Old 7th February 2005, 00:07   #1  |  Link
k0r0n4
666 byte icon
k0r0n4's Avatar
liboggz build
Since I was unable to find a build of liboggz on the internet, I decided to build it myself.
You can find the build of v0.9.0 here.
Feel free to browse around for other builds (including SVN builds). Every build should be in this directory.
The source can be obtained here.
This has some really useful utilities, especially the oggzmerge utility that allows you to mux already encoded theora streams with other streams w/o having to reencode.
This is not my code or my program, I'm just providing a binary distrobution of it. Enjoy
k0r0n4 is offline   Reply With Quote
Old 7th February 2005, 01:41   #2  |  Link
bond
great stuff, thanks a lot!
with oggzmerge its for example possible to mux different ogg streams (theora, vorbis, flac, speex):
oggzmerge -o output.ogg input_vorbis.ogg input_theora.ogg input_flac.ogg
playback works for example fine with illiminable's filters (and i hope with radlight's filters too)
oggzinfo for example displays what streams an .ogg contains
Ogg Theora | Ogg Vorbis
Old 11th February 2005, 12:18   #3  |  Link
Elias
MPEG-4 Crazy Lunatic!
Elias's Avatar
This seems pretty cool. Will it be included in ffdshow?
Elias is offline   Reply With Quote
Old 11th February 2005, 12:22   #4  |  Link
bond
Old 11th February 2005, 12:26   #5  |  Link
Elias
Elias's Avatar
Well, since ffdshow always has a bunch of "lib" codecs, will this one be there as well? What does LIB stand for anyway?
Old 11th February 2005, 12:50   #6  |  Link
bond
you can merge .ogg files, demux streams from .ogg, readout codec info...
this has nothing to do with what ffdshow does imo
Old 18th February 2005, 08:45   #7  |  Link
bond
thanks to k0r0n4, version 0.9.0 is now available
edit: still no oggzrip included
Old 18th February 2005, 14:21   #8  |  Link
k0r0n4
666 byte icon
k0r0n4's Avatar
Yeah, I'm working on that....for some reason MSVC++ doesn't like the project file (even when it tries to convert it it fails). I'm going to make my own project and double check what was in the old one manually (ugh) because it may be the only way to get it to build :-/
Old 18th February 2005, 14:28   #9  |  Link
bond
cool, thx!
Old 18th February 2005, 15:20   #10  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
I cant even make libogg...
k0r0n4, have you tried making it with gcc?
Old 19th February 2005, 02:46   #11  |  Link
k0r0n4
666 byte icon
k0r0n4's Avatar
Newp, this builds natively on windows via M$VC++, so I don't see the point in using gcc.
I think there is a script to convert MSVC++ proj files to makefiles...but I don't recall the name, so you'll have to look around for it.
Old 19th February 2005, 03:20   #12  |  Link
celtic_druid
celtic_druid's Avatar
Compiles fine here with gcc. No need to convert anything, just run ./configure. There was no project file for oggzrip in the source that I downloaded.
celtic_druid is offline   Reply With Quote
Old 19th February 2005, 10:09   #13  |  Link
bond
celtic_druid, did you build oggzrip too? it seems this tool is causing the troubles
Old 19th February 2005, 12:30   #14  |  Link
celtic_druid
oggzdump, oggzed, oggzinfo, oggzmerge and oggzrip.
Did a svn checkout to and there is still no oggzrip project file, so that would be the issue. Bit like h264_parse, etc. with MPEG4IP.. There are simply no MSVC project files. However unlike mpeg4ip oggz compiles real easy with mingw.
I'll put them up in misc if you want to download it.
Old 19th February 2005, 12:33   #15  |  Link
bond
yes plz
Old 19th February 2005, 12:42   #16  |  Link
celtic_druid
Ok, no project file due to the use of getopt with oggzrip.
Old 19th February 2005, 12:56   #17  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
It's here: http://www.aziendeassociate.it/cd.asp?dir=/Misc
Old 19th February 2005, 14:11   #18  |  Link
celtic_druid
Ok, oggzrip compiles ok with MSVC if you link against libmissing60.lib.
Old 19th February 2005, 20:38   #19  |  Link
bond
can anyone get oggzrip to work correctly?
here it always simply creates a new .ogg that still includes all streams of the input.ogg, no matter if i use -i or -c (no matter what id, codecname you use)
when trying to use the -s option it tells me that there are too many serialnumbers? the input .ogg has 4 streams...
also it doesnt seem to recognize the flac streams as flac, but instead shows "unknown"
Old 19th February 2005, 20:44   #20  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
have you tried both MSVC and GCC compiles? (you can find them following the link i previously posted)
