#1 | Link |
![]() Join Date: Nov 2001
ffdshow with updated vfw Theora encoder available
latest available ffdshow now includes an updated theora encoder (using alpha4) and which now offers the following encoding options:
- 2pass (using the ffmpeg 2pass algo) - high quality: enables full motion vector search instead of the hierarchical motion vector search (logarithmic search) (if disabled it still falls back to full search if the vector returned by the hieararchical one is particularly bad.) in vp3 the disabled high quality mode is equivalent to enabled "quick compress" - sharpness: bascially setting the tradeoff between image details/sharpness and ringing artefacts - noise sensitivity: not sure. i think has some effect on how quanization is done? - pixel/display aspect ratio: usable for anamorphic resize - drop frames: whether to drop frames when target bitrate is overflown by some amount (better disable by default), good for low bitrate video communication - direct .ogg output via the "output -> store frames to external file" option
Between the weak and the strong one it is the freedom which oppresses and the law that liberates (Jean Jacques Rousseau) I know, that I know nothing (Socrates) MPEG-4 ASP FAQ | AVC/H.264 FAQ | AAC FAQ | MP4 FAQ | MP4Menu stores DVD Menus in MP4 (guide) Ogg Theora | Ogg Vorbis use WM9 today and get Micro$oft controlling the A/V market tomorrow for free Last edited by bond; 26th February 2005 at 23:42. |
#2 | Link |
Woot Woot! Gonna try
After updating ffdshow, RealAnine already supports it
download RealAnime and Bencos |
#3 | Link |
MPEG1 FAN ;-)
Let's try it! And... maybe i`ll use after all the Theora (instead VP3)
![]() Edit Still shitty results . VDub crashes, Explorer aswell... neeah. Sticking to VP3 ![]() /Edit Last edited by CQ; 2nd February 2005 at 00:29. |
#4 | Link |
<The VFW Sheep of Death>
MSVCR71?!!! What the heck is this, and why is ffdshow asking for it? It wont work at all unless this stupid thing is somehow installed... Where do I get it?
New VfW builds. High quality AVC Guide. Check out DeathTheSheep United today! |
#5 | Link |
#6 | Link | |
Wewkiee
![]() Join Date: Feb 2002
AAAArrrrrrggghhh!!!! |
#9 | Link |
MPEG-4 Crazy Lunatic!
Well, this latest build works great, except for the fact that msvcr71.dll doesn't load, and this causes ff_vfw.dll not to load either... as a result of it, I can't use ffdshow in VirtualDub. And yes, I've chosen vfw to be installed during installation. I think that this is a bug in the latest ffdshow build, because a friend that I sent the latest build to works great with vfw.
#10 | Link | |
In my case, both the msvcr71.dll and ff_vfw.dll are in the ffdshow installed folder, but they don't seem to load for some reason.
#11 | Link |
Think I'll change the installer so that it goes in the system folder, same as ff_vfw and ff_acm, that is if it isn't there already or is an older version. Guess I could also just go back to MSVC6, at least for ff_vfw and ff_acm.
#12 | Link |
or you could just build including the MSVCRT.lib and save having to worry about it. ok the exe size is increased a little bit but its not as if its huge. what an extra 200kb-300kb maybe to the exe size ?
Narrator: And of course, with the birth of the artist came the inevitable afterbirth - the critic. (History of the World part 1) |
#13 | Link |
Well I could link against libc.lib and then set MFC to static.
That way ff_vfw is 28.5k instead of I think 5k. Guess the point is that with ffdshow you have numerous files (ffdshow.ax + all the plugins) and each would have its size increased, all adding up to probably more than just including the MS dll. |
#15 | Link | |
MPEG1 FAN ;-)
Put the msvcr71.dll in the system32 folder (or system on older wins) and that's all you must do. So: install ffdshow (if you didn't already) and then put the msvcr dll in the system folder. No more complications with compiling, building, smashing, crashing
#16 | Link | |
#17 | Link |
dl link seems bad now. reports "permission denied" Anyone else seeing that?
Curator of links at http://neuron2.net (Yes, I know it's woefully out of date...) Collecting 9/11, Afghan/Iraq, Mail Call, Trains, Cooking, Woodworking, Fighting Illini |
#19 | Link |
Hmmm...would the appropriate term for Slashdotted A/V links be "doom9ed"?
#20 | Link | |
clueless n00b
![]() Join Date: Oct 2001
I was not able to download it from that location as well, but you can just download the latest ffdshow from celticdruid: http://www.aziendeassociate.it/cd.asp?dir=/ffdshow
| Thread Tools | |
| Display Modes | |
