Thread Tools Display Modes
Old 5th January 2005, 11:55   #1  |  Link
sysKin
sysKin's Avatar
sex264 (updated almost daily by now)
Hi everyone
I just finished "my" first really working build of x264 with up-to-date VfW interface. The GUI has most of the options that core has, including bframes, two-pass, and motion estimation selectors. It's pretty ugly I admit but I don't care
I need testers. Consider this version RC1 - I think it works but I don't feel like testing
The name is sysKin's experimantal x264, or sex264 for short.
Grab it (build and src) at http://syskin.is.dreaming.org/x264/ .
Have fun, and don't forget to report anything that is wrong or missing.
Radek
[edit 9th Jan] New version available.
Visit #xvid or #x264 at irc.freenode.net
sysKin is offline   Reply With Quote
Old 5th January 2005, 12:02   #2  |  Link
Yong
d00m9 Player
sex264, nice name! lol
Yong is offline   Reply With Quote
Old 5th January 2005, 12:55   #3  |  Link
Sirber
Sirber's Avatar
Cool!
What are the *working* features?
[edit]
Install don't work, VDub don't see it .
download RealAnime and Bencos
Sirber is offline   Reply With Quote
Old 5th January 2005, 13:13   #4  |  Link
sysKin
sysKin's Avatar
Whatever x264's core currently has. Ffdshow doesn't want to play its b-frames (asserion error with newest Celtic Druid's build) but Videosoft's decoder plays them fine.
Very bad. This definitely works for me - check if x264vfw.dll got copied to windows\system32\ (ah, maybe you're not administrator?).
Radek
Old 5th January 2005, 13:22   #5  |  Link
Sirber
Sirber's Avatar
I'm administrtator. Second click on the .inf, install. It seems to copy a file but in VDubMod, nothing
[edit]
Tryed with regsrv32.exe, but it said function DLLRegisterServer is not found.
Old 5th January 2005, 13:59   #6  |  Link
bond
np showing up here in vdm
btw syskin you might want to consider using "avc1" as fourcc, its not nice looking, but still its the four letter "fourcc" the mpeg-4 standard defines to use for signalling h.264 in .mp4 (i think it can be taken as the equivalent to the .avi 4ccs)
its already supported by ffdshow
edit3: maybe it would be also nice to add a description to the subpixel options (eg uses qpel, uses hpel aso..)
edit: and how do you make 2pass working in vfw?
for the first pass i assume you use constant quant, what quant do you use?
edit2: two gui problems:
1) the "ok" button in the advanced tab is divided by the bottom line (i hope its clear what i mean)
2) i still get the problem, that when i push the "load defaults" that all values get set to 0 and all options get unticked in the advanced tab
Ogg Theora | Ogg Vorbis
Old 5th January 2005, 14:20   #7  |  Link
Jerry_Sm@rt
great!cann't wait to try it.
Any mirror?i just can not visit that url.
Jerry_Sm@rt is offline   Reply With Quote
Old 5th January 2005, 14:22   #8  |  Link
Tommy Carrot
Tommy Carrot's Avatar
Today's build by celtic_druid can play it back without any problems.
Just a question: what is the recommended b-frame prediction mode, temporal or spatial?
Tommy Carrot is offline   Reply With Quote
Old 5th January 2005, 14:29   #9  |  Link
Shinobu
Satsuki'S Softs Maker
Shinobu's Avatar
no problem at all with this codec, but i'll launch more test this night ^^.
the load default isn't working great on windows 2000, you have to close the config tab of the codec and reopen it to apply the reset.
Satsuki Yatoshi'S Softs
Shinobu is offline   Reply With Quote
Old 5th January 2005, 14:36   #10  |  Link
SeeMoreDigital
Life looks better in HDTV
SeeMoreDigital's Avatar
Hi sysKin,
Will an Mpeg4/AVC implementation, such as this, ever make it into XviD?
Side Note:
I wonder how quickly Doom9 will get round to creating an Mpeg4/AVC section. As the forum is full of such discussions
Cheers
Still confused about anamorphic images? Then look here! | Main Encoding Interests: Hardware device playback | My Gear |
Old 5th January 2005, 15:32   #11  |  Link
virus
Senior n00b
Ok, I've already reported to Radek the most obvious cosmetic flaws, now I'd like someone testing for a more serious issue.
