13th June 2004, 21:19 | #41 | Link |
I have problems with this Filter on "higher" motion in movies. I used
Despot(p1=25,p2=10,pwidth=60,pheight=60,mthres=12,ranked=true,dilate=1, sign=2) Summerized for me is it difficult to decide which factor p1,p2 or mthres should be tuned to get right results. As you can imagine i does not understand the algorithm of this filter so good, so maybe you can get give some points, how to tune it. -- EDIT I think the filter should get better motionestimation (not best but better) because i think one must set p1 high und p2 low to reduce artefacts. Because i think a simple difference betweet two pixels is too bad to decide, if it is a spot or motion. greets krieger2005 Last edited by krieger2005; 13th June 2004 at 23:21. |
14th June 2004, 11:53 | #42 | Link |
AviSynth plugger
For high motions, you may increase Mwidth, Mheight parameters, and try tune Merode.
But of course, motion compensation is the better. Did you try Depan or MVtools ? New version Despot 2.1 (June 14, 2004) is released: Add parameter "mratio" parameter (it was internal =3 in all previous versions). Change default of "merode" to dependent from "mratio". Update doc. At last I begin to understand how the filter works at motion denoising stage 3) Find moving areas of an image by simply comparing each pixel to the previous frame and considering all those which are greater than MTHRES. 3b) Mark motion pixels without noise with weight "mratio" in the motion map. Mark pixels determined both noise and motion as weight 1 in the motion map. 4) Denoise the motion map by erosion and then dilating (as a whole it is morphological opening operation). During erode phase, the motion map is eroded with range mwidth/2 and mheight/2,and zones with small summary weight (less than "mratio*merode/100") are decreased or completely removed from motion map. Such zones correspond to small relative (in percent) numbers of motion neighbors within this range or mostly noisy pixels (spots). During dilate phase, remained motion zones are enlarged with same range. |
14th June 2004, 14:58 | #43 | Link |
I try first MVTools. But because the source is very noisy MVTools generate a "block-theater", where block were shift down, up ...
But in some scenes does the MVTool "something", so that DeSpot does less artifacts. I tried also DePan: Code:
i=last d=depanestimate(range=5, trust=100) x=depan(data=d) return StackHorizontal(x, \ subtract(x,i).ColorYUV(autogain=true)) For higher motion-scenes u use: Code:
norm=ConditionalFilter(motion,des,"abs((YDifferenceFromPrevious+YDifferenceToNext)/AverageLuma*100)",">","19") ConditionalFilter(highmotion,norm,"abs((YDifferenceFromPrevious+YDifferenceToNext)/AverageLuma*100)",">","35") btw, thanks for the tip with Mwidth, Mheight. I forgot these parameters.... |
14th June 2004, 22:22 | #44 | Link |
AviSynth plugger
With Depan, you must use or two Depan(), or DepanInterleave, to compensate global motion for Despot.
Simplest script: Code:
avisource("qwerty.avi") i=ConverttoYV12() mdata=DePanEstimate(i) DePanInterleave(i,data=mdata) Despot(some parameters) selectevery(3,1) BTW, now I try implement some new method of motion detect in DeSpot. |
21st June 2004, 22:27 | #45 | Link |
AviSynth plugger
Changes new DeSpot v.3.0 (June 22, 2004) from 2.1:
Version 3.0 is major release update (probably alpha with bugs): Add another motion detection method "motpn" (previous to next frame). Add whole segments removing methods "seg"=1,2. - more safe. Change luma correction to local in segments (spots) removing mode. Change some defaults. Code reorganization. http://bag.hotmail.ru If new modes will be good in tests, I will remove some old modes in next version. Last edited by Fizick; 20th July 2004 at 23:06. |
24th June 2004, 09:16 | #46 | Link |
Potentate
Fizick,
Have been trying out your filter in restoring some captures off of a laserdisc that is experiencing "laser rot". Your filter seems to knock out the white and black spots nicely, but it does not seem to detect/eliminate any chroma information from the removed spots. I have white, red, blue, and green dots - the white ones are gone, but the others have the intensity reduced, but the chroma flair is still visible. Any thoughts, tricks??? I'm using version 3.0 or your filter. Thanks Ted |
25th June 2004, 19:04 | #47 | Link |
AviSynth plugger
I think, indedendent color spots detecting may produce false detection with ugly color artefactes.
Probably removing color spot only at places of detected luma spots may be better. But it is not very simple task becourse of different sampling of color planes in YV12, espessially for interlaced clips. And it also may produce some artefactes. Current version of DeSpot can fit luma locally, but how fit color in places of removed spots? May you propose any algorithm? |
25th June 2004, 21:40 | #48 | Link | |
Potentate
Fizick,
Thanks, Ted |
27th June 2004, 17:13 | #49 | Link |
AviSynth plugger
New version of DesPot.
