Thread Tools Display Modes
Old 4th April 2005, 19:44   #1  |  Link
jeanl
jeanl's Avatar
MenuShrink 2.2 is here!
MenuShrink Version 2.0 is here!
EDIT MenuShrink Version 2.2 is also here! See below!
MenuShrink is a small application that turns large motion menus into tiny still
menus with or without audio. Menus can usually be shrunk down to 5% to 10% of
their original size, while keeping full functionality.
Version 2.0 has the following main new features:
  • New Preview mode allows you to visually select which image to use in each menu.
  • The output DVD are more compliant than before. The remaining problems with highlights not showing on some DVD players have been fixed.
  • Cells with "non-functional" buttons are now skipped.
  • There's an new panel to set the path to your favorite apps.
along with many improvements and bug fixes.
Get the new version at the usual place:
http://www.videohelp.com/~menushrink/
Here's the change log.
UI:
  • Added selection with video preview for the still frame.
  • MenuShrink remembers which frames were manually selected for the last processed DVD.
  • MenuShrink can reload the last opened DVD.
  • Added tool buttons and a path panel to set them up.
  • Added support for messages in french.
  • Added better command-line support. Pass video_ts.ifo and you open the full DVD. Pass vts_01_0.vob and only that VTS is marked for processing.
  • If the VTSM_C_ADT table isn't correct to begin with, MenuShrink no longer crash.
  • The VTS selection panel has been improved.
Engine:
  • MenuShrink now produces more compliant single-VOBU cells in no-audio mode.
  • In audio mode, the audio is no longer clipped when the buttons appear late in the menu.
  • MenuShrink now picks the smallest frame for transition clips (menu intros/outros).
  • MenuShrink now squashes and attempts to skip cells that have non-functional buttons (either tiny buttons, or buttons that all have NOP commands).
Bug Fixes:
  • Fixed a bug in the pack identification routine that caused an audio pack to be mistaken for a navpack in Godzilla!!!
  • Fixed a problems with tools when the path to the DVD folder had spaces in it.
  • Occasional highlight delay has been fixed.
  • The few remaining problems with highlights not showing on some DVD and some players have been ironed out.
Here's the thread for
version 1.0.
Enjoy!
jeanl
A few PgcEdit guides.
DVDSubEdit a free tool to edit subtitles directly inside the vob.
jeanl is offline   Reply With Quote
Old 4th April 2005, 23:36   #2  |  Link
lelo108
First!!
i love you man
Je t'aime lol
tu es trop fort!
merci beaucoup pour ce taff!!!
lelo108 is offline   Reply With Quote
Old 4th April 2005, 23:42   #3  |  Link
jeanl
jeanl's Avatar
Originally posted by lelo108
First!!
i love you man
Je t'aime lol
tu es trop fort!
!!! LOL!
I'm laughing my ass off over here! Next thing we know, this thread's going to be censored for obcenity! But keep it coming man!! LOL!
Tout le plaisir est pour moi, by the way
jeanl
Old 5th April 2005, 00:33   #4  |  Link
jsoto
Just a Member
I like much your manual still selection. Easy to use.
Good work, jeanl !!
jsoto
Web sites with my tools
http://download.videohelp.com/jsoto
http://jsoto.posunplugged.com/
jsoto is offline   Reply With Quote
Old 5th April 2005, 00:34   #5  |  Link
jeanl
jeanl's Avatar
Good work, jeanl !!
jsoto
Thanks jsoto! I haven't included your color-enabled log yet (I ran into problems, didn't find the time to solve them) but I really want to. That makes the log sooo much more readable. I'll keep you posted...
Jeanl
Old 5th April 2005, 03:52   #6  |  Link
blutach
Country Member
blutach's Avatar
Congratulations jean from one of your hardworking "beta testers" LOL
BTW: Your link to the thread for MS 1.0 is wrong (was also wrong at DD but was fixed )
Regards
Les
Only use genuine Verbatim or Taiyo Yuden media.
blutach is offline   Reply With Quote
Old 5th April 2005, 18:32   #7  |  Link
Whitespliff
Whitespliff's Avatar
I get version 1 when I d/l from your site, already had that one
In a world without walls and fences, who needs Windows and Gates?
