9th February 2011, 03:38 | #11201 | Link |
RE: Afterlife 'Undead Vision' problems
I have searched on this thread for this problem and cannot find it, so here it is. I ripped the complete Resident Evil: Afterlife Blu-Ray to a directory. I then put it through BD Rebuilder with the BD25 size selected, all the extras and just english audio and subtitles (allowing for more than one stream of a language). Everything seems fine except the resultant BD25 sized version has no audio on the Picture in Picture commentary called 'Undead Vision'. After about 3 hours faffing about getting PDVD to play an iso image i made of the original files (just to check see if it's in there) it played with sound just fine. So it's definately BD Rebuilder thats skipping the sound. When i look at the list of tracks BD Rebuilder has detected, there is always one audio track that it refuses to tick, even with me changing the audio options in the settings to all languages, no reencoding etc etc. Can someone help me? I cant figure out how to get the sound on this extra feature and i suspect its that stubborn track that i cant enable. Apreciate the time jdobbs, been using your program now for a looong time |
9th February 2011, 03:50 | #11203 | Link |
This won't resolve any BD_RB problem, but you can always use tsmuxer to add the audio stream back in from the original. That would solve your immediate problem with this movie.
Of course you will have to determine which .m2ts file contains the audio in the original. |
9th February 2011, 05:15 | #11205 | Link | |
9th February 2011, 05:16 | #11206 | Link | |
9th February 2011, 07:18 | #11208 | Link | |
9th February 2011, 18:23 | #11209 | Link |
Hi
Having a problem with Avatar (PAL) Extended edition. Trying to build as DVD-5. Movie only, alternate movie mode DVD5, other movie (playlist number 3 from the list) Fails with FAILED to rebuild. Settings Code:
[Options] MODE=1 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=all SD_CONVERT=0 COLOR_BOOST=0 RESIZE_1080=0 DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=0 KEEP_HD_AUDIO=1 AVCHD=0 REMOVE_WORKFILES=0 AUDIO_TRACK_LIMIT=1 SUBTITLE_TRACK_LIMIT=1 CUSTOM_TARGET_SIZE=23450 TARGET_SIZE=23500 VERSION=0.37.0.4 ENCODE_QUALITY=0 ONEPASS_ENCODING=2 AUTO_QUALITY=1 OPEN_GOP=0 DEINTERLACE=0 SD_TO_1080=0 CONVERT_WIDE=0 AC3_192=0 MOVIE_ONLY_LOOP=1 REMOVE_OUTPUT=0 USE_FILTERS=0 BDMV_CERT_ONLY=0 USE_LAVF=0 IVTC_PULLDOWN=1 ASSUME_DVD_PAL=0 MOVIEONLY_TYPE=1 ALTCRF=20 ALTMETHOD=0 [Paths] SOURCE_PATH=E:\AVATAR_CE_D1\ WORKING_PATH=E:\DVD\ Code:
----------------------- [11:22:14] BD Rebuilder v0.37.04 (beta) - Source: AVATAR_CE_D1 - Input BD size: 39.85 GB - Approximate total content: [02:58:09.470] - Windows Version: 6.1 [7600] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: DVD-5, 720x480/576, AC3 Audio - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=448 [11:22:14] PHASE ONE, Encoding - [11:22:14] Extracting A/V streams [VID_00049] - [11:32:36] Reencoding: VID_00049 (1 of 33) - [11:32:36] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 14,972 frames - Bitrate: 2,944 Kbs - [11:32:36] Reencoding: VID_00049 - [11:42:27] Video Encode complete - [11:42:27] Reencoding audio tracks (if req'd) - [11:50:11] Multiplexing M2TS - [11:50:11] Extracting A/V streams [VID_00002] - [11:52:48] Reencoding: VID_00002 (2 of 33) - [11:52:48] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 25,559 frames - Bitrate: 2,527 Kbs - [11:52:48] Reencoding: VID_00002 - [12:42:05] Video Encode complete - [12:42:05] Multiplexing M2TS - [12:42:05] Extracting A/V streams [VID_00034] - [12:42:17] Reencoding: VID_00034 (3 of 33) - [12:42:17] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,003 