#1 | Link |
DivX Pro Codec - Fusion Beta Release
In the last month and a half since the last alpha release of the DivX Plasma codec, the DivX team has been working long hours in ironing out the alpha-ness and are pleased to officially announce that Fusion has begun. The DivX Pro Fusion (IntertialConfinement) codec marks the first beta release in the series and fixes many of the previous issues reported with Plasma.
Check out the full announcement at DivX Labs for the beta download and be sure to leave your feedback in the newly-revamped Beta Release Forum |
#2 | Link |
.. and this time it actually works! I encoded over four hours of content with this build last night
![]() I recommend you avoid the Psychovis right now, we're looking into a small problem there. Aside from that, jump right in and keep us posted of your results.
DivX Plus Web Player 2.0 Beta DivX Tech Preview - MKV on Windows 7 Developer portal |
#3 | Link |
TeacH Me!! I'm so n00b!
Problems with GMC:
![]() My little test: 1)original 2)XVID_2pass@1750-1B-mot.search:6-VHQ:4-trellisON-GMC-MPEG 3)XVID_2pass@1750-1B-mot.search:6-VHQ:4-trellisON-GMC-h263 4)DivxFUSION_2pass(better-insane)@1750Kbps-1B-h263opt.-psvOFF 5)NeroAVC_2pass@1750kbps-1B-deblock:-2-psvOFF-other options ON postprocessingON (auto) Last edited by nicco; 8th January 2005 at 15:40. |
#4 | Link |
Life looks better in HDTV
I think the problem with GMC might be this: -
![]() What do some of you guys think? Cheers
Still confused about anamorphic images? Then look here! | Main Encoding Interests: Hardware device playback | My Gear | |
#5 | Link |
Thanks nicco, I'll log that one so someone can look at it.
Can you tell me a little more about the frequency? Do you see this immediately on turning on GMC, is it rare? Does it only happen on keyframes? Also: Is this the DivX decoder or a third-party decoder? Does it happen with both?
#6 | Link | |
All players/filters tested after having generated encodes in 1pass and 2pass mode. With or without B-VOP and using all current speed modes! Cheers
Still confused about anamorphic images? Then look here! | Main Encoding Interests: Hardware device playback | My Gear | Last edited by SeeMoreDigital; 9th January 2005 at 00:02. |
#7 | Link |
Thanks SeeMoreDigital, much appreciated!
#8 | Link |
I made some comparasion to
I made some comparison to and AVC (in Nero Digital) encoder clearly won. There are a big differents espacialy in very motion scenes.I noticed that divx6 has better quality in static scene and keeps more detail than divx5. I didn't have any problems with stability.
#9 | Link |
SMD already answered for me
I have 2 new question: 1-In Vdub under codec list I have Divx Fusion (working) and Divx Fusion YV12 (not working), what is the lat one? 2-I can not access at decoder config. dialog |
#10 | Link | ||
#11 | Link | ||
Re: I made some comparasion to
![]() Quote:
DivX Plus Web Player 2.0 Beta DivX Tech Preview - MKV on Windows 7 Developer portal Last edited by DigitAl56K; 9th January 2005 at 01:18. |
#12 | Link |
MPEG1 FAN ;-)
In a few months... "Sigma Designs' SMP860 series supports AVC, WMV9, MPEG-2 and MPEG-4 at 1920x1080 30p" Will have a fight (a fair one!) in the standalone MPEG4 ASP & AVC zone .
#13 | Link |
Chips vs devices on the market in volume are two different things.
Take it to a new thread now please, this thread is for the Fusion beta
#14 | Link |
is the settings button back working in the standard vfw window with this release ? not everyone uses or tests on virtualdub.
Narrator: And of course, with the birth of the artist came the inevitable afterbirth - the critic. (History of the World part 1) |
#15 | Link |
hey guys i've just downloaded the new fusion beta and was going thru all the settings but i can't see any check for saving log file for multipass is this just done automaticly now or is it not doing it at all and just wasting any pass after 2???
#16 | Link | |
#17 | Link | |
#18 | Link |
ok i've never really played with them settings before just left them as there defaults i'm looking at it now i can see in the manual cli (-bvn1 3000000 -vbv 9708400,6291456,4718592 -b 1 -nf -profile=4) i can't see anything that to me would mean to write and update logs but i'm just guessing that a couple of them are like -b 1 i'm guessing it's the b frames set to on ect but i'm not 100% sure
what is it that doing the logs in there or what string am i having to add in there for it to?? allso if it counts to anything i'm using gk 33.1 |
#19 | Link |
Default working directory is C:\DivX and will not appear on the CLI.
If you change the working directory in the settings window the new working directory will appear on the CLI as: -dir <path> There is a known-issue in this beta that if you enter an invalid path and begin encoding the encoder will crash, so be careful! It is best to use the "Browse" button on the Settings window for this reason.
| Thread Tools | |
| Display Modes | |