Whitespliff is offline   Reply With Quote
Old 5th April 2005, 18:42   #8  |  Link
jeanl
jeanl's Avatar
This happens sometimes if you don't refresh... When you get to the download page (not the main page), hit F5 (or refresh your browser). Then you'll get version 2.0
jeanl
Old 5th April 2005, 18:51   #9  |  Link
Whitespliff
Strange, I delete my tempory files (along with history & cookies) almost daily so it should have given me the new page.
Stupid mistake on my part
Tnx
Old 5th April 2005, 18:53   #10  |  Link
jeanl
jeanl's Avatar
It's a bit scary though... I wonder if a lot of people will get version 1.0 instead of 2.0 and wonder what the heck is wrong!
Anybody knows how to avoid the problem on my side (can I do something on the web page to make sure this does not happen?).
jeanl
Old 5th April 2005, 22:20   #11  |  Link
CoNS
reMember
Put the version number in the file name...?
And delete http://jean.laroche.free.fr/MenuShri...ies/index.html and stick to direct links to the files.
CoNS is offline   Reply With Quote
Old 5th April 2005, 22:22   #12  |  Link
jeanl
jeanl's Avatar
yes yes yes... I put the version number in the files, and deleted the old one (so people might get an error, but won't get the old version).
The intermediate page allows me to see the number of downloads. I don't know how to do that otherwise (I don't like such intermediate pages myself!).
jeanl
Old 6th April 2005, 06:26   #13  |  Link
blutach
Country Member
blutach's Avatar
Bug in Log??
Any one else get this?
I press save and I got a run time error so I re-processed. Save again, and nothing in log. Had to copy and paste manually.
Regards
Les
Old 6th April 2005, 07:46   #14  |  Link
jeanl
jeanl's Avatar
OK that problem was solved. If you run into it, download version 2.04 from the web, here...
Thanks blutach
jeanl
Old 7th April 2005, 04:27   #15  |  Link
Whitespliff
jeanl
I think: <meta http-equiv="Pragma" content="no-cache"> does just that (add it in your header).
Hope this helps
Old 7th April 2005, 05:10   #16  |  Link
jeanl
jeanl's Avatar
Hope this helps
Excellent! I'll put it there! Thanks a bunch...
jeanl
Old 7th April 2005, 05:29   #17  |  Link
daehkcid
Mec, ca sera cool si on pouvait editer les menus! Il ne manque que ca!
daehkcid is offline   Reply With Quote
Old 7th April 2005, 05:40   #18  |  Link
jeanl
jeanl's Avatar
Translation: "dude it would be cool if we could edit menus. That's the only thing missing"
Answer: Mec, it would be cool if you wrote in english for the rest of us on this forum .
To edit menus, you have PgcEdit's menu editor, which is absolutely fabulous! You can change almost EVERY aspect of your menus. There's really not much to add to that.
But what did you have in mind anyway???
jeanl
Old 7th April 2005, 11:17   #19  |  Link
arsmori
arsmori's Avatar
My guess: a simpler PgcEdit menu editor, a freeware MenuEdit, with fries... and mayonnaise.
Superb app btw, just shrunk 8½ criterion ed. menu from 280MB to 7 MB, I love it.
Ahh, ze assimilated expats, ze are zeu worsteuh francophobez.
(j/k, I know I know, international forum, intelligibility! rules! aux armes etc.)
arsmori is offline   Reply With Quote
Old 7th April 2005, 17:57   #20  |  Link
jeanl
jeanl's Avatar
You have me rolling on the floor here! . Don't want to go into politics here, but I live in the states and believe me, I'm far from assimilated (like many US citizens I know!!!).
Anyway, thanks for the good words! A plus!
jeanl
Thread Tools
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
