#1 | Link |
DVDBot team member
DVDBot: new backup software
Please try and comment ;-)
http://www.srv2000.com sorry.. posted on the bad place... mods, please delete this one Last edited by jvc7845; 13th February 2003 at 23:01. |
#2 | Link |
Whoa! does this actually work, did anyone try this utility yet?
My only question is that it seems to have a quality tab? how can it tell dvd2one to use better compression, I thought dvd2one only used the same setting for all movies!? ![]() Can anyone enlight me on this? |
#3 | Link | |
DVDBot team member
#5 | Link | |
DVDBot team member
#6 | Link |
What is is supposed to do ? Make a 1:1 copy ?
When I run it it finds the DVD, but then it checks the audio and the software 'freezes'. Also, when the software is run, it attempts to access the internet. Is this for real ? or a Fake ? Spyware maybe ? Their website isn't much help, it doesn't even explain what the software is supposed to do ... |
#7 | Link | |
DVDBot does not even allow the selection of the DVD source. So it does not even find my DVD. ![]() I guess I'll delete right now. |
#8 | Link | |
DVDBot team member
we hope this version fix the "no dvd detected" problem |
#9 | Link |
dvd bot v 0.9a
got the new version but it still has probs finding the movie, if u run the progy 1st the dvd wont even show up in windows explorer, i have to shut dvdbot down then put the disc in, however it still crashes on checking the audio stream.
#12 | Link | |
DVDBot team member
it gives more control, and don't forget that encoders like CCE & TMPG are planned ![]()
------------------------ DVDBot team member |
#13 | Link | |
DVDDecrypter works fine for me using SPTI. I am using a Pioneer A04. |
#15 | Link |
I'm with ZWIEBER on this one, what exactly does it do??
I have already d/l it to test but it just crashes for me (on my otherwise ROCK solid XP platform) I am able to use DVDdecryptor (and do so regularly) on it's default settings without problems. Is BOT a full backup solution (menus ect) ![]() |
#16 | Link |
Technicolor Japan
I gave this proggy a try and i can say it looks very promising.
Im using Win XP and had no problems with it so far. I prefer to use CCE so I would like to see how this program run in tandem with it. i have a suggestion may it's already in the works - i noticed that you cant select which VTS you want, seems like the program selects it for you - it would be nice to be able to select them manually. hendrix |
#18 | Link | |
DVDBot team member
#19 | Link | |
Get the fastest and most secure CD Ripper dBpoweramp Reference R13 featuring PerfectMeta Try the most powerful and easy to use DVD editor - DVD Remake Pro |