frames - Bitrate: 3,749 Kbs - [12:42:17] Reencoding: VID_00034 - [12:45:03] Video Encode complete - [12:45:03] Multiplexing M2TS - [12:45:03] Extracting A/V streams [VID_00004] - [12:45:31] Reencoding: VID_00004 (4 of 33) - [12:45:31] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 2,113 frames - Bitrate: 3,495 Kbs - [12:45:31] Reencoding: VID_00004 - [12:48:46] Video Encode complete - [12:48:46] Multiplexing M2TS - [12:48:46] Extracting A/V streams [VID_00035] - [12:49:08] Reencoding: VID_00035 (5 of 33) - [12:49:08] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 3,056 frames - Bitrate: 3,243 Kbs - [12:49:08] Reencoding: VID_00035 - [12:50:55] Video Encode complete - [12:50:55] Multiplexing M2TS - [12:50:55] Extracting A/V streams [VID_00006] - [12:52:59] Reencoding: VID_00006 (6 of 33) - [12:52:59] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 21,792 frames - Bitrate: 3,226 Kbs - [12:53:00] Reencoding: VID_00006 - [13:08:36] Video Encode complete - [13:08:36] Multiplexing M2TS - [13:08:36] Extracting A/V streams [VID_00036] - [13:08:50] Reencoding: VID_00036 (7 of 33) - [13:08:50] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 727 frames - Bitrate: 4,056 Kbs - [13:08:51] Reencoding: VID_00036 - [13:11:21] Video Encode complete - [13:11:21] Multiplexing M2TS - [13:11:21] Extracting A/V streams [VID_00008] - [13:12:20] Reencoding: VID_00008 (8 of 33) - [13:12:20] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 7,831 frames - Bitrate: 2,509 Kbs - [13:12:20] Reencoding: VID_00008 - [13:27:54] Video Encode complete - [13:27:54] Multiplexing M2TS - [13:27:54] Extracting A/V streams [VID_00037] - [13:28:02] Reencoding: VID_00037 (9 of 33) - [13:28:02] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 960 frames - Bitrate: 2,462 Kbs - [13:28:02] Reencoding: VID_00037 - [13:31:24] Video Encode complete - [13:31:24] Multiplexing M2TS - [13:31:24] Extracting A/V streams [VID_00010] - [13:32:08] Reencoding: VID_00010 (10 of 33) - [13:32:08] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 5,135 frames - Bitrate: 2,457 Kbs - [13:32:08] Reencoding: VID_00010 - [13:42:26] Video Encode complete - [13:42:26] Multiplexing M2TS - [13:42:26] Extracting A/V streams [VID_00050] - [13:42:40] Reencoding: VID_00050 (11 of 33) - [13:42:40] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,057 frames - Bitrate: 2,424 Kbs - [13:42:40] Reencoding: VID_00050 - [13:44:32] Video Encode complete - [13:44:32] Multiplexing M2TS - [13:44:32] Extracting A/V streams [VID_00012] - [13:45:28] Reencoding: VID_00012 (12 of 33) - [13:45:28] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 6,760 frames - Bitrate: 2,884 Kbs - [13:45:28] Reencoding: VID_00012 - [14:04:04] Video Encode complete - [14:04:04] Multiplexing M2TS - [14:04:04] Extracting A/V streams [VID_00038] - [14:04:12] Reencoding: VID_00038 (13 of 33) - [14:04:12] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,036 frames - Bitrate: 3,270 Kbs - [14:04:12] Reencoding: VID_00038 - [14:08:35] Video Encode complete - [14:08:35] Multiplexing M2TS - [14:08:35] Extracting A/V streams [VID_00014] - [14:09:40] Reencoding: VID_00014 (14 of 33) - [14:09:40] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 8,633 frames - Bitrate: 3,089 Kbs - [14:09:40] Reencoding: VID_00014 - [14:15:07] Video Encode complete - [14:15:07] Multiplexing M2TS - [14:15:07] Extracting A/V streams [VID_00051] - [14:15:45] Reencoding: VID_00051 (15 of 33) - [14:15:45] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 8,548 frames - Bitrate: 2,431 Kbs - [14:15:45] Reencoding: VID_00051 - [14:21:39] Video Encode complete - [14:21:39] Multiplexing M2TS - [14:21:39] Extracting A/V streams [VID_00016] - [14:21:49] Reencoding: VID_00016 (16 of 33) - [14:21:49] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 2,482 frames - Bitrate: 2,387 Kbs - [14:21:49] Reencoding: VID_00016 - [14:23:07] Video Encode complete - [14:23:07] Multiplexing M2TS - [14:23:07] Extracting A/V streams [VID_00040] - [14:23:11] Reencoding: VID_00040 (17 of 33) - [14:23:11] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 605 frames - Bitrate: 4,115 Kbs - [14:23:11] Reencoding: VID_00040 - [14:23:34] Video Encode complete - [14:23:34] Multiplexing M2TS - [14:23:34] Extracting A/V streams [VID_00018] - [14:24:32] Reencoding: VID_00018 (18 of 33) - [14:24:32] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 11,310 frames - Bitrate: 2,966 Kbs - [14:24:32] Reencoding: VID_00018 - [14:30:40] Video Encode complete - [14:30:40] Multiplexing M2TS - [14:30:40] Extracting A/V streams [VID_00041] - [14:31:01] Reencoding: VID_00041 (19 of 33) - [14:31:01] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 3,014 frames - Bitrate: 3,936 Kbs - [14:31:01] Reencoding: VID_00041 - [14:32:48] Video Encode complete - [14:32:48] Multiplexing M2TS - [14:32:48] Extracting A/V streams [VID_00020] - [14:33:40] Reencoding: VID_00020 (20 of 33) - [14:33:40] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 11,158 frames - Bitrate: 2,708 Kbs - [14:33:40] Reencoding: VID_00020 - [14:39:47] Video Encode complete - [14:39:47] Multiplexing M2TS - [14:39:47] Extracting A/V streams [VID_00042] - [14:39:56] Reencoding: VID_00042 (21 of 33) - [14:39:56] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 2,528 frames - Bitrate: 2,468 Kbs - [14:39:56] Reencoding: VID_00042 - [14:41:19] Video Encode complete - [14:41:19] Multiplexing M2TS - [14:41:19] Extracting A/V streams [VID_00022] - [14:42:26] Reencoding: VID_00022 (22 of 33) - [14:42:26] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 13,448 frames - Bitrate: 2,838 Kbs - [14:42:26] Reencoding: VID_00022 - [14:49:40] Video Encode complete - [14:49:40] Multiplexing M2TS - [14:49:40] Extracting A/V streams [VID_00052] - [14:49:51] Reencoding: VID_00052 (23 of 33) - [14:49:51] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 3,033 frames - Bitrate: 2,504 Kbs - [14:49:51] Reencoding: VID_00052 - [14:51:31] Video Encode complete - [14:51:31] Multiplexing M2TS - [14:51:31] Extracting A/V streams [VID_00024] - [14:57:16] Reencoding: VID_00024 (24 of 33) - [14:57:16] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 62,869 frames - Bitrate: 3,104 Kbs - [14:57:16] Reencoding: VID_00024 - [15:31:02] Video Encode complete - [15:31:02] Multiplexing M2TS - [15:31:02] Extracting A/V streams [VID_00044] - [15:31:07] Reencoding: VID_00044 (25 of 33) - [15:31:07] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 899 frames - Bitrate: 3,500 Kbs - [15:31:07] Reencoding: VID_00044 - [15:31:37] Video Encode complete - [15:31:37] Multiplexing M2TS - [15:31:37] Extracting A/V streams [VID_00026] - [15:31:51] Reencoding: VID_00026 (26 of 33) - [15:31:51] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 2,814 frames - Bitrate: 3,376 Kbs - [15:31:51] Reencoding: VID_00026 - [15:33:20] Video Encode complete - [15:33:20] Multiplexing M2TS - [15:33:20] Extracting A/V streams [VID_00045] - [15:33:23] Reencoding: VID_00045 (27 of 33) - [15:33:23] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 608 frames - Bitrate: 4,064 Kbs - [15:33:23] Reencoding: VID_00045 - [15:33:45] Video Encode complete - [15:33:45] Multiplexing M2TS - [15:33:45] Extracting A/V streams [VID_00028] - [15:34:28] Reencoding: VID_00028 (28 of 