#1 | Link |
![]() Join Date: Oct 2001
Muxman version 0.12 released
Available here
New features: full support for field pictures 8 subpicture tracks import Muxman or Scenarist project files (scripts) export Muxman project files batch mode / command line processing |
#2 | Link |
woman @ german doom9
Dear mpucoder,
unfortunately, something doesn't work with subtitles. The following error message appears: Code:
Opened sub 1 file F:\temp\muxman\sourcen\TEMP\SUBs\Mai01-Mai04_TEST.sst. Pixel_Area values 0 572 are incorrect, using default of 0 572. Display_Area Y values 2 574 are incorrect, using default of 2 574. F:\temp\muxman\sourcen\TEMP\SUBs\\Mai01-Mai04_0001.bmp adjusted start time is negative (SubRip delay too high). file skipped. Code:
st_format 2 Display_Start non_forced TV_Type PAL Pixel_Area (0 572) Display_Area (0 2 719 574) PA (0 0 0 - - - ) E1 (255 0 0 - - - ) E2 (0 0 255 - - - ) BG (255 255 255 - - - ) SubTitle 0020 Directory F:\temp\muxman\sourcen\TEMP\SUBs\ ############################################################# SP_NUMBER START END FILE_NAME ############################################################# Contrast (15 15 15 0) Color (2 1 7 1) 0001 00:00:10:00 00:00:48:00 Mai01-Mai04_0001.bmp Color (2 1 1 1) 0002 00:01:00:00 00:01:20:00 Mai01-Mai04_0002.bmp Color (2 1 7 1) 0003 00:01:40:00 00:02:00:00 Mai01-Mai04_0003.bmp Color (2 1 1 1) 0004 00:02:02:00 00:02:40:00 Mai01-Mai04_0004.bmp Thanks for v.12 ... Katjarella
katjarella by Creyskull Visuell Design |
#3 | Link |
NTSC subpictures are supposed to have an even number of lines, unfortunately the check doesn't care which tv system is used. It doesn't change the output, though. I have removed the check and replaced the zip file without a revision number change. Also the delay should be correct now.
All the tests run on Muxman (which are now automated thanks to project files) showed no changes in output. The exception, of course, is field pictures which were wrong before. One thing about your sst script - the contrast line will be skipped. Any line following a line with all "#" will be skipped. Last edited by mpucoder; 27th February 2005 at 22:58. |
#4 | Link |
I was thinking more about the skipping line. Originally any unrecognized line, like the with SP_NUMBER in it would have caused a syntax error. But the parser now just ignores anything it does not recognize. So I will be changing the parser to treat a line of all "#" as just a single line comment.
There is one thing that should be corrected in your script, for both Muxman and Scenarist. And that is the conversion rules. These are the symbols that follow the color values, eg PA (0 0 0 - - - ) the - - - are the three conversion rules. The only characters Scenarist allows are < = > &, these define the relationship between the stated color and that in the bitmap. - has no meaning and will be replaced with & by Scenarist, meaning if the bitwise AND of bitmap color and value from the script is non-zero then that is a match. Muxman right now does not process the rules in an sst file (it assumes = = =), so you get away with it. But that will change (I missed it this time), and you may be surprised at the subpictures. Last edited by mpucoder; 27th February 2005 at 23:12. |
#5 | Link |
Ok, mpucoder...
The Original Scenarist Script: Code:
Item=Video {
Place Holder=No
Name=TESTSTREAM
Resolution=PAL
Drop Type=Non-drop frame
Data Start Time=00:00:00;00
Data End Time=00:01:19;24
File=F:\temp\muxman\sourcen\TEMP\TESTSTREAM.m2v
Width=720
Height=576
Is Encoded=Yes
Encode Type=MPEG 2
Size=720 x 576
Aspect Ratio=4 : 3
Picture Structure=Frame Structure
GOP Size=15 frames
GOP Structure=N/A
Bit rate=9800000
Average Bitrate=6000000
Minimum Bitrate=4000000
Bitrate Type=Variable
Icon Time=00:00:00;00
Line21 Switch1=No
Line21 File1=
Line21 Switch2=No
Line21 File2=
Item=Sub-Picture {
Place Holder=No
Name=Mai01-Mai04_0001
Resolution=PAL
Data End Time=00:00:10;00
Width=720
Height=576
Is Encoded=Yes
Screen Size=Size {
X=720
Y=576
Item=Segment {
Name=Segment_1
Display Mode=4:3
Item=Video Stream {
Coding Mode=Mpeg-2
Standard=PAL
CC Field 1=No
CC Field 2=No
Item=Video Play {
Size=10024552
Duration=Actual
Item=Sub-Picture Stream {
Stream Number=1
Language=en
Language Extension=1
Display Mode=unspecified
Item=Sub-Picture Play {
Start=00:00:00:00 (0)
Forced Start=Yes
Time Code=PAL
Duration=00:00:10:00
Origin=0,0
Display Area=0,2,719,574
Color 1(Pa)=000000 & & &
Color 2(E1)=ff0000 & & &
Color 3(E2)=0000ff & & &
Color=2 1 7 1
Contr=15 15 15 0
But in Scenarist, the same SubScript works flawlessly.
