Old 2nd January 2005, 06:31   #1  |  Link
squid_80
Windows x64 port
I've been working on porting xvid to windows for AMD64 and I'm looking for people willing to test it. There's so many different options, I figure this is the quickest way to find bugs.
A zip of xvidcore and the vfw frontend can be downloaded here:
http://home.iprimus.com.au/ajdunstan/xvid64.zip
Unzip, right click the inf file, select install.
Getting the 64-bit version of VirtualDub is also a good idea, unless you've got some other way to test it. If VirtualDub crashes it probably won't bring up the familiar crash handler, it will just exit with no messages at all. This is my fault, not VirtualDub's.
This build is using MMX/3DNow instructions, which Microsoft and AMD have said not to do. So it may very well break if they release a new beta or there may be other issues not discovered. I am working on converting the functions to SSE2, but it takes time.
If people want the source I can put it up. I'm using visual studio .net 2003, winddk 3790, yasm-0.4.0 and WinXP for AMD64 1218. I'm not sure how you'd go about compiling with anything else.
KNOWN ISSUES:
None at the moment.
I've only done pretty basic encodings, you guys probably play around with the different options a lot more than I do. So give it a go and let me know what works and what doesn't. Speed comparisons are welcome too, try to make sure the 32-bit build you're comparing against is a 1.1 build.
squid_80 is offline   Reply With Quote
Old 2nd January 2005, 14:48   #2  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
Interesting! I should re-install winxp for 64 bit extended systems and test it.
Old 3rd January 2005, 02:46   #3  |  Link
Joe Fenton
You might check the source for the 64bit Linux version of xvidcore against what you're doing.
http://ayo.freshrpms.net/fedora/linu...PMS.freshrpms/
You'll find an rpm of 64bit xvid source there.
Joe Fenton is offline   Reply With Quote
Old 3rd January 2005, 03:45   #4  |  Link
sysKin
sysKin's Avatar
Or just get it from CVS.
Visit #xvid or #x264 at irc.freenode.net
sysKin is offline   Reply With Quote
Old 3rd January 2005, 06:55   #5  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
this is so f___ing cool. I will test ASAP on my x64 install.
Old 3rd January 2005, 07:06   #6  |  Link
Blue_MiSfit
Problem:
For me at least, I cannot seem to get avisynth to work properly on x64. I have Virtual Dub 64 1.6.1, XviD x64 from this thread, and when I try to open the following script into vdub:
LoadPlugin("H:\PROGRA~2\GORDIA~1\AviSynthPlugins\dgdecode.dll")
LoadPlugin("H:\PROGRA~2\GORDIA~1\AviSynthPlugins\UnDot.dll")
mpeg2source("D:\Family Guy Disc 3\213 - Road to Rhode Island\Road to Rhode Island.d2v")
Undot()
It refuses to open and says AVI Import Filter Error - (Unknown) (80040154)
I have avisynth 2.5.5 installed (albeit in 32 bit mode as I don't know of a 64 bit compile).
Ideas?
Old 3rd January 2005, 07:39   #7  |  Link
squid_80
Originally posted by Blue_MiSfit
Problem:
Undot()
Ideas?
VirtualDub is 64-bit, avisynth is 32-bit. They can't work together.
But if you've got the xvid stuff installed, hopefully you should be able to open and encode xvid avis. VirtualDub also natively supports MPEG-1 files I think, if you've got any VCDs lying around.
Old 4th January 2005, 04:31   #8  |  Link
Blue_MiSfit
So... I can play existing XviD content (awesome), but there's no way to serve decoded (from a d2v) YV12 frames into vdub right now?
Old 4th January 2005, 05:43   #9  |  Link
ObiKenobi
Posts: n/a
Not until there is a 64-bit version of Avisynth.
Old 4th January 2005, 11:10   #10  |  Link
ChronoCross
Does it really matter?
ChronoCross's Avatar
Kinda Defeats the point of having 64-bit versions of vdub and xvid since 90% of all encoded content today is done through avisynth. Perhaps The avisynth guru's should get to work on a x64 port.
ChronoCross is offline   Reply With Quote
Old 4th January 2005, 17:39   #11  |  Link
superdump
Posts: n/a
If you have large amounts of HDD space, you could find some 64-bit optimised lossless codec and filter everything to a lossless file and then process it directly from the lossless file. Would that help?
Old 4th January 2005, 21:38   #12  |  Link
squid_80
I've been thinking the same thing. A 64-bit version of huffyuv probably won't be too hard to do. Are there any other lossless codecs with source floating around?
Old 5th January 2005, 04:02   #13  |  Link
Blue_MiSfit
I've been looking for a good lossless codec that would work in both 32 and 64 bit modes and I'm not seeing anything. I guess I will have to transcode some pre-existing material (MPEGs or an XviD AVI) to use for a speed test. Report coming soon.
