#1 | Link |
Wewkiee
![]() Join Date: Feb 2002
BatchUpdateIFO 0.9.0.10b
Started a new thread since the change list was getting long.
Here is the origional post which contains a quick tutorial http://forum.doom9.org/showthread.php?s=&threadid=76630 Find it at http://bui.dvd2dvd.org NOTE: if batchupdateIFO does not run for you do the following--> Code:
download this -- BatchUpdateIfo - Framework This installer includes common dialogue for many controls for windows for all programing languages and mfc/c++ .dlls needed for use (Thanks to DarkListener for the installer and hosting it!) - Fixed - what 09010 broke (cell command table update) 0.9.0.10 - Fixed - Handles 0 cell authored properly (0 cell originals werent a problem.) Muxman is able to create pgcs with 0 cells in compiles so this had to be addressed. Also updates end byte of pgci_srp table to new size if changed. 0.9.0.9 - Fixed - When angles are removed chapters are updated to reflect the change. Since i was there i fixed the code for when the authored pgc has more cells than the original. (it should take any quantity of cells in the pgc you can legally create. ) 0.9.0.8 - Added - 'Reverse' mode which will put the final files in the Authored directory (Only Copies files in Batch Mode). This was Eyes'Only's idea to make it easier to use IMGTOOL, also leaves original dir alone. The ifo's update in the same direction but the files in the original directory are left untouched (in Batch mode). Backup files are placed in the original directory. - Added - Option to only copy sub streams or audio streams separately. - Added - Progress Bar for copying routines during Reverse Update. (if you d-loaded before feb-28 8:40pm EST then redownload.. corrected a tiny oopsie adding the progress bar routine caused) 0.9.0.6 - When copy audio/sub tables option is on it now also updates the vtsi_mat table offset 0x200->0x400 which is the audio/sub stream tables. prior version only updated the pgci audio/sub tables. this was fine as long as extra audios/subs werent added. - thanks lev for finding this issue 0.9.0.5 - Correct FSEEK problem during RCE removal <thanks [slim]d12 for pointing out the issue> 0.9.0.4 - Some Pro DVDs have PGCs with no Programs or cells in some of the IFOs. I coded this condition as an error and you would get a PopUp that a 0 cell PGC existed and that VTS would be skipped. BatchUpdate now will process such DVDS. It will now also take authored IFOs with PGCS with no programs/cell. If cells existed on the original they would reflect as 0 in the final IFO - Fixed errors in the ifo summary routine (didnt effect the update process).. I used parameters from IFOEdit that I assumed to be right but were not. Thanx to Dest for catching it. - Other Stuff As before the sources are available upon request via the GPL (If you would like to see my poor programing skills )
AAAArrrrrrggghhh!!!! Last edited by Trahald; 12th June 2005 at 19:34. |
#6 | Link |
Bavarian Ripping Angel
Hi Trahald,
as I mentioned that this will not work was an mistake sry. I got an other error not the same is I thought first. I had also to download msvcr71.dll. BatchUpdateIFO worked with this 2 .dlls fine 4 me thx Trahald for this tool |
#7 | Link |
Wewkiee
yeah.. i would have to link to that dll as well..anyways.. i just reuploaded a version of 0906 with mfc statically linked so the dll files arent needed anymore. so redownload 0906 again if you dont already have newest mfc on your system.
oh and thanks dl
AAAArrrrrrggghhh!!!! |
#9 | Link |
Wewkiee
yeah.. all it does is pull the pgc info over from the authored ifo.. batchupdate doesnt really have to know whats going on in the stream. what makes seamless branch really work is in the vobs which i dont have to touch. i dont think ive tried a seamless multistory since i made it tho.. i might try t2 tonight.. or if i can find my matrix (my empty dvd case is in one box .. the disk is probably mixed in one of my spindles in another box.. wish me luck) the fun of moving
![]() something you may already know... keep in mind that the result will be what scenarist gives which is a non-seamless multistory.
#10 | Link |
Hi Trahald
I made an "BatchUpdateIFO FrameWork" ![]() it installs and reg. COMDLG32.OCX, mfc71.dll, msvcr71.dll. It has only to be installed once and you can make your .exe smaller like .net FW ![]() .BUI FrameWork If some filemirroring is needed tell me I have some traffic over
#12 | Link |
You better link it at your first post under
NOTE: if batchupdateIFO does not run for you do the following--> or your hp or nobody will find it ![]() Only if you like it 4 mirroring -> pm or irc (nick Dark(y)or Shugo) anytime you need
#17 | Link |
Team Noob
.BUI FrameWork link dead
Had to reinstall windows and batchupdateifo don't work anymore so I figgered I need the .BUI FrameWork but the link no longer works.
Is this temporary?
...sometimes it's like trying to chop down a tree with a butter knife. |
#19 | Link |
Team Noob
Thanks muppets, I will do that.
Update: For those who have trouble finding the files (comdlg32.ocx, mfc71.dll, msvcr71.dll): http://www.dll-files.com/dllindex/index.shtml http://freeware.it-mate.co.uk/?Cat=OCX_Files Update2: hummmm... Ok, now where do they go? I using Windows XP Pro. Readme's with dll files say to put in system folder. Is this correct? They do not go in the system32 folder? And where does comdlg32.ocx go?
...sometimes it's like trying to chop down a tree with a butter knife. Last edited by Raster; 7th March 2005 at 11:09. |
#20 | Link |
Wewkiee
i believe the all go into system 32 (nt oses)... the mfc dlls arent needed at the moment (i went back to compiling them into them into the exe) .. but the common dialog (ocx) is. it can be registered by doing the following after you put them into the system32 directory
Windows 95, 98, or Me: regsvr32 \windows\system\COMDLG32.OCX Windows NT or 2000: regsvr32 \WINNT\system32\COMDLG32.OCX Windows XP: regsvr32 \windows\system32\COMDLG32.OCX
| Thread Tools | |
| Display Modes | |
