18th May 2011, 15:01 | #3222 | Link |
If you're actually using S/PDIF (coaxial or optical), try using ReClock and setting it to encode to AC3, that way you can get 5.1 to your Receiver. S/PDIF itself only supports 2 channel PCM. For more you need HDMI.
18th May 2011, 17:13 | #3225 | Link |
Regarding dts-ma decoding with the arcsoft dll. With the 1.1.0.0 version, LAV audio is telling me my soundtrack is 7.1, but its actually 5.1. Where are these extra channels coming from? With the 1.1.0.8 version, if the movie gets loud I hear a lot of static (quieter parts ok). If anyone has any ideas about these 2 issues please let me know |
18th May 2011, 17:15 | #3226 | Link |
1.1.0.0 is not fully supported yet. The next version will add support for this.
For the other issue, it may just be a bug in the decoder, as i do not process the output at all. Once supported fully, 1.1.0.0 will most likely be the best version to use anyway.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 18th May 2011 at 17:18. |
18th May 2011, 17:54 | #3227 | Link |
Any particular things i should look at, apart from AC3 encoding? seeing as i don't require the video part of it i can just leave it alone?
The Internet: where men are men, women are men, and children are FBI Agents |
18th May 2011, 18:44 | #3228 | Link |
Why is this? BTW, from googling there seems to be a dtsdecoderdll.dll version 1.1.0.10 that came with "TMT 3.5", by which I think the poster meant TotalMedia 3.5. Apparently it doesn't work with eac3to, so I don't know if it could work with LAV.
18th May 2011, 19:04 | #3229 | Link |
1.1.0.0 is the version eac3to was developed against, and it reproduces all audio perfectly. 1.1.0.7/8 drop the back-center in 6.0 layouts, and molest mono audio for no good reason.
I'm not sure when they changed the decoder, so i cannot say which versions between 1.1.0.0 and 1.1.0.7 have what bugs/features.
18th May 2011, 19:07 | #3231 | Link |
Its fine, you just won't have a back center in 6.0 DTS files. Luckily, thats a rather rare layout. 6.1 works fine again.
18th May 2011, 19:34 | #3234 | Link |
Version 1.1.0.0 came with TMT2. But TMT2 installs 2 dtsdecoderdll.dll-s, one to Common files and the other to the program folder, the first from 21.04.2008 and the second from 25.04.2008. They are 1.1.0.0 both, but binary different. nevcairiel, which particular version are you testing with? In that thread mindbomb wrote about mono and 16 bit bugs in 1.1.0.7 which were fixed in 1.1.0.8. As I understood those bugs did not exist in 1.1.0.0, right?
18th May 2011, 20:11 | #3235 | Link |
I'm encountering a new problem, but seemingly not with the decoder. What happens is if I use LAVsplitter to decode DTS/TrueHD/whatever instead of bitstream, whenever I'm done playing my movie and go back into windows media Center there's no sound anymore (or sounds are very distorted). When this happens I can no longer play Live TV or Netflix or Boxee because they error out. However I can go right back into MPC-HC and play another movie just fine. If I restart the computer, then all works fine again until I play another MKV with lossless audio. I do use re-clock if that makes any difference.
Now If I have LAV Audio set to Bitstream, then all works perfect and Windows sounds (including WMC, Netflix, and Boxee) all work fine before and after I play an MKV. Anyone know what could be the problem? I'd rather LAV Audio decode the lossless audio so I can maintain the benefits of ReClock. |
18th May 2011, 20:23 | #3236 | Link |
It's not a LAV Audio issue. It's ReClock and pretty much every other exclusive mode renderer that's causing it. It doesn't reset the audio connection when the exclusive mode lock is dropped. I personally feel that's a bug in the audio driver. (I'm guessing you're on AMD hardware?)
18th May 2011, 20:29 | #3237 | Link | |
18th May 2011, 20:31 | #3238 | Link | |
18th May 2011, 20:36 | #3239 | Link |
That is odd. One would think if ReClock is making an exclusive mode connection it wouldn't matter what the source is. It's when the exclusive mode lock is released that the trouble begins. TMT5 does the same thing when I bitstream, for example. The audio connection gets all screwed up. I generally go to the Audio CP and play the test sound or open Pandora to reset it.
18th May 2011, 20:37 | #3240 | Link |
Are you using Media Center as a GUI to call up MPC-HC? If you're not using ReClock's WASAPI exclusive mode, and aren't using a 7.1 system, you can try the Realtek HDMI driver.
Also, try disabling MC menu sounds, or setting your Windows mixer to stereo, before you try Realtek. Last edited by Andy o; 18th May 2011 at 20:40. |
