Thread Tools Display Modes
Old 6th September 2006, 00:24   #1  |  Link
Sirber
Sirber's Avatar
myFairTunes V.0.5.5b - a iTunes/DRM removal tool
Now supports iTunes 6.0.5.x and iTunes 7.0.0.x
Download NEW myFairTunes6 v.0.5.5b here: http://www.team-assembly.com/myFairT...5.5b_Setup.exe
Download NEW myFairTunes6 v.0.5.5b Source Code: http://www.team-assembly.com/myFairT....5b_Source.rar
AAC Stream Capture based loosely on Igor Skochinsky's Freely available QTFairUse6 Python source code
M4A Conversion based on Jon Lech Johansen's Freely available DeDRMS source code
Credits and Greets to Igor and DVD Jon, and thanks to everyone on the Hymn Forums who helped with testing!
*** NOTE - MUST have Microsoft .NET Framework Version 2.0 Installed!
Get it here: http://www.microsoft.com/downloads/d...displaylang=en
New For This Release
0.5.5b
- Fixed x6 High Speed..
- Fixed and Tested Windows 2000 Support
- Stabilized Patch/Capture some more..
KNOWN ISSUE:
it still sometimes fails removing the track from the library.. but it does convert it and backup 100%
Release History
0.5.4b
- Optimized Patch/Capture
- Added "Always On Top" Option
- All Options now "remember" previous settings
- Added decent installer
0.5.3b
- Fixed more iTunes7 store bought M4A conversion bugs (thanks markofkane)
- Disabled "Internet Connection open to Apple" for XML Parsing
- Added 'iTunes Close on Exit' option (Thanks mattisking)
- Other minor bug/stabilization/cosmetic enhancments.
0.5.2b
- *Private Release (thanks markofkane)
0.5.1b
- Fixed iTunes7 file format padding
0.5b
- iTunes 7.0.0 Support !!
- Adjusted some patch logic to minimize iTunes crashing..
- additional Stabilization
- Added more Windows 2000 fixes (thanks iTunesIsEvil)
0.4b
- Fixed "ALL ARTISTS" & "ALL ALBUMS" to remain 1st list entry
- Fixed Add track's "Reference not set to instance of object"
- Fixed thread syncronization issues
- If M4P backup exists, appends .xx.m4p to target filename (0-99)
0.3b
- myFairTunes6 Always Stays on top
- Better "Backup Folder" browse button handling
- Auto Convert to MP3 and add to library
- Up to 6x High Speed Conversion (using Tunebite driver - still 100% lossless AAC)
- Supports Unicode Special Characters in file names
- Supports Windows 2000
- Supports Other Language Playlists (Like German etc)
- iTunes Crash detection and auto restart
- Can toggle Track List Sorting by Track Name, Artist and Album
- Added Configuration File for easy configuration of File Selection etc.
- Lots of bug fixes & stabilization..
0.2b
- Name change myFairTunes6 to stop any confusion...
- Browse your Entire iTunes Library's M4P files
- Full iTunes Control, plays and stops Tracks automatically
- Full Automatic Conversion of Entire Library with ONE button click
- Multi Select only the Artists, Albums and Tracks you want to convert
- Full lossles M4A conversion with all original tags in tact (artist,album, track, art etc.)
- Full iTunes Library Integration, Auto inserts M4A and removes M4P Tracks..
- Make backup of all converted M4P files (You pick the target backup folder)
- Preview Track directly in myFairTunes
- M4a Files can be converted to high fidelity MP3's directly in iTunes
0.1b
- Supported iTunes versions: 6.0.5.x
- RAW AAC Dumping of PRotected M4P Tracks
download RealAnime and Bencos
Sirber is offline   Reply With Quote
Old 6th September 2006, 04:17   #2  |  Link
int 21h
Still Laughing
int 21h's Avatar
I'm probably just stupid, but at first I thought you wrote this, then I realized it is a C++ port of the QTFairUse python script.
The original thread for this program (to check for updates and such): http://hymn-project.org/forums/viewtopic.php?t=1555
This program does work very well for the English version of iTunes... if only the 1x realtime conversion restriction didn't exist.
"I thought what I'd do was, I'd pretend I was one of those deaf-mutes. That way I wouldn't have to have any god!#$% stupid useless conversations with anybody. If anybody wanted to tell me something, they'd have to write it on a piece of paper and shove it over to me. They'd get bored as hell doing that after a while, and then I'd be through with having conversations for the rest of my life." Chapter 25, pg. 198, The Catcher in the Rye, J.D. Salinger
int 21h is offline   Reply With Quote
Old 6th September 2006, 13:50   #3  |  Link
Sirber
Sirber's Avatar
6x will come in next version.
And indeed this is not my soft, I just posted it here
Old 8th September 2006, 13:47   #4  |  Link
Sirber
Sirber's Avatar
updated for 0.4b
Old 8th September 2006, 22:08   #5  |  Link
Schrade
Schrade's Avatar
Thanks, Sirber
Schrade is offline   Reply With Quote
Old 12th September 2006, 16:06   #6  |  Link
strider01
Is it possible to upload this to somethign other than RapidShare. I'm at a loss at to why people are still using that irritating site, as there are so many other more reliable free hosting solutions. Any non-RapidShare links would be greatly appreaciated! Thanks
strider01 is offline   Reply With Quote
Old 12th September 2006, 17:07   #7  |  Link
Digga
User, Registered
RS is still big in 'buisness' because it's became so popular in such a short time and there are quite some premium users who use the service a lot.
anyway here's a link from the OT:
http://charlie.skytekgroup.com/files...es6_v.0.4b.exe
...and that was the day I realized I had to stop collecting things like matches or dead bodies.
Digga is offline   Reply With Quote
Old 13th September 2006, 20:52   #8  |  Link
johner23
Hi.
---> http://www.apple.com/itunes/
Does it work with LEGAL OBTAINED ( read: purchased ones ) files downloaded from that site?
johner23 is offline   Reply With Quote
Old 13th September 2006, 21:47   #9  |  Link
blutach
Country Member
blutach's Avatar
johner23,
Let's word our posts carefully please. Better would be to ask if it works on files purchased from that site.
Regards
Les
Only use genuine Verbatim or Taiyo Yuden media.
blutach is offline   Reply With Quote
Old 13th September 2006, 22:09   #10  |  Link
johner23
Oh, sorry...
Of course I'm talking about LEGAL obtained files ( not only from that site, but any of them), but I'm should put ALL the words, for clear meaning and without any doubt in the phrase. LOL.
Anyway, thanks for your advice.
Best regards.
devil (johner)
Old 17th September 2006, 17:34   #11  |  Link
Sirber
Sirber's Avatar
updated post for 0.5.5b
Old 12th October 2006, 01:22   #12  |  Link
int 21h
Still Laughing
int 21h's Avatar
Link is dead because 0.5.7b is out
http://www.team-assembly.com/myFairT...5.7b_Setup.exe
Old 29th January 2007, 10:18   #13  |  Link
Lorek
Will this remove the drm from video purchased through itunes?
Lorek is offline   Reply With Quote
Thread Tools
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
