#2 | Link |
![]() Join Date: Nov 2002
Don, this is just a cosmetic issue:
A number of the popup message boxes DGIndex produces have the default icon in the upper left corner. A few of the message boxes have no icon. Try loading an avi and look at the message box that appears. Now try loading a JPG file and look at that message box. Originally I though they should all have the DGIndex icon, but now I believe they should have no icon. That is consistent with most message boxes I think. Do what you want, but they should all be consistent. You should check all the messagebox API calls, cause they all appear to be affected, not just the file open messages. (eg: Project Successful is also affected) Besides this, it looks good. EDIT: Originally I said it was DGDecode message boxes, I meant DGIndex messages. I fixed the post. Last edited by Cyberia; 18th January 2005 at 04:43. |
#5 | Link | |
_
![]() Join Date: Jan 2002
![]() After I got over the shock of being asked to load JPEGs, etc., I did in fact notice that one did not have the icon. I compared the calls and it is totally undocumented, but it seems that if you apply the property MB_SYSTEMMODAL, the icon shows up. So I deleted them all. There should be no icons on any popups in RC2. Thanks for persisting in this. |
#8 | Link | |
![]() Join Date: Nov 2001
#10 | Link |
I'm afraid we've to stop
![]() Join Date: Mar 2003
I tested that CLI behaviour - works ok, but when -Exit is not specified the error message is rather puzzling: "Couldn't write D2V file. Is it read only?"
Second part of the error message can be omitted IMHO.
Gordian Knot Family: Gordian Knot: website, download Auto Gordian Knot: Website and download, tutorial, FAQ |
#11 | Link | |
#12 | Link | |
_
Umm, any idea how to demux this stuff? Any specs? Any sample code? |
#14 | Link | |
_
#15 | Link |
Could change the default location of the Windows File Save dialog to open to the same folder as where we loaded the VOBs?
In other words, if I open a vob, then when it comes time to save a project, point the Save dialog to that directory first. I can't think of an easy way to say this. EDIT: Dang, and I speak English natively. OK, pretend I didn't type all that, and instead suggested this: I propose changing the default directory for the Windows Save File dialog (seen when saving a project) to refer to the location of the last VOB opened. Last edited by Cyberia; 20th January 2005 at 19:20. |
#19 | Link |
_
DGMPGDec 1.1.0 RC2
Here is RC2:
http://neuron2.net/fixd2v/dgmpgdec110rc2.zip * Message popups now have no icon in the title bar. * The audio delay calculation for transport files is now correct and reliable. * Added even more bullet-proofing for loading silly files (with sarcastic error message). I'd like to make a full release of this as long as no big problems are found. |
| Thread Tools | |
| Display Modes | |