Changes 3.1 (June 27, 2004) from 3.0: Add color correction at place of removed spots. Parameter "color": true - change color of pixels at places of removed spots to mean value previous, current and next frames, false - not change color of pixels at places of detected spots. Try! |
28th June 2004, 16:16 | #50 | Link | |
Potentate
Fizick,
You are the Man!!!! Looks like the filter works as advertized - I need to play around with the parameters, as I get some smearing around the spot removal, but the results are better than the previous verisons and certainly much, much better than nothing at all!!! Thank You. If you ever get to the USA, look me up - I owe you a beer!!!!! T Quote:
12th August 2004, 19:24 | #52 | Link |
AviSynth plugger
version 3.2
Recently I release new version of DeSpot.
Changes 3.2 (July 4, 2004) from 3.1: Corrected enabling and disabling of temporal smooth for some modes. Changed temporal smooth method to more fast but simpler, new tsmooth is similar to old tsmooth*2. Restored median mode processing as was before version 3.0. Partial ISSE optimization for speed increasing (Pentium3 or Athlon is needed now). Updated doc. |
20th August 2004, 09:12 | #54 | Link |
Fizick, I adore you. The DeSpot filter works better than expected (and documented) -- the results are awesome.
Combined with DePanEstimate, it forms a perfect tool for film restoration. Unfortunately one problem persists: any solid surface with a large number of frequent simular elements (e.g. brick wall or polka-dot dress) will exhibit an erratic motion estimation with elements disappearing and reappearing randomly. It can be partially remedied by increasing the "range" parameter of Depanestimate, but it slows the process and introduces artifacts on other surfaces. So I'm still scratching my head. |
20th August 2004, 22:03 | #55 | Link | |
AviSynth plugger
Serg Belyansky,
The rest of your post is belonged to DePan filter? I will answer there. http://forum.doom9.org/showthread.ph...n&pagenumber=4 Please post there. |
19th September 2004, 00:33 | #56 | Link |
AviSynth plugger
New Despot version 3.3 (September 19, 2004):
Added "mscene" parameter for scene change detection. (To prevent artifacts at scene change)
My Avisynth plugins are now at http://avisynth.org.ru and mirror at http://avisynth.nl/users/fizick I usually do not provide a technical support in private messages. |
8th October 2004, 23:58 | #57 | Link |
AviSynth plugger
Changes new version 3.3.1 (October 08, 2004) from 3.3:
Fixed bugs with scene change detection.
27th October 2004, 18:20 | #58 | Link | |
Pic1 Pic2 Pic3 RemoveDirt removes everything, but details suffer quite a bit. So I tried DeSpot and indeed it removes some of the white sparks, but I couldn't make him to remove scatches (pic3: right eye), hair lines (pic1: nose) and some of the not so white sparks (pic2: right cheek, pic3: over the left ear) What are the tweak directions to remove these scratches and bluish sparks on the background? |
28th October 2004, 19:33 | #59 | Link |
AviSynth plugger
Jedd,
Your hair scratches are probably too weak for current Despot. However, you may try this script: despot(sign=-1,pwidth=100,pheight=10,p1=15,p2=8,mthres=12) But I think, that more safe for so low threshold p1 is two-pass call (first for thin long horizontal scratches and second for small compact spots): despot(sign=-1,pwidth=100,pheight=2,p1=15,p2=8,mthres=12) despot(sign=-1,pwidth=10,pheight=10,p1=15,p2=8,mthres=12) But it is not perfect. Try. Any comment and suggestion for DeSpot inproving?
30th October 2004, 01:12 | #60 | Link |
I've got a little far than that, now my script looks like:
#big black spots despot(sign=1,pwidth=45,pheight=45,p1=15,p2=8,mthres=8,color=true) #thin white lines despot(sign=-1,pwidth=140,pheight=100,p1=8,p2=1,mthres=5) #thick hair lines (avoid real hair) despot(sign=-1,pwidth=140,pheight=100,p1=15,p2=13,mthres=13,merode=24) #lines contacting motion, avoid motion areas despot(sign=-1,pwidth=140,pheight=100,p1=15,p2=13,mthres=13,merode=16,seg=1) #small dots and dust despot(pwidth=6,pheight=5,p1=15,p2=8,mthres=12,tsmooth=2) Pic3 before Pic3 after I was trying to make it more compact, but thin and thick lines and dots - they all whant diffrenet thresholds. What is difficult: - to get rid of the light blue dots on the dark green wall. - gray hair - when the head moves the hair tends to stay where it were. I could partially fix it with the low merode arg. - to understand why higher thresholds fix big artifacts and don't fix small ones. Another very strange problem I met - I use dvdrebuilder to compress my video and it seems, rebuilder doesn't like 5 despots in a row. 4 are fine, 4 despots + deen are fine too. VirtualDub takes 5 without any problems. I asked Rebuilder pros here: http://forum.doom9.org/showthread.php?s=&threadid=84660 but maybe somebody here knows what might be wrong? |