[edit]
I took an 11:54 352x240 MPEG-1 clip @ 29.97 fps that had fair quality for being low resolution MPEG-1, and recompressed it into XviD using the following settings:
CQ2
Sharktooth's EQM V3HR
Adaptive Quant
Bvops @ 3/1.5/1
Quants 2-31
Trellis
MSP6
VHQ4
VHQ_Bvops
Everything else at default
And I got the following speed results:
XP Professional 32 Bit : 6:36
XP Professional x64 : 6:39
I also did a test with qpel enabled (which did produce horrible artifacts on the x64 edition, as expected) just for comparison and got the following results:
XP Professional 32 Bit : 9:48
XP Professional x64 : 9:55
As you can see, x64 is actually a bit slower. As expected
Just my results here folks,
~misfit
Old 5th January 2005, 21:53   #14  |  Link
Shinigami-Sama
Solaris: burnt by the Sun
Shinigami-Sama's Avatar
I still don't get how an encode ona 64bit system could be slower
it makes no sense
theres more of well everything :\
and extra 32bits increases teh amount of memory accsed a secnod by 2^23 more
and there aer more registers in teh 64 cpu
granted the clock speed is somewhat smaller
but amd makes up for that in decrased latancy and bottlenecks
it seems to defy logic :\
and another test should be done when avisynth64 come out
because it is kind of a slanted test unless there was no avisynth on the 32 encode
and test was made off a vcd?
isn't to low quality to make a vaild test?
I mean I find vcds hard to watch to begin with because of teh low detail
*heh funny thing I've noticed in this forum more so over others i syou guy seem to use "as" as "because" which is improper
just a bit of fyi*
Originally Posted by benjust View Post
interlacing and telecining should have been but a memory long ago.. unfortunately still just another bizarre weapon in the industries war on image quality.
Shinigami-Sama is offline   Reply With Quote
Old 5th January 2005, 22:59   #15  |  Link
chilledoutuk
chilledoutuk's Avatar
sort of defeats the point of 64bit optomised code as the only advantage to be had is faster encoding.
When microsoft pulls there collective thumbs out of there arses pehaps they will finally release the 64bit version of windows xp. Then there will be more incentive for 64bit versions of applications such avisynth.
HQ XviD Music Video Forum
When I'm good I'm very, very good but when I'm bad I'm better.
chilledoutuk is offline   Reply With Quote
Old 6th January 2005, 04:33   #16  |  Link
Joe Fenton
Actually, all this shows is that all the time is being spent in the areas that weren't optimized to take advantage of the extra resources in 64bit mode - i.e., the hand optimized MMX assembly routines. That makes sense... they made the routines in the first place because they do the majority of the work. You stated earlier you are using the same routines, so you aren't getting the benefit of 64bit. Those routines need to be converted to make use of SSE2 and the extra 8 SSE registers to REALLY see what it is capable of.
People always get confused when doing optimizations. They optimize something that is using less than 2% of the CPU and wonder why it's not any faster. You'll see that a lot as 64bit becomes more prevalent. People will be compiling programs with no regard as to what really needs optimizing and therefore see no improvement. What good is it to make the GUI 64bit -O3 optimized code when the rest of the program is optimized 32bit assembly? Rather extreme example, but it makes the point. You have to optimize the right parts of the program to see any improvement.
Most filters and codecs use hand-optimized assembly language subroutines that have been worked out to give the best results on a 32bit x86 CPU. These routines will have to be rewritten, some completely, for 64bit before multi-media takes a jump forward.
Old 6th January 2005, 08:28   #17  |  Link
squid_80
Is this directed at me? I never said this was an optimized build and I expected it to be slower than 32-bit. I put it here for two reasons: to unearth any serious bugs (crashes, bad output) and to give people a codec to use with vdub64. The only reason I said speed comparisons are welcome is because I expect them to be more or less the same, any significant difference should be investigated.
Old 6th January 2005, 23:17   #18  |  Link
Joe Fenton
Oh - well then, you succeeded.
I wasn't sure if you had expected it to be faster or not. Guess I should have reread the first posts. I missed that the first time through.
Well, at least it's about the same speed. I'm looking forward to when people start optimizing for 64bit. Even an extra 10 to 20% would be a help on a several hour long encode.
Old 7th January 2005, 00:11   #19  |  Link
squid_80
Maybe. Only one tester so far, I wouldn't declare it bug free yet.
I think I've found the problem with qpel, I'll fix it and add a few new sse2 functions some time this weekend.
Old 7th January 2005, 02:29   #20  |  Link
Joe Fenton
No, I meant in making it slower.
You said you expected it to be slower - and you succeeded.
I don't currently have XP64 installed or I'd check it as well. I mostly stick to FC3 64bit these days. I haven't booted my main system into Windows in months. I've got a BP6 I use for Windows stuff right now.
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