33) - [15:34:28] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 7,431 frames - Bitrate: 3,918 Kbs - [15:34:28] Reencoding: VID_00028 - [15:38:28] Video Encode complete - [15:38:28] Multiplexing M2TS - [15:38:28] Extracting A/V streams [VID_00046] - [15:38:31] Reencoding: VID_00046 (29 of 33) - [15:38:31] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 380 frames - Bitrate: 4,005 Kbs - [15:38:31] Reencoding: VID_00046 - [15:38:45] Video Encode complete - [15:38:45] Multiplexing M2TS - [15:38:45] Extracting A/V streams [VID_00030] - [15:39:29] Reencoding: VID_00030 (30 of 33) - [15:39:29] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 7,929 frames - Bitrate: 3,689 Kbs - [15:39:29] Reencoding: VID_00030 - [15:43:42] Video Encode complete - [15:43:42] Multiplexing M2TS - [15:43:42] Extracting A/V streams [VID_00047] - [15:44:02] Reencoding: VID_00047 (31 of 33) - [15:44:02] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 3,806 frames - Bitrate: 3,236 Kbs - [15:44:02] Reencoding: VID_00047 - [15:46:02] Video Encode complete - [15:46:02] Multiplexing M2TS - [15:46:02] Extracting A/V streams [VID_00032] - [15:46:25] Reencoding: VID_00032 (32 of 33) - [15:46:25] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 5,610 frames - Bitrate: 2,631 Kbs - [15:46:25] Reencoding: VID_00032 - [15:49:15] Video Encode complete - [15:49:15] Multiplexing M2TS - [15:49:15] Extracting A/V streams [VID_00048] - [15:49:28] Reencoding: VID_00048 (33 of 33) - [15:49:28] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 7,185 frames - Bitrate: 1,107 Kbs - [15:49:28] Reencoding: VID_00048 - [15:52:47] Video Encode complete - [15:52:47] Multiplexing M2TS [15:52:47]PHASE ONE complete [15:52:47]PHASE TWO - Rebuild Started - [15:52:47] Rebuilding stream 00049 [1 of 33] - [15:52:47] Rebuilding stream 00002 [2 of 33] - [15:52:47] Rebuilding stream 00034 [3 of 33] - [15:52:47] Rebuilding stream 00004 [4 of 33] - [15:52:47] Rebuilding stream 00035 [5 of 33] - [15:52:47] Rebuilding stream 00006 [6 of 33] - [15:52:47] Rebuilding stream 00036 [7 of 33] - [15:52:47] Rebuilding stream 00008 [8 of 33] - [15:52:47] Rebuilding stream 00037 [9 of 33] - [15:52:47] Rebuilding stream 00010 [10 of 33] - [15:52:47] Rebuilding stream 00050 [11 of 33] - [15:52:47] Rebuilding stream 00012 [12 of 33] - [15:52:47] Rebuilding stream 00038 [13 of 33] - [15:52:47] Rebuilding stream 00014 [14 of 33] - [15:52:47] Rebuilding stream 00051 [15 of 33] - [15:52:47] Rebuilding stream 00016 [16 of 33] - [15:52:47] Rebuilding stream 00040 [17 of 33] - [15:52:47] Rebuilding stream 00018 [18 of 33] - [15:52:47] Rebuilding stream 00041 [19 of 33] - [15:52:47] Rebuilding stream 00020 [20 of 33] - [15:52:47] Rebuilding stream 00042 [21 of 33] - [15:52:47] Rebuilding stream 00022 [22 of 33] - [15:52:47] Rebuilding stream 00052 [23 of 33] - [15:52:47] Rebuilding stream 00024 [24 of 33] - [15:52:47] Rebuilding stream 00044 [25 of 33] - [15:52:47] Rebuilding stream 00026 [26 of 33] - [15:52:47] Rebuilding stream 00045 [27 of 33] - [15:52:47] Rebuilding stream 00028 [28 of 33] - [15:52:47] Rebuilding stream 00046 [29 of 33] - [15:52:47] Rebuilding stream 00030 [30 of 33] - [15:52:47] Rebuilding stream 00047 [31 of 33] - [15:52:47] Rebuilding stream 00032 [32 of 33] - [15:52:47] Rebuilding stream 00048 [33 of 33] - [15:52:47] Building ALTERNATE OUTPUT Structure - [15:56:13] Starting MPLEX. [15:56:13] - Failed to REBUILD Cheers, Andy |
9th February 2011, 19:41 | #11210 | Link | |
Well thanks for the effort your making to sort that out, i've got faith enough to leave the bugger on my drive till you do. I'll be watching the latest updates with great interest. Excellent work dood, you rock Last edited by Giddeon; 9th February 2011 at 19:44. |
