Old 3rd December 2004, 04:34   #1  |  Link
blutach
Country Member
blutach's Avatar
Bitmap to VOB
Perhaps I should know this and am brain dead today, but can anyone explain the easiest way to turn a BMP into a tiny VOB?
Regards
Les
Only use genuine Verbatim or Taiyo Yuden media.
blutach is offline   Reply With Quote
Old 3rd December 2004, 04:38   #2  |  Link
2COOL
PGC Navigator in Training
2COOL's Avatar
Top of my head...
1. Use TMPGenc to convert BMP to a m2v and later author/remux with IfoEdit.
2.
  1. This way is much quicker.
  2. Create a single blank VOB with BlankVOB.
  3. Create new IFOs with IfoEdit.
  4. Use DVD Shrink's still image function to remux.
Don't forget to set your still time to 255 if you want to preview it later. I prefer this instead since it's free and unlimited as opposed to TMPGenc 30 day trial period with MPEG2 codec.
Note: ensure that you are using the appropriate resolution in BlankVOB. Don't know if you have a horizontal or vertical shot of your photo. You may have to trial and error but DVD Shrink adjusts nicely to image off-sized resolutions.
2COOL
Old 3rd December 2004, 04:41   #3  |  Link
blutach
Country Member
blutach's Avatar
Merci beaucoup 2C. And very nice numbering you have.
Les
Old 3rd December 2004, 05:30   #4  |  Link
2COOL
2COOL's Avatar
Like the blue numbers? I did it especially for you.
2COOL
Old 3rd December 2004, 14:09   #5  |  Link
jsoto
Just a Member
3.- You can make an avs file using dvd2svcd bmp loader.
LoadPlugin("C:\Program Files\DVD2SVCD\Avisynth2.5 Plugins\Avisynth BMP Loader.dll")
Blackness(2)
AssumeFPS(25)
ConvertToYUY2
BicubicResize(720,576)
AvisynthBMP_Loader("My_Path","My_file.bmp")
With Blackness() you can control the numer of frames, and in CCE (or the encoder you use) you can control the bitrate (quality) of the resulting MPEG.
jsoto
Web sites with my tools
http://download.videohelp.com/jsoto
http://jsoto.posunplugged.com/
jsoto is offline   Reply With Quote
Old 3rd December 2004, 17:47   #6  |  Link
sweetness
member
i used to use the TMPGenc method(8000 bitrate 2passVBR) but i found that DVD Shrink does a better job at converting pics to MPEG2.
never tried the dvd2svcd bmp loader, have to give it a shot.
i just love my jacket pictures
some guides
sweetness is offline   Reply With Quote
Old 3rd December 2004, 18:07   #7  |  Link
jeanl
jeanl's Avatar
sweetness, I didn't know you could do that with shink! Can you briefly outline the procedure? Does the re-authoring mode allow that? I always though that shrink could only transcode and I was under the impression that converting a pic to an MPEG2 required some amount of encoding (for the video part).
Jeanl.
A few PgcEdit guides.
DVDSubEdit a free tool to edit subtitles directly inside the vob.
jeanl is offline   Reply With Quote
Old 3rd December 2004, 18:29   #8  |  Link
mrslacker
Junior Slacker
mrslacker's Avatar
I like to use dvdauthorgui to make stills if i want a jacket picture or a custom menu. It uses jpeg2yuv and mpeg2enc. Its one of the quickest methods that I've found. See it.
I'll have to check shrink's method too. I didn't know it did that either!
mrslacker is offline   Reply With Quote
Old 3rd December 2004, 21:25   #9  |  Link
r0lZ
PgcEdit daemon
r0lZ's Avatar
Originally posted by 2COOL
&#141 Create a single blank VOB with BlankVOB, create new IFOs with IfoEdit, and use current DVD Shrink's still image function to remux. Don't forget to set your still time to 255 if you want to preview it later.
He, 2COOL, I like your method 2. When you have a blank VOB with the IFOs stored somewhere on HDD, it's a piece of cake to convert a BMP to VOB! Good idea!
r0lZ
Old 3rd December 2004, 21:37   #10  |  Link
sweetness
member
well, it doesn't make a m2v file, it makes a vob that can be demuxed and resized.
just open any dvd and in re-author mode (shrink converts the pic to the resolution of the title)drag your tile and then with start/end move the end slider to to the beginning. you will get something like 15 frames. then compression setting is set to still image.
demux and resize for jacket picture.
some guides
Old 3rd December 2004, 21:41   #11  |  Link
r0lZ
PgcEdit daemon
r0lZ's Avatar
You may also use the 2COOL method: just open a dummy DVD with only one VTS with one blank frame. Then, replace the black frame by your still image. Use the Still Image compression setting.
r0lZ
Old 3rd December 2004, 21:52   #12  |  Link
sweetness
member
actually it was my method see here. but that's all cool
oops, about the resize. my bad, you still have to reencode.
BTW 2cool. is that a bug??
some guides
Old 3rd December 2004, 23:09   #13  |  Link
blutach
Country Member
blutach's Avatar
I've now used DVD Shrink 3 times to do this. Easy as (American?) Pie
Thanks guys.
Rgds to all
Les
Old 4th December 2004, 01:35   #14  |  Link
2COOL
2COOL's Avatar
The only similar parts of our method is that we used DVD Shrink and it's still image function. I know you corrected yourself but to clarify to others, you used re-author mode and set end sector. While I used Full disc backup only. Anyways, no personal offense from me.
Not a real one but one of my main superheroes I grew up with during my childhood. That's V3.
http://incolor.inetnebr.com/stuart/riders/
2COOL
Old 4th December 2004, 02:54   #15  |  Link
blutach
Country Member
blutach's Avatar
Looks like a bug
Les
Old 4th December 2004, 03:00   #16  |  Link
2COOL
2COOL's Avatar
&#33&#34
2COOL
Old 4th December 2004, 18:15   #17  |  Link
sweetness
member
@2cool
you know i still can't get shrink to still compress a dummy(blank) DVD. it just jumps back to automatic. anyone else have this happen? or know how to fix this?
oh about the jacket picture for the large J00___5L.MP2(or J00___6L.MP2) you don't need to resize but for the other two you would have too. but who has a tv that shows the other two anyways?
some guides
Old 4th December 2004, 18:23   #18  |  Link
r0lZ
PgcEdit daemon
r0lZ's Avatar
DVDShrink cannot compress a single frame, because it's a keyframe. That's normal.
However, you can replace it with another picture (BMP, JPG or PNG) if you select the Still Image compression. This works in Full Disc and Reauthor modes.
r0lZ
Old 4th December 2004, 18:39   #19  |  Link
sweetness
member
it works now. and i found the problem too. if you create the ifo with ifoedit .971 it works. but if you use .96 to create the ifo dvd shrink will not allow you to select still image, it jumps to automatic. try it.
some guides
Old 5th December 2004, 04:30   #20  |  Link
blutach
Country Member
blutach's Avatar
Sorry to jump in again, but supposing I had a BMP (say it was copied with PgcEdit) and I wanted to overwrite the image with some text. Now the image isn't perfect because of the anamorphic representation and any text I overwrite on it will be distorted when played back.
And ideas on how to overcome this?
Regards
Les
