#1 | Link |
![]() Join Date: Oct 2001
Muxman - simple DVD authoring
Two years ago (or was it three?) I set about gathering information so that I could write an authoring program. But a couple things got in the way, and all the world got was the information I had gathered.
Now things are finally back to normal. Yes, the crackhead girlfriend is finally gone (my apologies to Germany, where she decided to go next). Anyway, the centerpiece of any authoring program is its multiplexer, so I wrote that first and designed a simple authoring program to test it. It is available at www.mpucoder.com/Muxman My plans are to further develope this into a program rivaling Scenarist. Such a program, however, would not be free. But this program, along with bugfixes and some later improvements, will continue to be available and free. At some point there will be two, or maybe more, versions ranging from free on up. |
#4 | Link | |
Wewkiee
![]() Join Date: Feb 2002
Re: Muxman - simple DVD authoring
Excellent.. great work mpucoder.
AAAArrrrrrggghhh!!!! |
#5 | Link |
Wewkiee
I demuxed one of the features from The Two Towers extended.. disk 4 appendices (the feature that goes into the premiers for TTT) powerdvd plays it fine except for right before the london premier where Billy boyd is talking (about the 2:20 minute mark) it glitches there and you cant rewind over it. Windvd and IFOEdits player both can barely play the output( the video stutters behind the audio the whole way). This is a NTSC (almost pure 29.97) video right off the dvd. Just to parallel i muxed it in scenarist and was fine.
#7 | Link |
Wewkiee
Opened video file D:\TWO_TOWERS_EXT_D4\VIDEO_TS\VTS_01_1 - 0xE0 - Video - MPEG-2 - 720x480 (NTSC) - 16~9 - Letterboxed.M2V, 275750255 bytes. Opened audio 1 file D:\TWO_TOWERS_EXT_D4\VIDEO_TS\VTS_01_1 - 0x80 - Audio - AC3 - 2ch - 48kHz - DRC - English - DELAY -66ms_fixed.ac3. AC3 audio, frame size = 0x300. 10:33:29 Begin multiplex. SeqEnd at 106F880A. SeqEnd at 106F9D6B. Bytes remaining in buffer = 0. 10:34:27 End multiplex. Fields: 34046, VOBU: 1362, Sectors: 145013.
#8 | Link |
The 2 SeqEnd is probably the cause of the problem with this video. There is one part of Muxman that didn't make it for this week that deals with short VOBU's. And SeqEnd can, and usually does, create a short VOBU. Here's what happens: A SeqEnd marks the end of encoding, and also forces the multiplexer to end the current VOBU. If that VOBU is less than 0.4 seconds long it should be merged with the VOBU prior to it. But since Muxman is a single pass multiplexer it doesn't know about this until after it has happened. I'm still working on the process of backing up to join them together. The cases I ran into didn't have SeqEnd close together, so the player was able to recover.
Just bad luck, I hope, on your choice of material. But it is something I'm aware of and working on. I also noticed a negative audio delay. This is something I'm going to be writting about on my website, as it has really gotten out of hand. The bottom line is if you need a negative audio delay something is wrong with the software you are using. I believe it all started with dvd2avi not handling closed GOPs properly, and has persisted like a bad urban legend ever since. Donald Graft (neuron2) has written a corrected version of the program, you can get it here Another source of negative delay is demuxing by VobID. This would be a great idea if implemented properly, but it isn't by any program I tried. What goes wrong? In a seamless VOB joint, like those found within a title, some audio for the first VOB is multiplexed into the second. But during demux all the programs start and stop on the VOB boundary, leaving out the tail end of the audio and grabbing extra at the beginning. But, IF you demux and never pass the video through dvd2avi or avisynth, AND this starts with the first VobID of the title, negative audio delay is not possible, and should not be "corrected" for. |
#9 | Link |
Wewkiee
OK.. I encoded video from the file and remuxed.. now plays perfect on powerdvd.. but the video still stutters on ifoeditplayer and windvd (the audio plays through w/out problems or pause)
here is the new log Code:
Opened video file D:\TWO_TOWERS_EXT_D4\VIDEO_TS\reencode.mpv, 428434548 bytes. Opened audio 1 file D:\TWO_TOWERS_EXT_D4\VIDEO_TS\VTS_01_1 - 0x80 - Audio - AC3 - 2ch - 48kHz - DRC - English - DELAY -66ms_fixed.ac3. AC3 audio, frame size = 0x300. 13:04:24 Begin multiplex. SeqEnd at 19896470. Bytes remaining in buffer = 0. 13:06:03 End multiplex. Fields: 34045, VOBU: 1418, Sectors: 220459.