#6 | Link |
jdgljlfljg
Fantastic to see project file/cli support. Although I think it's a huge shame that it's not possible to just specify an sst, instead of each individual subpicture and it's attributes. This would make auto generation of project files so much easier for people like me.
Also, in case you didn't know, the project file extention (mxp) seems to match that of the macromedia extension manager (which is installed with dreamweaver). |
#9 | Link |
jdgljlfljg
I take back what I said. Pure awesomage
![]() Yes, maybe you should change the extension, only because dreamweaver is so popular. Perhaps mmp? You can input possibilities at http://filext.com and see if they are already taken by well-known apps
#11 | Link | |
#12 | Link |
The fix is online now. And any fixes will be public. It's just that from now on I will give them revision numbers (letters, actually). A new series of alpha's will start Monday.
I'll have some documentation online about the project file soon. There is one other not-so-obvious thing you can do. Scenarist does not allow more than one motion video file in a track (segment to Muxman), instead they use a "concatenation file list" in a file with the .cfx extension. Muxman will import and expand these. |
#13 | Link |
jdgljlfljg
I tried 2 ssts via the GUI and the results were funky - the background was black instead of transparent for a start.
The ssts were saved from a sub/idx using SubResync/vsconv.exe. Here's one of them" st_format 2 Display_Start non_forced TV_Type NTSC Tape_Type NON_DROP Pixel_Area (0 477) Directory . Subtitle saved Display_Area (0 2 719 479) Contrast (15 15 15 0) PA (0 0 255 - - - ) E1 (255 0 0 - - - ) E2 (0 0 0 - - - ) BG (255 255 255 - - - ) SP_NUMBER START END FILE_NAME Color (9 4 15 3) Contrast (15 15 0 15) 0001 00:01:39:02 00:01:41:25 saved_0001.bmp 0002 00:01:42:24 00:01:46:23 saved_0002.bmp 0003 00:01:47:16 00:01:49:15 saved_0003.bmp |
#15 | Link |
Just a Member
A BIG thanks. I'll give it a try in CLI mode..
jsoto
Web sites with my tools http://download.videohelp.com/jsoto http://jsoto.posunplugged.com/ |
#16 | Link | |
jdgljlfljg
#17 | Link |
You still have to put the colors into the PGC manually. sst files have no color information.
The next version will add a lot more to what a project file can do, including setting the CLUT, but just this version required 110 keyword/context combinations. This was to get it to the same level as the gui. |
#18 | Link |
jdgljlfljg
Of course, forgot about the palette. Muxman's default palette differs from Scenarist's and presumably gabest produces ssts to fit the latter's default.
But that aside, I'm having issues with some other subs. The bmps on these are unusual, compared to the typical blue background, red text and white outline. They consist of a black backround and a small white box around the text area, and the text is red with a blue outline. Scenarist handles these just fine using the inputted sst, Muxman doesn't, the background is white etc. It would appear Muxman detects what the background is differently from scenarist. st_format 2 Display_Start non_forced TV_Type NTSC Tape_Type NON_DROP Pixel_Area (0 477) Directory H:\test\subs2 Subtitle test Display_Area (0 2 719 479) Contrast (15 15 15 0) PA (0 0 255 - - - ) E1 (255 0 0 - - - ) E2 (0 0 0 - - - ) BG (255 255 255 - - - ) SP_NUMBER START END FILE_NAME Color (3 10 3 3) Contrast (0 0 0 0) 0001 00:00:00:00 00:00:00:01 test_0001.bmp Contrast (0 15 15 0) 0002 00:00:30:08 00:00:35:26 test_0002.bmp 0003 00:02:54:25 00:02:57:18 test_0003.bmp Contrast (0 0 0 0) 0004 00:03:32:27 00:03:32:28 test_0004.bmp Contrast (0 15 15 0) 0005 00:03:40:13 00:03:46:17 test_0005.bmp 0006 00:03:55:08 00:03:56:29 test_0006.bmp 0007 00:04:01:07 00:04:04:20 test_0007.bmp 0008 00:04:17:08 00:04:18:17 test_0008.bmp 0009 00:04:23:17 00:04:25:25 test_0009.bmp 0010 00:04:49:19 00:04:51:16 test_0010.bmp 0011 00:04:51:22 00:04:53:06 test_0011.bmp Last edited by Matthew; 28th February 2005 at 02:25. |
#19 | Link |
Re-read your post. Could you send one of the bitmaps to me - muxman (at) mpucoder (dot) com
Muxman actually has no rule for the background - if a pixel is not P, E1, or E2 it is BG. What else to do with a pixel that matches nothing? |
| Thread Tools | |
| Display Modes | |