9th February 2011, 23:37 | #11211 | Link | |
10th February 2011, 04:19 | #11212 | Link | |
Interesting that I thought BD-RB would pull the delay value from the mpls that tsMuxeR reads upon remux, so as to avoid the potential audio delay causing the async. Will this correction apply to secondary audio as well, since there was another report of the main audio being in sync but the secondary audio was not? |
10th February 2011, 07:28 | #11213 | Link | |
@jdobbs
Now, when one of the 10,000 (it seems) heads gets lopped off, you'll hear "Thump, thump, thump" as it hits the ground - and not, "Sire, may I peel you a grape?" ;>} |
10th February 2011, 13:42 | #11214 | Link |
Question
Hey guys I am having problems making a backup of Case 39. Here is the log.....
----------------------- [07:35:50] BD Rebuilder v0.37.04 (beta) - Source: CASE_39_AC - Input BD size: 35.49 GB - Approximate total content: [02:44:02.565] - Target BD size: 22.90 GB - Windows Version: 6.1 [7600] - Quality: Highest (Very Slow), Two Pass - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=448 [07:35:50] PHASE ONE, Encoding - [07:35:50] Extracting A/V streams [VID_00019] - [07:35:58] Reencoding: VID_00019 (1 of 23) - [07:35:58] Collecting video information - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 958 frames - [07:35:58] Reencoding: VID_00019, Pass 1 of 1 - Encode failed. Retrying. - Encode failed. Retrying. - Reached retry limit. Aborting. - BD-Rebuilder v0.37.04 (beta) - Windows Version: 6.1 [7600] - AVISYNTH Version: 2.5.8.0, Ok - HAALI Splitter: Isn't recommended version - FFDSHOW: , not recommended version - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set incorrectly: [0] - FFDSHOW MPEG2 set incorrectly: [0] - FFDSHOW AVC set incorrectly: [0] - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok [07:36:02] - Failed video encode, aborted I realize the following are wrong according to the log: - HAALI Splitter: Isn't recommended version - FFDSHOW: , not recommended version - FFDSHOW VC-1 set incorrectly: [0] - FFDSHOW MPEG2 set incorrectly: [0] - FFDSHOW AVC set incorrectly: [0] But I just got done doing a backup of The Lovely Bones with no issues. I am guessing the two discs have different Video File types,and this is why I am encountering the issue? Thanks Jake Sorry I left out I have my VC1 set to wmv9,I thought thats what were supposed to set it to in windows 7? Jake Last edited by Jake802; 10th February 2011 at 13:45. Reason: Missed something |
10th February 2011, 15:29 | #11217 | Link |
That's why I asked the question, The only settings I have touched in FFDShow is to make sure the VC1 is set to WMV9. I dont have a clue as to what the others should be. I just know I havent touched them and I havent had any issues in a long time!
10th February 2011, 15:36 | #11218 | Link | |
I don't remember the other report you mentioned -- but the odds are low that there is a connection. Last edited by jdobbs; 10th February 2011 at 15:41. |
10th February 2011, 15:44 | #11219 | Link | |
You need to follow the directions in the first post of this thread exactly. You aren't set up correctly. Any one of those incorrect values I see can result in failure -- and you have several wrong. Last edited by jdobbs; 10th February 2011 at 15:50. |
10th February 2011, 15:50 | #11220 | Link | |
Question my video decoder configuration says vc1 wmv9,how else do i fix it,should I uninstall everything and reinstall it? I just found it odd because I have been making backups for months now with no issues? So Uninstall everything and reinstall after a fresh reboot? Thanks Jake |
