#1 | Link |
_
![]() Join Date: Jan 2002
DGMPGDec 1.2.1 Beta 2
Here's a new beta. The changes are as follows:
1. Fixed crashing bug in BlindPP(). 2. Fixed incorrect DGDecode postprocessing for YUY2. 3. Changed DGDecode to deliver YV12 by default. For I420, use DGDecode(...,i420=true). This fixes interoperability with some applications, such as mencoder. 4. Fixed erroneous audio delays for multiple tracks. 5. Added i420 parameter to DGDecode help file, and added an Appendix on BlindPP() usage. http://neuron2.net/dgmpgdec/dgmpgdec121b2.zip |
#2 | Link | |
I'm afraid we've to stop
![]() Join Date: Mar 2003
Re: DGMPGDec 1.2.1 Beta 2
Gordian Knot Family: Gordian Knot: website, download Auto Gordian Knot: Website and download, tutorial, FAQ |
#5 | Link | |
Would it be difficult to add a field_operation option to dgdecode (to override what's specified in the d2v)? Also D2V_Format_v08.txt says:
I forgot my password. |
#8 | Link |
Member of a Library
neuron2,
Now that hints are getting more fashionable, could you consider passing hints to telecide? (sory if I don't know what I'm talking about, or if it is already implemented or planned... DGdecode is working flawlessly here, but telecide could use some help too - not that it isn't OK itself, it's the sources I'm struggling with...) And thank you for your great work! GL |
#9 | Link | |
_
The problem is that the progressive_frame flag is notoriously unreliable. If you need any help with the Telecide sources, I'll be happy to assist you via PM. |
#10 | Link | |||
Member of a Library
![]() Quote:
![]() Quote:
http://forum.doom9.org/showthread.php?s=&threadid=85639 Now I don't seek help for myself (I've already finished with those movies), but I think every idea for improving great programs is worth considering (and that may be my contribution since I can't do programming myself). GL |
#12 | Link |
I tried using DGMPGDec v1.2.1 beta 2 instead of DVD2AVIT3 for making a .d2v of a transport stream captured by an MyHD MDP-120 but when I try to cut commercials it goes much slower than if i make the .d2v with DVD2AVIT3, is there a reason for this?
#14 | Link |
I have a problem:
When I use DGMPGDec 1.2.1 Beta 2 i get MOVIE AC3 T02 3_2ch 384Kbps DELAY 40ms with DVD2Avi i get: MOVIE AC3 T02 3_2ch 384Kbps DELAY -40ms So the delay is negative like also ifoEdit shows up. But the curious thing is the in both cases, if i enter the delay excactly as shown in filename when muxing to .avi it is in sync. So i think there has to be a difference in the created .d2v since the 2 .ac3 files have identical content! |
#17 | Link |
_
You use the value that gives you the best sync!
DGIndex just reports the offset between the video and the audio at the starting point. But the streams could have been multiplexed already slightly out of sync. My process is to try a short encode using the DGIndex value. If that appears OK, I use that. If not, I experiment until I find the right value. Most of the time DGIndex is close, but not always. |
#20 | Link | |
![]() Join Date: Nov 2002
Read the FAQ, Q34. In short, the old versions dropped 3 frames, which affected the delay. |
| Thread Tools | |
| Display Modes | |
