Old 2nd April 2005, 20:25   #1  |  Link
pawl
environment vars
Is it possible to access user environment variables from an avisynth script? I know I could do some sort of replace with a batch file, but I'd prefer not to..
Thanks!
pawl is offline   Reply With Quote
Old 2nd April 2005, 23:44   #2  |  Link
esby
esby's Avatar
You mean accessing the window environment variables?
Or accessing what is stored in the avs environnment (aka env)
esby
http://esby.free.fr/
esby is offline   Reply With Quote
Old 3rd April 2005, 03:36   #3  |  Link
pawl
Yeah, the windows environment variables.
Old 3rd April 2005, 06:36   #4  |  Link
stickboy
AviSynth Enthusiast
I don't think there currently is a way.
I think it should be pretty trivial to write a plug-in that can retrieve values of environment variables, though. I can give it a shot tomorrow unless someone else feels like doing it (and probably doing it better).
stickboy is offline   Reply With Quote
Old 3rd April 2005, 11:15   #5  |  Link
stickboy
AviSynth Enthusiast
Okay, try this: GetSystemEnv
Edit:
Renamed from GetEnv by request.
Old 3rd April 2005, 11:24   #6  |  Link
esby
esby's Avatar
Wouldn't it better to rename it to GetWinEnv instead of GetEnv
as there is already an internal env context in avisynth?
This could avoid confusion.
esby
Old 3rd April 2005, 11:51   #7  |  Link
stickboy
AviSynth Enthusiast
Maybe... but the other environment isn't (and probably should never need to be) accessible via user scripts.
And I know that AviSynth is pretty Windows-specific, but I'd prefer to avoid using a Windows-specific name (especially since it's just a pass-through to getenv() from the C standard library).
Maybe GetOSEnv or GetSystemEnv or something?
Old 3rd April 2005, 12:02   #8  |  Link
esby
esby's Avatar
Oh right,
getSystemEnv() might work
esby
Old 3rd April 2005, 21:31   #9  |  Link
pawl
Awesome! Much thanks!
Old 5th April 2005, 02:09   #10  |  Link
pawl
Any good reason these functions aren't in the core?
Old 5th April 2005, 07:13   #11  |  Link
stickboy
AviSynth Enthusiast
No one requested them before.
I don't have CVS access, but if someone who does thinks they're appropriate, they're more than welcome to merge those functions in (the code's pretty trivial anyway).
Old 26th May 2009, 20:46   #12  |  Link
DigitAl56K
Bump up and vote +1 for adding to the core
DigitAl56K is offline   Reply With Quote
