Old 20th April 2005, 17:09   #1  |  Link
Bluedan
Bluedan's Avatar
Multiple media stream selection in DirectShowplayer with Haali's splitter
There (still) seems to be an issue with playback of multiple media stream container in combination with Haali's splitter (v19-04-2005)
Tested it with Matroska, tested MP4 as well some time ago.
Used bsplayer v1.2.2build817 and core media player v4.02.
Same scene:
Chapter definitions are recognized by player, but one is unable to choose between different audio or subtitle streams within the players options.
I know that the switch is possible through the system tray icon.
But I find this not desireable, for I had to minimize the player window to get access to the tray, which is awkward.
Hotkeys in player are essential.
On top of this after having switched subs, bsplayer "looses" the subtitle display - it stops showing them - in case I start seeking.
When I switch audio stream the player does not recognize the "new language" though it plays it.
IIRC, the same behavior applies to MP4 files but I didn't test again 'cause I have no mp4 at hand ATM.
My naive conclusion is that the splitter has to be adapted to player commands. The matroska splitter from gabest had the same functionality
I'm probably misconfused...
Bluedan is offline   Reply With Quote
Old 20th April 2005, 17:52   #2  |  Link
Bluedan
Bluedan's Avatar
update
Further investigation:
MP4 container: Subs don't show up at all, neither with internal sub renderer (bsplayer) nor with vsfilter autoload (TCM).
When trying to switch subs through Haali tray icon an error message occurs, but only with the first try:
Mkx:
Reconnect error: 80040111
The players don't crash.
BTW: Getting rid of NeroDigitalParser (splitter) in filter graph is a pain in the a**. Even reinstalling Haalis splitter and changing the merrits (Radlight F. Manager) doesn't have the desired effect. Really strange.
Finally I had to unregister Nero's splitter...
Old 20th April 2005, 20:13   #3  |  Link
JoeBG
stupid
JoeBG's Avatar
Re: update
That´s what we all did
cu
Joe
freedom is just another word for nothing left to loose
JoeBG is offline   Reply With Quote
Old 20th April 2005, 21:35   #4  |  Link
Bluedan
Bluedan's Avatar
But how could that be?
The merrit stuff is supposed to work, no?
Or is Nero doing 'dirty' (direct show) tricks?
Old 20th April 2005, 22:59   #5  |  Link
bond
the filter with the higher merit gets used by default, and nero has a higher merit as haali
Ogg Theora | Ogg Vorbis
Old 20th April 2005, 23:24   #6  |  Link
Bluedan
Bluedan's Avatar
Yes, and I tried to change that with the radlight filter manager.
Afterwards I verified that the merrit values had really changed, but still the Nero Splitter appeared in the filter chain.
AFAIR, both originally carried the value normal, so I assigned normal+1 to Haali and (just for stupidity) NeroDigitalParser to do not use.
But this is not the main issue, for I found a dirty and quick solution for dirty tricks, it's much more the stream switching thing.
I think this is supposed to be different than in its current existence.
I will shut my mouth immediately, if someone tells me that it's on mike's TODO list...
He's my only hope for AVC in matroska.Otherwise I wouldn't have crosse d the lines and left gabest splitter behind.
Old 21st April 2005, 08:53   #7  |  Link
iapir
About the impossibility to select streams from within your player, it's because your player doesn't support a COM interface that Haali uses (and defined by Microsoft AFAIK). MPC, TCMP and other playes have been updated recently to handle that...
iapir is offline   Reply With Quote
Old 21st April 2005, 09:33   #8  |  Link
Bluedan
Bluedan's Avatar
[...]MPC, TCMP and other playes have been updated recently to handle that...
Certain? I don't know about MPC for I don't have it installed, but I have tested the latest 4.02 version (or is there a newer one for the privileged ?) of TCMP with that with the above mentioned result!
Old 21st April 2005, 12:18   #9  |  Link
DAvenger
hacked
DAvenger's Avatar
With RadLight 4 you can easily set a prefered splitter/decoder for all formats. No need to fight merit issues
Pokec o sexe, láske a vzťahoch : http://www.mojvztah.sk
Spyware, malware a vírusy : http://www.antispyware.sk
Hudba, texty, akordy, noty, albumy, mp3 a videoklipy : http://www.musicworld.sk
DAvenger is offline   Reply With Quote
Old 21st April 2005, 13:34   #10  |  Link
yaz
n00b ever
yep ... and the same can be done w/mpc too.
the bests
y
yaz is offline   Reply With Quote
Old 22nd April 2005, 11:58   #11  |  Link
JoeBG
stupid
JoeBG's Avatar
I can´t see the different audiostreams or subtitels in TCMP, updated yesterday. Youst Zoom Player and MPC can handle all streams from Haali´s splitter.
cu
Joe
Old 22nd April 2005, 11:59   #12  |  Link
iapir
I think the TCMP version is not released yet. I guess you should wait for the next release or shout to the CoreCodec guys
