update detection --[Information] [31.05.2018 17:44:29] Using cached update config and server: http://megui.tmebi.de/test/ --[Information] [31.05.2018 17:44:30] No package requires an update --[Information] [31.05.2018 17:44:30] redist files copied: 2017_x64 -[Information] AutoEncode --[Information] D:\Desktop\EOS 5D Mark IV Premiere-muxed.mkv ---[Information] [31.05.2018 17:44:49] No Target Size (use profile settings) ---[Information] [31.05.2018 17:44:49] Split Size: null ---[Information] Eliminating duplicate filenames ----[Information] [31.05.2018 17:44:49] Video output file: D:\Desktop\EOS 5D Mark IV Premiere.hevc ----[Information] [31.05.2018 17:44:49] Muxed output file: D:\Desktop\EOS 5D Mark IV Premiere-muxed.mkv -[Error] Log for job1 (video, EOS 5D Mark IV Premiere.avs -> EOS 5D Mark IV Premiere.hevc) --[Information] [31.05.2018 17:44:51] Started handling job --[Information] [31.05.2018 17:44:51] Preprocessing --[Information] [31.05.2018 17:44:51] AviSynth input script ---[NoImage] LoadPlugin("D:\Sonstiges\Videotools\MeGUI\tools\lsmash\LSMASHSource.dll") ---[NoImage] vid = LSMASHVideoSource("Premiere.mov", format="YUV420P10") ---[NoImage] aud = LSMASHAudioSource("Premiere.mov") ---[NoImage] AudioDub(vid, aud) --[Information] [31.05.2018 17:44:51] resolution: 3840x1080 --[Information] [31.05.2018 17:44:51] frame rate: 60000/1001 --[Information] [31.05.2018 17:44:51] frames: 658 --[Information] [31.05.2018 17:44:51] aspect ratio (avs): 32:9 (3.556) --[Information] [31.05.2018 17:44:51] custom command line: --input-depth 10 --no-sao --profile main10 --[Information] [31.05.2018 17:44:51] Job command line: "cmd.exe" /c ""D:\Sonstiges\Videotools\MeGUI\tools\ffmpeg\ffmpeg.exe" -loglevel level+warning -i "D:\Desktop\EOS 5D Mark IV Premiere.avs" -strict -1 -f yuv4mpegpipe - | "D:\Sonstiges\Videotools\MeGUI\tools\x265\x64\x265.exe" --preset slow --crf 19.0 --input-depth 10 --no-sao --profile main10 --sar 1:1 --output "D:\Desktop\EOS 5D Mark IV Premiere.hevc" --frames 658 --y4m -" --[Information] [31.05.2018 17:44:51] Process started --[Information] [31.05.2018 17:44:51] Standard output stream --[Error] [31.05.2018 17:44:51] Standard error stream ---[Information] [31.05.2018 17:44:52] [chan] box has more bytes than expected: 40 ---[Information] [31.05.2018 17:44:52] [chan] box has more bytes than expected: 40 ---[Information] [31.05.2018 17:44:52] [avisynth @ 000002236e6fac80] [warning] Stream #0: not enough frames to estimate rate; consider increasing probesize ---[Information] [31.05.2018 17:44:52] [warning] Guessed Channel Layout for Input Stream #0.1 : stereo ---[Information] [31.05.2018 17:44:52] y4m [info]: 3840x1080 fps 60000/1001 i420p10 sar 1:1 unknown frame count ---[Information] [31.05.2018 17:44:52] raw [info]: output file: D:\Desktop\EOS 5D Mark IV Premiere.hevc ---[Information] [31.05.2018 17:44:52] x265 [info]: HEVC encoder version 2.8+10-a7bd0622ece5 ---[Information] [31.05.2018 17:44:52] x265 [info]: build info [Windows][GCC 7.3.0][64 bit] 10bit ---[Information] [31.05.2018 17:44:52] x265 [info]: using cpu capabilities: MMX2 SSE2Fast LZCNT SSSE3 SSE4.2 AVX FMA3 BMI2 AVX2 ---[Information] [31.05.2018 17:44:52] x265 [info]: Main 10 profile, Level-5 (Main tier) ---[Information] [31.05.2018 17:44:52] x265 [info]: Thread pool created using 8 threads ---[Information] [31.05.2018 17:44:52] x265 [info]: Slices : 1 ---[Information] [31.05.2018 17:44:52] x265 [info]: frame threads / pool features : 3 / wpp(17 rows) ---[Information] [31.05.2018 17:44:52] x265 [info]: Coding QT: max CU size, min CU size : 64 / 8 ---[Information] [31.05.2018 17:44:52] x265 [info]: Residual QT: max TU size, max depth : 32 / 1 inter / 1 intra ---[Information] [31.05.2018 17:44:52] x265 [info]: ME / range / subpel / merge : star / 57 / 3 / 3 ---[Information] [31.05.2018 17:44:52] x265 [info]: Keyframe min / max / scenecut / bias: 25 / 250 / 40 / 5.00 ---[Information] [31.05.2018 17:44:52] x265 [info]: Lookahead / bframes / badapt : 25 / 4 / 2 ---[Information] [31.05.2018 17:44:52] x265 [info]: b-pyramid / weightp / weightb : 1 / 1 / 0 ---[Information] [31.05.2018 17:44:52] x265 [info]: References / ref-limit cu / depth : 4 / on / on ---[Information] [31.05.2018 17:44:52] x265 [info]: AQ: mode / str / qg-size / cu-tree : 1 / 1.0 / 32 / 1 ---[Information] [31.05.2018 17:44:52] x265 [info]: Rate Control / qCompress : CRF-19.0 / 0.60 ---[Information] [31.05.2018 17:44:52] x265 [info]: tools: rect limit-modes rd=4 psy-rd=2.00 rdoq=2 psy-rdoq=1.00 ---[Information] [31.05.2018 17:44:52] x265 [info]: tools: rskip signhide tmvp strong-intra-smoothing lslices=4 ---[Information] [31.05.2018 17:44:52] x265 [info]: tools: deblock ---[Error] [31.05.2018 17:44:52] x265 [error]: y4m: frame header missing ---[Information] [31.05.2018 17:44:52] x265 [info]: frame I: 1, Avg QP:26.60 kb/s: 62686.27 ---[Information] [31.05.2018 17:44:52] x265 [info]: consecutive B-frames: 100.0% 0.0% 0.0% 0.0% 0.0% ---[Information] [31.05.2018 17:44:52] encoded 1 frames in 0.67s (1.49 fps), 62686.28 kb/s, Avg QP:26.60 ---[Information] [31.05.2018 17:44:52] [error] av_interleaved_write_frame(): Broken pipe ---[Information] [31.05.2018 17:44:52] [error] Error writing trailer of pipe:: Broken pipe --[Information] [31.05.2018 17:44:52] Job completed Last edited by Morku; 31st May 2018 at 17:06. |
31st May 2018, 18:58 | #6100 | Link |
The issue also occur with this testfile: http://4kmedia.org/lg-new-york-hdr-uhd-4k-demo/
and in my case when "--input-depth 10" is added. But I want to keep 10-bit of the sourcefile. |
