Thread Tools Display Modes
Old 19th December 2004, 15:50   #1  |  Link
celtic_druid
celtic_druid's Avatar
XviD 1.0.3
his is XviD 1.0.3 bugfix release.
This release fixes very minor bugs. It is source and binary compatible
with the previous version.
As a sidenote, the 1.1 is maturing fast these last weeks and it's quite possible
Santa Claus could bring you an official beta release of this new tree before the
end of the new year.
The 1.1 tree brings a fair number of optimizations in the decoder, better quality
and more speed for the encoder, a brand new PowerPC port, a Linux AMD64 port...
Changes since 1.0.2:
* xvidcore
- Fixed trellis optimization overflow for quant <= 2.
- Don't read too short streams. This prevents from reading useless
stream garbage.
- Fixed 64 bit crashes because of addressing assuming 32bit integers. (Andre Werthman)
- Fixed 2 diamond search bugs (one was causing searches in wrong directions,
the other one was causing an early exit)
* VFW frontend
- Better stride calculation
* DShow frontend
-- Edouard Gomez
http://ed.gomez.free.fr/
celtic_druid is offline   Reply With Quote
Old 19th December 2004, 16:40   #2  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
For the lazy ppl here you can find some new builds from celtic_druid (including xvid 1.03).
Old 20th December 2004, 03:28   #3  |  Link
ookzDVD
DVD Rebuilder!
ookzDVD's Avatar
I'm waitng for Koepi's Build :)
I better wait for Koepi's Build.
I think you know why
ookzDVD is offline   Reply With Quote
Old 20th December 2004, 04:04   #4  |  Link
ObiKenobi
Posts: n/a
Re: I'm waitng for Koepi's Build :)
Why bother? He's already put out a 1.1 build so why would you want to wait for a 1.0.3 build.
Old 20th December 2004, 11:37   #5  |  Link
Koepi
Koepi's Avatar
Anyways my 1.0.3-build is up now. I couldn't check the installer since i did the compiler-switch-setting/compiling over VNC. Would be nice to get feedback if it works then
Regards
Koepi
Koepi is offline   Reply With Quote
Old 20th December 2004, 12:04   #6  |  Link
r0cket
r0cket's Avatar
Well, yes, the installer does work.
But I'm very missing those DXN profiles Nic provided in his builds
r0cket is offline   Reply With Quote
Old 20th December 2004, 12:39   #7  |  Link
SeeMoreDigital
Life looks better in HDTV
SeeMoreDigital's Avatar
Just tried celtic_druid's and Koepi's builds,
Just the following observations so far: -
01 - Under the "Aspect Ratio" tab, can the "Picture Aspect Ratio" please be corrected to say "Display Aspect Ratio"?
02 - By default, "Display Encoding Status" is always switched on. While the function is useful, I don't think I'm the only one, who would prefer to have it turned off, by default..... Or am I?
03 - I see the trusty old "decoder filter" is being used. What happened to the proposed new filter that could detect PAR/DAR signalling?
04 - Obviously, B-VOP encodes do not work with my Xcard
Cheers guys
Still confused about anamorphic images? Then look here! | Main Encoding Interests: Hardware device playback | My Gear |
Old 20th December 2004, 14:27   #8  |  Link
celtic_druid
01 & 02 I could fix. Wouldn't be a vanilla 1.0.3 compile then though, would have to call it something else.
03, it is v1.0.3, it isn't supposed to have the new decoder, that is only for cvs head/1.1 builds.
Old 20th December 2004, 18:53   #9  |  Link
niamh
Dismembered
niamh's Avatar
02. personally, I'm perfectly happy to have it on by default, it's the first thing I look at(and the last). A good middle way would be to have it on, but minimized , because it does behave a bit like a pop-up ad
A sidenote, the thread has been up 24 hours(well, 27), and already 3750 views....WoW.
niamh is offline   Reply With Quote
Old 20th December 2004, 23:20   #10  |  Link
neo75903
The One, as in unique :)
neo75903's Avatar
Caint find koepi's build from his signature site.
Anyway, using celtic_druid's build, thx all for the binaries.
edit: found the link on an other side:
http://www.koepi.org/XviD-1.0.3-20122004.exe
Mr. Anderson, welcome back. We...missed you.
