#1 | Link |
MainConcept H.264 Encoder 1.0 Final Released!
In my opinion - it's worse! it crashes again again and again.
Pity 1.0! http://www.mainconcept.com/h264_encoder.shtml Last edited by bond; 21st April 2005 at 22:38. |
#2 | Link |
![]() Join Date: Nov 2001
interesting
![]() btw i think that release is coming too soon to be using the moonlight/elecard encoder i assume (mainconcept bought elecard recently) edit: btw i posted an open issue list with mc's encoder some time ago here
Between the weak and the strong one it is the freedom which oppresses and the law that liberates (Jean Jacques Rousseau) I know, that I know nothing (Socrates) MPEG-4 ASP FAQ | AVC/H.264 FAQ | AAC FAQ | MP4 FAQ | MP4Menu stores DVD Menus in MP4 (guide) Ogg Theora | Ogg Vorbis use WM9 today and get Micro$oft controlling the A/V market tomorrow for free Last edited by bond; 21st April 2005 at 22:13. |
#3 | Link |
I've tested this version some minutes ago.
- program chrashes when "räumlicher bereich" is more than 150 etc. - maximum reference-frames of 99 in 5.1 causes chrashes - the quality is extremely poor - playback is jittering Poor 1.0! |
#4 | Link |
What does Smart Rendering do ?
all my compares are riddles so please try to decipher them yourselves :) current Main XviD PSNRLab version 1.1 current XviD PSNRLab update 1.1.3 MT1389xx Player Infos XviD EDP Build CVS (CruNchers Visual System ©) V 1.4 new with predefined profiles ;) Code:
Olivera: "We're expendable assets"
"and we've just been expended"
#5 | Link | |
![]() i need some sleep
#6 | Link | ||
Ouch, ouch, ouch, ouch, ouch...
When a man sits with a pretty girl for an hour, it seems like a minute. But let him sit on a hot stove for a minute--and it’s longer than any hour. That’s relativity. -- Albert Einstein |
#8 | Link |
Life looks better in HDTV
Who is going to spend $499 on this, when there are more cost effective and even free H.264 encoders out there?
Cheers
Still confused about anamorphic images? Then look here! | Main Encoding Interests: Hardware device playback | My Gear | |
#10 | Link |
ok here my findings:
- avc baseline and main profile is supported (levels are also setable) - raw and mpg PS/TS output is supported - encoding is not that slow imho: ~4fps on a p3 866mhz with b-frames, cabac, loop, which means its a lot faster than previous versions - nice, not always to be expected thingies: reordered p-frames (but no b-references), hadamard, ar signalling, rdo - to be expected but not support thingies: 2pass - encoding always crashes at the end when using more than 1 reference frames, which leads to that the frames from the end are missing in the output stream (with 1 ref all frames are there) - also it sometimes crashes when i try to go to the advanced codec options (it seems to happen if i run the same encode a second time after a crash without (wanting to) changing anything except the advanced settings) - via the reorder delay value you can influence the number of used b-frames in a row, eg - setting the delay to 1 will disable b-frames, even if the gui doesnt show it - a delay of 2 uses 1 b-frames in a row, a delay of 3 two b-frames, delay4 uses 3 b-frames aso... - the two settings max IDR interval and reorde delay are not setable independantly it seems, changing one will also change the other setting automatically - eg idr interval is setable maximal to 99. using a that high value (which would make sense imho), leads to the strange result (as it forces delay to be set to 11 for example) of 10 b-frames in a row there doesnt seem to be a way to change this- no adaptive placement of b-frames - the encoder tells me that max 1 reference frame is not allowed in main profile. in baseline its setable to 1 - access unit delimiter is always used with mpg PS output, even if disabled in the gui - TS output seems to have been fixed since the last release (the streams get now signalled as avc), but produces a very huge overhead (especially with b-frames: a 200kb video stream results in a 5mb TS file )- their decoder seems to have problems handling reordered p-frames combined with max 1 reference frame (with more reference frames it works) - the decoder seems to handle other .mpg files (eg from moonlight) fine too (but always adds a watermark)
Between the weak and the strong one it is the freedom which oppresses and the law that liberates (Jean Jacques Rousseau) I know, that I know nothing (Socrates) MPEG-4 ASP FAQ | AVC/H.264 FAQ | AAC FAQ | MP4 FAQ | MP4Menu stores DVD Menus in MP4 (guide) Ogg Theora | Ogg Vorbis use WM9 today and get Micro$oft controlling the A/V market tomorrow for free Last edited by bond; 22nd April 2005 at 16:12. |
#11 | Link | ||
i mean if you want a fully integrated commercial solution you can buy nero for much less and get a far better codec the next thing is that you have to pay 499€ or 499$, i mean what type of joke is this? an exchange rate of 1:1 for €/$? 499$ are 384€ atm... seems mainconcept totally relies on their name when selling stuff... Quote:
Between the weak and the strong one it is the freedom which oppresses and the law that liberates (Jean Jacques Rousseau) I know, that I know nothing (Socrates) MPEG-4 ASP FAQ | AVC/H.264 FAQ | AAC FAQ | MP4 FAQ | MP4Menu stores DVD Menus in MP4 (guide) Ogg Theora | Ogg Vorbis use WM9 today and get Micro$oft controlling the A/V market tomorrow for free Last edited by bond; 22nd April 2005 at 15:23. |
#12 | Link |
But: It's not 1st April. Hm. So they wanna say me, that they were working on this program for almost 2 years and what is coming out? This encoder is more worse than Videosofts. It crashes as often as the previous betas and the quality hasn't realy improved since them. And what do you wan't with an encoder which chrashes more than you can encode? This only can be a joke!
Sorry, but no clear thinking person of a firm for encodings would pay money for this. What do they want to reach with this? |
#13 | Link |
i heavily tested it and it only crashed in two situations here, with only one being really bad, as i described already...
#14 | Link |
moron
even sorenson is the same. i've dl-ed the latest trial, and one encoding is finished form 9 attempt, however i ended up a not playable garbage. so we have options: ateme(nero) or x264, possibly moonlight - but i never tried.
one by one my leaves fall... one by one my tales are told... |
#15 | Link |
The only pitys are the two years of development and the waiting people for that. I've expected a real BEAT from mainconcept (2 times better quality than ateme's a.s.o.) and a realy improvement since the latest beta but I claim they just worked for their other products and now just called the beta2 just 1.0 final, except some ui-changes.
It seems that mainconcept will rename this product into something different like multimedia-encoder or something. Because the mpeg-encoder is fully included in that release and the h.264-algorithms "should be" in a very early development-stage - and they need to improved! 2.0 - Please come! Last edited by peteag; 22nd April 2005 at 17:59. |
#16 | Link |
peteag, have you been sent by a competitor of mainconcept to badmouth their products?
![]() the encoder and decoder is definitely not that bad as you try to tell... the only real problem i saw was that the encoding aborts shortly before the stream ends, so you have a few frames less in the output, the rest works pretty fine
#17 | Link |
The realy bad is selling a product for 500€/$ which isn't as half as good as a freeware proggie (x.264) or a extremely cheaper product (nero). And all that by a company which is very popular for their codec-products ...
@ bond: This problem wasn't happen to me. But lot more different ones. Is there any guy who doesn't have the major-problem: 4-TIMES-WORSER-QUALITY-THAN-X264? Please send aswers and solutions
#18 | Link | |
moron
#19 | Link | ||
x264 author
#20 | Link | ||
| Thread Tools | |
| Display Modes | |
