14th November 2006, 23:33 | #141 | Link |
foobaring my ass off
Your output WAV PCM must be in this order for correct channel mapping: L-R-C-LFE-Ls-Rs.
What are you using for AAC --> WAV decoding? If the tool doesn´t have a correct maping on decoding, it is gonna get you a while till you figure out what order is being used, as AAC is C-L-R-Ls-Rs-LFE (the LFE order might be wrong though, I don´t remember). The AC3 encoder (i.e Aften) assumes that the order is right, so you get this: C-L-R-Ls-Rs-LFE (a wrongly decoded WAV from AAC) L-R-C-LFE-Ls-Rs (a correct WAV mapping) So C goes to L, L to R, R to LFE, and so on and so forth. Check your AAC decoding. As last resource, strip into mono streams the 6-ch WAV (with Ww ), determine wich mono channel is wich, and remux with WAV order. Cheers
"Damn, respect my authoritay!!" - E. Cartman |
15th November 2006, 00:47 | #142 | Link |
This is the process I’ve been using.
1. I take the 6-channel AAC file (ripped from a QT file) 2. I put the AAC file into the Nero encoding tool and output it to a PCM WAV file. 3. I take the WAV and put it into Wavewizard (where I get stuck with the channel mapping). 4. I then take the newly created WAV and encode it to AC3 via Aften. Thanks. |
15th November 2006, 14:03 | #146 | Link |
Errant Knight
does this help?
AAC
15th November 2006, 15:59 | #147 | Link |
A fast way I use to see the mapping is to play the WAV thru AC3filter, wich has an equalizer that shows you the levels of each audio channel. This way avoids having to strip the channels and check each channel individually.
Usually the channel with little to no level througought the track is the LFE, the one that is almost always high specially on dialogs is the Center. Left and Right have normally the same levels at the same time, and peaks in the surround channels are not as frequent as the Frontal Left and Right, but there are still more than in the LFE. Also, Left comes always before Right. If u have channel 0 and channel 1, it´s bound to be that #0 is L and #1 is Right (the same with surround channels). This might sound complicated but you only need to see it once and you´ll understand inmediately. Cheers.
15th November 2006, 16:19 | #148 | Link | |
16th November 2006, 17:18 | #149 | Link |
Opening with AC3filter implies no need to trim, export, wait till the file is loaded into the audio app and peak-searched.
You just open it. It doesn´t get any faster, easier or less energy consuming than that. Cheers.
16th November 2006, 17:28 | #150 | Link |
right Skelsgard,seems easy to recognize when you know the source but for unknow...well,i like and use AC3filter but it only show me levels and not waveforms then again,for unknow sources is hard only whatching levels...i lose something in your hints? trust,i really want to know how you use in this case.thanks!
16th November 2006, 18:25 | #151 | Link |
Remember that there´s nothing absolute here. There are always opinions, wich can be discussed and shared, and hopefully never silenced.
Is not "you´re wrong and I´m right", just "I like more this way because... than this other way". And about the "rules", they´re just meant to be general guidelines, nothing more. About what i mean. It´s something like this, I´ll give some examples: The first image is a standard AC3 being decoded with AC3filter. The channels in the levels panel seem to correspond to a portion of the movie with dialog (high level C), maybe some background music? (medium levels L and R, with almost equal loudness), birds ramdomly singing on the trees? (low level Ls and Rs), and nothing blowing up (null LFE). Now the next pics belong to an apparently wrongly-mapped-when-decoded WAV. Now we have a L channel with high level maintained in samples from different time (the upper and bottom images are 10 minutes apart from each other). SL and LFE have the same levels across the samples, might correspond to L and R. And so on. Knowing this is a wrongly mapped decoded AAC, i can assume that the order is C-L-R-Ls-Rs-LFE, instead of L-R-C-LFE-Ls-Rs. So I find the correlations: a high level L in dialogs wich would correspond to C, R and C sharing levels with similar overall levels wich would relate to L and R respectively. The same for LFE and Ls, relating to Ls and Rs respectively. And an almost null, low level for moments, Rs, relating to LFE. This entire mental construction, as long as it seems, occurs in half a second. You just click-open the WAV, check ac3filter´s properties and there you see it. I feel this is parting away from the main issue of the thread wich is Wavewizard, maybe it can be continued in a new thread. Cheers.
16th November 2006, 23:02 | #152 | Link | |
all clear,very clear.
this is the "bingo" part: Quote:
thanks Skelsgard,your explanations are very complete and don't need any audio editor to check,AC3filter can do it easily following your hints. |
17th November 2006, 12:31 | #154 | Link | ||||
compilation...(resuming)
Skelsgard's posts are like a guide with pictures. regards |
12th December 2006, 17:45 | #156 | Link | |
I don't need any file ssrc_hp to resample with wavewizardv0.54. |
19th December 2006, 09:39 | #158 | Link |
Open the AC3 in a Directshow player and check for the filters used to render the file. There it should be AC3Filter.
Or if you use MPC, be sure to have AC3filter doing the decoding instead of MPC´s built-in filters. Don´t know if VLC accepts AC3filter as decoding filter. Cheers.
22nd December 2006, 03:27 | #160 | Link |
From the pic you posted, SR and LFE seem to be switched.
If you decode that stream to 6 mono WAV, you get a SR probably containing LFE and viceversa. Load the 6 mono streams in this order to get a proper WAV: L-R-C-SR-SL-LFE and play it again. Post two pics of the results if possible, a few minutes apart from each other. Cheers.
