#1 | Link |
Muxing RM files
This is a program to mux RealMedia files.
It can for example combine audio from one file and video from other. It can also extract audio or video from the file. Also avaible is a beta version that can extract streams from SureStream files. It accepts only RM and RMVB files, but you can try converting other formats into RM using dtdrive. I converted OGG into RM and then successfuly muxed it into RMVB. The archive also contain a comand line version. The program is currently awaible to download at http://elwood.webz.cz/RMMuxer.zip The SureStream beta http://elwood.webz.cz/SureStreamBeta.zip Last edited by elwood; 8th March 2005 at 14:57. |
#2 | Link |
if u want to publish it i think the best solution is the following :
find someone to host your archive, edit your thread with the description of your tool and eventually a sample on how to use your tool, and send a PM to Sirber to ask him to add your thread in the realvideo tool topic. i think some people will be happy to made some tests on your tool and report eventually some bugs. PS: for the tool name i think a joinner or a merger is more correct than a muxer (who sound like the possibility to mux and audio and video stream). Good luck ![]() Bye.
AutoDub v1.8 : Divx3/4/5 & Xvid Video codec and .OGG/.MP3/.AC3/.WMA audio codec. AutoRV10 v1.0 : Use RealVideo 10 Codec and support 2 Audio Streams and Subtitles. |
#4 | Link |
about the tool name i am sorry i have misunderstand on of your sentenses it's for that
![]() PS : for the host if you are interested i can host your archive if u are interested, you can send it at : darkcracker#caramail.com i will send you the direct link in PM. Bye.
#5 | Link |
![]() Join Date: Oct 2002
elwood: awesome! I am looking forward to try your muxer.
Sr. Codec Engineer | RealNetworks Codec Group | https://helixcommunity.org/ This information is provided "AS IS" with no warranties, grants no rights, and reflects my personal opinion. |
#6 | Link |
@elwood
Great tool! I would need something similar but in cmdline mode to merge 1 rmvb (video) with 1 rm (audio). Do you think it would be possible to build one?Thanks!
download RealAnime and Bencos |
#8 | Link |
Could be cool
RealAnime is currently in Delphi, I think it can be converted easily from C++ source.
#10 | Link |
lol
what I ment was if you release the source, I can easily convert it to delphi . But IMO, a cmdline merger would be best for most people (in addition to the GUI) instead of my convert in delphi...rmvbmerge.exe -i video.rmvb -i audio.rm -o test.rmvb
#11 | Link |
can be cool...can add this feature to reve...
Projects : (dev stopped) DamBatch, MBatch (generate mkv/mp4 files with aac(+)/vorbis/mp3 and x264/xvid/real or simple avi with h264/mp3 for fast reencoding using mencoder) Website : Damrod.com |
#12 | Link |
Yep. can be a great addition to many tools
#13 | Link |
I have completed the comand line version.
It can be downloaded at http://elwood.webz.cz/RMMuxer.zip I thank Dark-Cracker who helped me started and hosted the first version. Last edited by elwood; 6th December 2004 at 23:03. |
#14 | Link |
great!!!!
i think i will add a tab-panel in reve ;-)
#15 | Link |
So I tried both the GUI and the cmd line tool. In my little test, the cmd line tool worked great! However, when I pressed the Merge button on the GUI, it silently died, and produced a 0 byte output file. Any ideas?
#16 | Link |
Woot woot!
May I add it to RealAnime?
#17 | Link | ||
The core runs in it's own thread and the main program should not quit before the muxing is complete. I will check if my version works(Microsoft Visual C++ sometimes behave very oddly). If the test files are not too big and if I can download them somewhere, I can do some test with them. |
#18 | Link |
For the reference in RealAnime, do I use your real name or your d9 nickname? PM me for it
![]() Thanks!
#20 | Link |
Strange... with the cmdline, I get 100% CPU usage and about 100 KB/s from a 17 sec sample.
C:\Projets\RealAnime\output>rmvbmux.exe -i "C:\Projets\RealAnime\output\temp\int _video.rmvb" -i "C:\Projets\RealAnime\output\temp\int_audio.rm" -o "Y:\Anime\tes t.rmvb" Muxing ******................... after 1 minute... ![]() HW: C: is local disk Y: is samba share on linux 2.6.9 via gigabyte link
| Thread Tools | |
| Display Modes | |