-= Agent Smith, The Matrix Revolutions =-
neo75903 is offline   Reply With Quote
Old 21st December 2004, 04:09   #11  |  Link
celtic_druid
Pretty sure that this comes up every time Koepi releases something, but you probably need to refresh his site shift/ctrl+F5 to clear the cache.
edit: typo
Old 21st December 2004, 06:54   #12  |  Link
Koepi
Koepi's Avatar
Originally posted by celtic_druid
Pretty sure that this comes up every time Koepi releases something, but you probably need to refresh his site shit/ctrl+F5 to clear the cache.
my site shit?
Lovely typo!
Cheers,
Koepi
Old 21st December 2004, 11:24   #13  |  Link
SeeMoreDigital
Yep, the "refresh" page thingy has caught me out a few times in IE6. It also happens sometimes with Doom9's main site!
It's a bit weird because it still happens even when all the files in the "temporary internet folder" and "history folder" are deleted before accessing the web sites...
Cheers
Old 21st December 2004, 11:41   #14  |  Link
lark
Regular User
could that be a proxy issue?
even a transparent proxy somewhere...?
is there actually a different kind of HTTP get, when you do a refresh, so that the proxy could recognize this?
regards
t
lark is offline   Reply With Quote
Old 21st December 2004, 12:14   #15  |  Link
Uli
XviDiver ;)
Uli's Avatar
regards
t
If you use ctrl F5 in IE/FF then these two header fields are added to the HTTP request:
Pragma: no-cache
Cache-Control: no-cache
If these fields are correctly interpreted by the proxy chain you should get the contents from the server and not the cache.
If you get it from server you get
HTTP/1.1 200 OK
If you get it from cache you get
HTTP/1.1 304 Not Modified
Hope this clears things up
greetz, Uli
Uli is offline   Reply With Quote
Old 21st December 2004, 17:29   #16  |  Link
gpower2
Yet another Doom9 member
gpower2's Avatar
What's the differences between celtic_druid's, koepi's and Nic's builds?
I used to prefer Nic's builds since I am a P4 user but since it's been a long time for him to post a build I am a bit reluctant to use it. Am I wrong? Do all of the builds contain CVS definitions?
A big thanks to all of them for providing "little us" with such great builds!
Gp2 says:
Don't be a fool,
just be cool :cool: !
gpower2 is offline   Reply With Quote
Old 21st December 2004, 17:54   #17  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
Usually if the builds are from CVS the differencies are in the compiler (and compiler version) used and from the date the source has been taken from the CVS.
Usually a more recent CVS checkout contains the newer code.
For Athlon CPUs Koepi's and Celtic druid builds are faster, for P4s use the Nic's build.
BTW Celtic druid has the newer compiles.
EDIT: fixed
Old 22nd December 2004, 03:23   #18  |  Link
sysKin
sysKin's Avatar
Originally posted by Sharktooth
Nic's build is a CVS compile plus DXN profiles and VBV. Koepi's is a straight CVS compile from the 1.0x branch (actually 1.03, but does not contains DXN profiles). Also celtic druid build is 1.03 from CVS.
Wait wait, something was wrong here....
Koepi's 1.0.3 build is straight from CVS' 1.0 branch. Koepi's 1.1.-127 build was CVS (at that time) with some modifications - AR in directshow, VBV, and alternative ratecontrol algo.
Nic's build is pure CVS (1.1 branch) but is much newer that Koepi's, so it includes VBV and DXN profiles. But this is because both are in CVS now.
Celtic Druid has two builds, from two branches, both unmodified CVS. Celtic Druid's 1.1 build is 6 days newer than Nic's (at this moment).
Phew
Radek
Visit #xvid or #x264 at irc.freenode.net
sysKin is offline   Reply With Quote
Old 22nd December 2004, 04:39   #19  |  Link
celtic_druid
Basically all of my XviD builds are compiled with ICL7.1, except for the gcc ones.
As Syskin said all of my stuff is pure cvs, other than the stuff in the test folder, however skal's trellis fix was added to the cvs, so even that is basically pure cvs now.
I never did a cvs head build for:
xmm-ed transfer8to16_2() - faster bvop-vhq
add CBP cost as soon as possible (yet another bvop-vhq speedup)
Should probably put one up.
Old 22nd December 2004, 07:03   #20  |  Link
Enigmax
Thanks
Thanks for your CVS builds, Celtic_Druid.
Congratulations to the XviD Team. Very, very nice.
Greetings
Enigmax is offline   Reply With Quote
Thread Tools
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
