#1 | Link |
![]() Join Date: Oct 2002
RealVideo 10 "Winter 2004" update
Download:
Helix Binary Downloads Readme.txt: Changelog: ** 2004-12-06: Fix for rcBestPSNRMode introduced 11-24. Affects all encodes. Please update when you have a chance. ** 2004-11-24: Fix for parameter firstPassComplexity. This was in most cases ignored, and always set to 50 for the new R/C and 65 otherwise. ** 2004-11-08: Fix for Medium EHQ complexity, which almost no one is using. No need to update if you are not. ** 2004-10-28: fix for chromaModeDecision on single CPU systems (no hyper-threading or multi-proc) - chromaModeDecision always ON for EHQ 100 ** 2004-10-25: added option <chromaModeDecision> This option takes chrominance (or color) into account when choosing the best encoding modes. Fix: encodeAllFrames and rcBestPSNRMode would always be ON if included in audience, if if set to 'false' Fix: long standing bug where if Constant Quality less than 20-30 and EHQ greater than 70, bitstream could not be decoded. Thanks to Satsuki for discovering the problem. ** 2004-10-22: fixed bug related to the new EHQ100 Here is an updated RV10 encoder DLL with some small changes that have been added since the last release. This is not all we have been working on, of course, but we figured it would be useful to have this in the community. Replace erv4.dll in Producer's codecs directory. Remember to back up the existing one. This DLL may (as always) contain new bugs... 1. Improvement to EHQ 85 and higher, additional coding mode 2. minor improvements to EHQ 100 These combined will provide some improvement in quality, but not anything like EHQ did. There is no need to perform detailed comparisons. 3. new option <chromaModeDecision> This option takes chrominance (or color) into account when choosing the best encoding modes. 3. new option <encodeAllFrames>, which in streaming RC mode forces encoder to encode all frames. In curve compression RC mode, this has always been the case, and the option is not needed when the CC RC mode is used. 4. new option <rcBestPSNRMode>. In curve compression RC mode, sets parameters in a way that testing has shown provide the best PSNR, in addition to a small codec change. This may not always correspond to best visual quality. This option is mostly applicable to the new RC mode, not the old streaming RC mode. The settings rcBestPSNRMode imply are: patternAdaptivity => 2 rcHighBitrateReduce => 60 rcPFrameRefQuant => 6 rcBFrameRefQuant => 12 + the internal codec improvement Experiments show an improvement generally from 0.25 - 0.5 dB, but of course, your mileage may vary. New options are used like this: <codecProperties type="bag"> <chromaModeDecision type="bool">true</chromaModeDecision> <rcBestPSNRMode type="bool">true</rcBestPSNRMode> <encodeAllFrames type="bool">true</encodeAllFrames> </codecProperties> The same settings are available in the registry, standard location. [HKEY_LOCAL_MACHINE\SOFTWARE\RealNetworks\RV9] "chromaModeDecision"=dword:00000001 "rcBestPSNRMode"=dword:00000001 "encodeAllFrames"=dword:00000001 Note that even though I listed both rcBestPSNRMode and encodeAllFramesON, it really does not make sense to use both at the same time, since encodeAllFrames applies to the old rate control, and rcBestPSNRMode to the new rate control. As usual, let us know of any problems. -- Karl.
Sr. Codec Engineer | RealNetworks Codec Group | https://helixcommunity.org/ This information is provided "AS IS" with no warranties, grants no rights, and reflects my personal opinion. Last edited by karl_lillevold; 10th December 2004 at 19:01. |
#2 | Link |
Cool! Releasing RealAnime 2.22
download RealAnime and Bencos |
#3 | Link |
Some tests
On my 2000+, using 1-pass CQ65 EHQ100, it takes ~4 sec to encode ~.5 sec
#4 | Link |
I rolled back some initial EHQ100 changes, and now encoding speed at EHQ100 should be about the same as before, still with some improvement/bugfix included.
Sr. Codec Engineer | RealNetworks Codec Group | https://helixcommunity.org/ This information is provided "AS IS" with no warranties, grants no rights, and reflects my personal opinion. |
#5 | Link |
I'll check my logs tomorrow to check if I go up to 3h / file. Speed is not that important, and I'm glad you did this update before winter, I'll be able to heat my room while encoding!
#6 | Link |
Average 2h30 per file.
#7 | Link |
Testeur de codecs
1) RV10 seem to be better with high sensitivity for bframe. XviD regulate bframe number with BVOP sensitivity: perhabs a good idea for RV10 ... ?