I run several 2pass encodes (settings: all @ default) from the same 1stpass statsfile, just changing the target bitrate. When aiming for medium or high bitrates, everything went fine. But when aiming for low bitrates (450 kbit/s) everything b0rked with an assertion in ratecontrol.c.
According to sysKin, that should happen when the statsfile is shorter than needed... but the statsfile is OK since I run several successful encodes with it. I observed that problem in the past with ffdshow though - at the times it seemed to happen when the 2nd pass average QP was much bigger than the 1st pass one (1stpass is run at fixed QP=26 currently, so you need to go with very low bitrates to trigger it in sysKin's build).
If you can try and see if that happens to you too, that would be great. Thanks!
virus
virus is offline   Reply With Quote
Old 5th January 2005, 15:36   #12  |  Link
hellfred
FFmpeg fan
update sex264
Yesterday i have downloaded an installed 03012005_x264_bin.7z with the right-click-install method.
What is the recomendet procedure to update differen versions of sex264 /vfw codecs in one dll?
Just replace the x264vfw.dll?
regsrv32.exe -u x264vfw.dll and right-click-install the newer version?
And how to uninstall?
regsrv32.exe -u x264vfw.dll and deleting the dll?
Hellfred
hellfred is offline   Reply With Quote
Old 5th January 2005, 15:53   #13  |  Link
bond
maybe someone finds it interesting and so i dont forget about it:
when encoding with x264 vfw with b-frames (eg in virtualdub(mod) you will maybe find out the following (as i did):
- when choosing 2 b-frames -> two zero length frames get placed in the output stream (frames that avi thinks exist, but in fact dont exist ) -> as the output stream has the same framenumber as the input stream this means that practically there are 2 frames too few in the output
- for 1 b-frame -> 1 zero length frame -> 1 frame lost
- for 0 b-frames -> 0 zero length frames -> 0 frames lost
aso...
thats caused by the video for windows (vfw) framework (as used in vd(m)), which is NOT able to handle b-frames correctly on its own (as b-frames are a newer technology than vfw)
i talked about that with syskin and he meant that the old workaround to solve this (using one-byte 0x7f frames) should not be used, as it creates an incompatible stream if the app (eg everything, except vd(m)) doesnt know about it
Old 5th January 2005, 16:01   #14  |  Link
Tommy Carrot
@Hellfred: replacing should do it.
@Bond: that is exactly how the b-frame support works with xvid, if it didn't bother anyone for years, i don't see why it suddenly became a problem with x264.
Old 5th January 2005, 16:04   #15  |  Link
bond
because the workaround working for xvid, doesnt work for avc (in xvid no frames are lost)
you should read the whole post
Old 5th January 2005, 16:08   #16  |  Link
Tommy Carrot
Well, i'm sure syskin will find a simple solution for that.
Old 5th January 2005, 16:16   #17  |  Link
bond
he meant the best is to keep the current way (who cares about 2 frames in a 200000 frames movie )
another way would be to make avery adopt vd to beaware of these lost frames...
anyways just wanted to post that info so it doesnt get lost in the depths of irc
Old 5th January 2005, 17:54   #18  |  Link
JoeBG
stupid
JoeBG's Avatar
I really have no idea how to use it. I downloaded everything, but there is no *.exe. I always thought, a gui has a *.exe.
How does the tool work?
cu
Joe
freedom is just another word for nothing left to loose
JoeBG is offline   Reply With Quote
Old 5th January 2005, 18:29   #19  |  Link
Sirber
Sirber's Avatar
you're supposed ti install it using the .inf, but it failed for me
Old 5th January 2005, 18:42   #20  |  Link
stephanV
gone
I have a small question.
Since i recently (today) found out about the difference between I-frames and IDR-frames, i was wondering: is the keyframe-interval really the keyframe interval? Or is it the I-frame interval? I suppose i could try and found out, but i'd rather have some confirmation about it.
stephanV is offline   Reply With Quote
Thread Tools
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