#10 | Link |
One of the users in the german board, who is not so good in English, asked me to report the following:
This tool does not work well with still menus with audio streams. If there is one video frame, and several "frames" of audio below an beyond, you shall stuff the video stream with NAV packs, as some kind of padding to ensure a consecutively advancing timecode. |
#11 | Link |
jdgljlfljg
Good luck
![]() Shame it doesn't have command-line support though Otherwise I would use it instead of DVDAuthor when doing scripted avi->DVD-Video. For the moment, if I want a GUI I'll use maestro :/
#12 | Link | |
#13 | Link | |
#14 | Link |
Regular User
some bugs or features
i tried muxman briefly yesterday and discovered following:
- cannot select subpictures before video is seleted => crashes (perhaps the same for audio, but i didn't test) - if destination folder doesn't exist, muxman seems to work correctly (muxes), but there's neither any output (at least i couldn't find) nor error messages - not quite sure if 2 subs works, i tried, but at least powerdvd listed only 1 regards t
#15 | Link |
Both of the first 2 are fixed in the next release.
The second subpicture is mapped wrong. Regardless of aspect ratio sub 1 is the 4:3 and sub 2 is LB, which is total nonsense. In order to really fix it more dialog is needed for 16:9 to select the wide, LB, and PS versions of a language (not to mention set the language and extension). So that will take a little time. I hadn't planned to release every day anyway, but to fix as many problems as possible each week. |
#16 | Link |
look forward to using
not sure if you are familiar with subtitle workshop. If you are, I will be loading an sst file into to do some editing and need to know what format to export the subs in. Ifo-edit isnt a format but almost everything else is |
#18 | Link |
The problem I ran into with subs was the huge number of formats and lack of documentation for them. Using the IfoEdit format is admittedly, a hack to add the same functionality as IfoEdit (and therefore get its users to try Muxman). I also ran into many utilities to convert amongst the formats, but that, too, is not a solution.
I believe .sst is a must to support, Maestro's format an option. I just need a good document on the format, or even a good informal explanation. |
#19 | Link |
Life looks better in HDTV
Lovely tool mpucoder... many thanks!
Cheers
Still confused about anamorphic images? Then look here! | Main Encoding Interests: Hardware device playback | My Gear | |
#20 | Link |
hi mpucoder,
great work! Thanks! Unfortunately it seems that muxman has some problems with mp2 files. muxman always says 'audio type not recognized' and it refuses to add the mp2 file. this happens with all of my mp2 files that come from digital DVB capture (Germany, PAL). the mp2 files are demuxed from the captured DVB mpg file using ProjectX and then cut using Cuttermaran. i have no problems using these mp2 files with other programs (Winamp, BeSweet, IfoEdit, Media Player Classic, etc. pp.) if i try to use other mp2 files that i have produced myself with BeSweet by reencoding the original mp2 file from DVB, then Muxman accepts them. i have added the first 100 kB from a mp2 file that does not work with Muxman. (DVB -> ProjectX -> Cuttermaran) Here's the link: http://tinyurl.com/47ef6 greetings, Malcolm |
| Thread Tools | |
| Display Modes | |