2) Why RV10 put always 0, 1 or 3 consecutives bframes but never 2. RV10 seem to have no bug with 0, 1, 2 or 3 ? (I test that with first pass XviD stat file in producer for second pass ... lol)
Le Sagittaire ... ;-) 1- Ateme AVC or x264 2- VP7 or RV10 only for anime 3- XviD, DivX or WMV9 Last edited by Sagittaire; 20th October 2004 at 16:44. |
#8 | Link |
2-pass VBR seems faster than 1-pass CQ
#9 | Link |
Sagittaire:
1) I am not sure I understand.. "high sensitivity for B frames".. RV10 also decides # of B frames based on video complexity, but there is always room for improvement. 2) In particular this aspect can be improved. The frame queue implementation has made it hard to include 2 when the number of B frames is to be decided (1st), but not a problem in a fixed pattern, or when specified in the .pass file (nice experiment you did..!). This too is something that will be improved one day. Sirber: "seems" There is an invention called a stopwatch. You press a button to start a timer, then press again to stop the timer. The stopwatch will then display the amount of time that has passed from the time you pressed the start button until you pressed the stop button. It is sometimes quite useful 1-pass CQ at 100 might be slower than 2-pass at 85, since the 1st pass is always very fast. At the same EHQ, 1-pass will be faster.
#10 | Link |
My encode is finished.
1-pass CQ65, EHQ100: average 2h30 2-pass VBR, EHQ65/100: average 2h30
#11 | Link |
Sirber: nice. shows that 2-pass 1st past is super fast, and 2-pass is great to achieve a target filesize/bitrate.
#12 | Link |
The patternAdaptivity was set to 2 in the rcBestPSNRMode, does this also give the best psnr for anime? I remember reading the patternAdaptivity = 1 gives the best result for anime sometime ago.
The second question is that does rcBestPSNRMode override rcHighBitrateReduce and other setting it changed in jobfile? |
#13 | Link |
I fixed a bug that was introduced with this update, related to EHQ100. Download same location as given in first post. Thanks again to Sirber for finding it.
haibane: sorry for the delay. I don't know whether or not the 'shortcut' rcBestPSNRMode always results in best PSNR for anime. For your second question, see my post below.
Sr. Codec Engineer | RealNetworks Codec Group | https://helixcommunity.org/ This information is provided "AS IS" with no warranties, grants no rights, and reflects my personal opinion. Last edited by karl_lillevold; 22nd October 2004 at 19:53. |
#14 | Link |
From my test, in general, oldRC and CQ gives the best results for anime content.
download RealAnime and Bencos Last edited by Sirber; 22nd October 2004 at 19:23. |
#15 | Link |
haibane: All "uint" types are set before "bool". Thus, 'rcBestPSNRMode' will over-ride all "uint" settings. So if you want your own settings for the parameters rcBestPSNRMode is a shortcut for, you have to remove the rcBestPSNRMode parameter.
#16 | Link |
Testeur de codecs
I think that Average PSNR isn't a good tool for testing Rate Control quality: Overall PSNR or Frame PSNR graph are very better. Average PSNR must be very better with CBR than VBR. For example sample with very long/very "low motion" part and very short/very "high motion" part done very better Average PSNR for CBR.
Best PSNR mode for RV10 use rcHighBitrateReduce = 60. it's a very high reduction for bitrate modulation. Quality is higher for "low motion" but worst for "high motion". it's a very good strategy for Average PSNR but not for Overall PSNR.
Le Sagittaire ... ;-) 1- Ateme AVC or x264 2- VP7 or RV10 only for anime 3- XviD, DivX or WMV9 Last edited by Sagittaire; 22nd October 2004 at 20:08. |
#17 | Link |
Sagittaire: I agree. the rcBestPSNRMode shortcut is not meant for anything but experiments, and to show that best PSNR does not correspond to best visual quality, or constant quality.
#18 | Link | |
Testeur de codecs
sensibility = -25: Code:
i 6 680 0 0 1971 1953 p 6 113 547 20 3217 1154 p 6 293 354 33 4034 1703 p 6 353 327 0 4917 2047 p 6 45 622 13 4485 1246 p 6 88 591 1 4021 1416 p 6 54 610 16 4277 1233 p 6 53 625 2 4185 1314 p 6 85 595 0 4645 1374 p 6 41 638 1 4751 1296 sensibility = 0: Code:
i 6 680 0 0 1971 1953 b 10 0 680 0 445 373 p 6 270 384 26 4143 1591 b 10 0 680 0 1134 437 p 6 470 210 0 5525 2218 b 10 0 680 0 894 334 p 6 261 419 0 5564 1898 b 10 0 680 0 1195 353 p 6 327 352 1 5655 1979 b 10 0 680 0 1562 397 sensibility = +25: Code:
i 6 680 0 0 1971 1953 b 10 0 680 0 445 373 p 6 270 384 26 4143 1591 b 10 0 680 0 1134 437 p 6 470 210 0 5525 2218 b 10 0 680 0 1711 843 b 10 0 680 0 1548 482 p 6 427 253 0 6127 2164 b 10 0 680 0 2173 901 b 10 0 680 0 2238 596
Le Sagittaire ... ;-) 1- Ateme AVC or x264 2- VP7 or RV10 only for anime 3- XviD, DivX or WMV9 |
#19 | Link |
Sagittaire: Thanks! Now I understand. It's a threshold for how 'easy' the encoder chooses B frames. I could expose such a parameter as well. Something to think about for the next update
| Thread Tools | |
| Display Modes | |
