#1 | Link |
NuMenu4u
![]() Join Date: Nov 2002
NuMenu4u RC4 B1.2
New build available.
bug fixes: Now correctly changes the avs script for field order in format conversion. CBR now uses the AVG bitrate given not a default of 9000 CBR for stills is now set to max of 8000 Change to GOP settings for conversion - it was restricting N=3, N/M=4 even in NTSC->PAL Alteration to a pgc/button command. Was not getting the correct GPRM value - was resulting in a Scenarist error. Internal fixes to the UOPs script creation and cc file creation when using recovery console. Enhancements: Now processes the PGC command for GOUP where the command is ffff -> Resume PGC. This was causing an overflow error also. Option in Default tab to force a min duration for bmps. Only use if absolutely necessary!! http://www.numenu4u.com/NuMenu4u.zip http://www.numenu4u.com/Automate_Scenarist.zip Also an updated Automate.
NuMenu4u here |
#2 | Link | |
Re: NuMenu4u RC4 B1.2
/Eriksen76 |
#4 | Link |
Hi Zeul! First of all I would like to congratulate your job (Numenu). It's very useful program. But now I have a problem. I did the menu of LoTR 2 Extra version. When the program was running there was nothing problem. But when I checked the new menu, I recognised that every navigation buttons were missing.
Do you have any solution of this problem? |
#5 | Link | |
/Eriksen76 |
#8 | Link |
NuMenu4u
What is the full error message ie the call stack that is shown.
I don't see how you can get that, the largest thing that is stored in the memory is the vob file in the Subtitles folder - rarely is that more than 4-5 MB in size.
NuMenu4u here |
#10 | Link |
NuMenu4u
hmmmm
Unsure on this one. I will try & provide a special build that logs every process right from the start, to pinpoint the problem. BTW what other processes are running at the time? Please pm me your e-mail.
NuMenu4u here |
#12 | Link |
![]() Join Date: Oct 2003
metatron81,
please see this thread: NuMenu Error Files which is what zeul was referring to , which will explain what files are needed.while i am here i would like to personally thank zeul for all of his amazing work and development of muneu4u this year, and to wish him (and family) a merry christmas and happy new year! zeul, i will be thinking of you as i lay on a sunny beach enjoying a frosty cold glass of beer ... ahhhh .. summer ... its a beautiful time of year rock on j |
#13 | Link | |
![]() Join Date: Oct 2001
There seems to be a serious error with the bug report system. I tried to generate a report and when I selected the working directory (on the C: drive) it said there were 258 files to be included. Not knowing what type of files you needed I didn't think anything of it until I checked out the .zip file that was generated and found literally every .log and .txt file on my system drive (D: drive).
I just wanted to warn people before they accidentally send out personal information. I will try to manually gather the files and send in a report later today or tomorrow. The error was on Shrek 2, R1, in Scenarist export: Quote:
UPDATE: I sent the files. I had an email problem so I apologize if you received multiple copies. Last edited by wmansir; 24th December 2004 at 15:00. |
#14 | Link |
I've run into the following little problem with numenu (using the lastest version): If the menu has quite a few assets to encode with cce (more than 20 or so), I get a out of memory error and it shuts down. I have searched the forums but haven't found any solution.
Mac |
#15 | Link |
NuMenu4u
Mac Sidewinder
Try setting the ecl value in encoder settings, to a low setting. I have seen 2 out of memory errors now, since i introduced format conversion, beats me why!!
NuMenu4u here |
#16 | Link |
NuMenu4u
wmansir
I am aware of this problem, but as hard as i try, it NEVER fails for me. So to find out why? Please could you explain your exact settings for me to replicate. ie: drive that the iso image is stored mounted drive used exact output folder name.
NuMenu4u here |
#17 | Link |
Zeul sorry for the late reply. Did you receive the error report in the email?
For that job the source was an .iso on the E: drive mounted with Daemon Tools v3.47 to the K: drive. The output folder was C:\Shrek_2_US_16x9 The source was an unmodified I ripped it from the DVD using DVD Decryptor 3.2.2.0 (which I just noticed is out of date) in FILE mode. I then noticed the large menu and used ImgTool 0.91 to make the .iso. Within the next couple of days I will try to do some more test to see if it's my system or just this particular disc. I just did a quick test with a small stills only menu on a disc I just happened to have in my drive and it compiled and completed fine. I'll try some menus with video re-encoding later, but I have an encoding job running already so it will have to wait. @ Mac Sidewinder Are you receiving the memory error from NuMenu or does it come from CCE after it has encoded for a little while? If it is CCE then check Q14.3 of the CCE FAQ in the CCE forum. |
#18 | Link |
Actually I get the error when it is reading the avs scripts into cce. When it gets to about 25 or so I get this error. I am using 2.67.00.23 so I will try the fix listed in the faq. Since CCE didn't even start to encode, I didn't think this was causing it. Will let you know. Thanks
Mac |
| Thread Tools | |
| Display Modes | |
