Thread Tools Display Modes
Old 19th October 2004, 11:28   #1  |  Link
2COOL
PGC Navigator in Training
2COOL's Avatar
How to Do a Mock Strip using IfoEdit
Courtesy of 2 C L
With new users appearing on the scene everyday, it's a common question for them to ask "what is a mock strip?" when they are told to do one. Usually, it's called for if you had a badly authored Titleset. This process may not work in all cases but it used as a troubleshooting step to ensure that the Titleset is corrected anyways before looking into other steps in finding out what else is wrong with your files.
  • Mock
    [v. t.] To simulate; to imitate; to mimic
    Strip
    [v] to remove; "strip Audio/Subpicture elementary streams from a Title(s)"; "strip a Title(s) VOB Ids"
I believe I was the first one here to coin the phrase "Mock strip". It's a simple process using IfoEdit. Basically, you will perform a stripping of streams and VOB IDs but retaining everything instead. Here's the guide.
Mock Stripping Titleset VOBs
_______________________________________
1. Open up your IFO, in question, with IfoEdit.
2. Click on VOB Extras button.
3. Check only the VOB EXtras Options as below.
4. Browse to a Destination Directory other than source (original) folder.
5. Click OK
6. Your first Stream List is your list of existing Audio and SubPictures(Subtitles). Click on Check All and then Strip it button.
7. Your second Stream List is your VOB IDs. Click on Check All and Strip it button again.
8. IfoEdit will process and when done, you will have new files in your Destination directory.
9. In Windows Explorer, drag/copy all your new files into your directory that contains it's original counterpart files.
10. Confirm to copy all.
11. Open up your IFO, in question again, and click on Get VTS Sectors button. This will correct your IFOs sectors.
12. Click OK/Yes to all following dialogs.
13. When done, preview to test.
Mock Stripping Menus
2. Click on Menu Extras button.
3. Check only the Menu EXtras Options as below.
4. Browse to a Destination Directory.
5. Click OK
6. Your Stream List is your VOB IDs. Click on Check All and Strip it button again.
7. IfoEdit will process and when done, you will have new files in your Destination directory.
8. In Windows Explorer, drag/copy all your new files into your directory that contains it's original counterpart files.
9. Confirm to copy all.
10. Open up your IFO, in question again, and click on Get VTS Sectors button. This will correct your IFOs sectors.
11. Click OK/Yes to all following dialogs.
12. When done, preview to test.
2COOL
Old 19th October 2004, 11:49   #2  |  Link
jsoto
Just a Member
Useful guide. Thanks 2COOL
I usually do my mock strips without copying the files. It saves disk space and time and, up to now, I'm very happy with the results. Seems to me the results are the same.
So, the modifications to your guide are:
Titles stripping:
Options
[ ] Strip Streams'
[ ] Strip VobID's
[X] Correct Vob-Unit (Navigation Pack) pointers in VOB-files
[X] Correct original IFO files
VOB EXPERT Options
[X] Remove P-Uops
[X] Remove Macrovision
[X] Adjust Vob-Unit pointers.
[X] Adjust Audio/Subp point.
Also, uncheck
[ ] Auto-copy Menu Files to destination
[EDIT]
Steps 6, 7, 8 & 9 do not apply anymore.
Instead, select your ifo in the IFO tree window of IFOEdit and save it.
Continue with get VTS sectors, step 10 in 2COOL's guide
[/EDIT]
Menu stripping:
Options
[ ] Strip VobID's
VOB EXPERT Options
[X] Remove P-Uops
Also, uncheck
jsoto
Web sites with my tools
http://download.videohelp.com/jsoto
http://jsoto.posunplugged.com/
jsoto is offline   Reply With Quote
Old 19th October 2004, 12:16   #3  |  Link
2COOL
2COOL's Avatar
C It was about time and I was getting a little tired having to type out the process all the time.
  • Menu stripping:
    VOB EXPERT Options
    Also, uncheck
This gets unchecked anyways after you input a Destination Directory folder.
2COOL
Old 19th October 2004, 13:07   #4  |  Link
r0lZ
PgcEdit daemon
r0lZ's Avatar
Doesn't work for me!
And I use a special temp directory as the destination, so I usually accept the last destination directory used...
r0lZ
Mirror (in Belgium)
Unofficial mirror (in Poland)
Old 19th October 2004, 15:53   #5  |  Link
jsoto
Just a Member
Yeah, it works!. But only if you selects again the destination folder, and even in the case of being greyed out!!
jsoto
Old 19th October 2004, 20:53   #6  |  Link
CoNS
reMember
Thanks for the guide, 2COOL.
I'm one of those new users appearing everyday...! So now I know how to mock strip.
But when exactly do I have to perform such a mock strip?
For testing purposes, or to fix an error in the titleset? (Why is it "called for if you had a badly authored Titleset"?)
And what could cause such badly authored titlesets? (in which situations do you meet the problem?)
CoNS is offline   Reply With Quote
Old 20th October 2004, 00:45   #7  |  Link
blutach
Country Member
blutach's Avatar
@2COOL
Thnx for yet another invaluable guide. Is jsoto's (faster) method the way to go?
@jsoto
Can you do a Mock Strip in VOBBlanker? I think it can be done. And at least for me, VOBBlanker is intuitively easier to use than IFOEdit. As well, if I am correct, VOBBlanker does an "automatic" GET VTS sectors whereas IFOEdit does not.
And, I always take your advice to make the output folder on a different physical drive - it really speeds up the process!!!
@anyone
I know the speed up trick in IFOEdit (placing its progress indicator under the taskbar), but does a different destination drive also help?
Les
Only use genuine Verbatim or Taiyo Yuden media.
blutach is offline   Reply With Quote
Old 20th October 2004, 01:48   #8  |  Link
jsoto
Just a Member
Yes, but beware: there are two groups of VOB pointers I'm still basing the calculations in the original ones, and not from scratch (as IFOEdit does). They can affect to FF (goup one) and subpictures (group two). So IFOEdit method is better, and the way to go if you are trying to fix something wrong..
Yes, but it takes no time!
Yes. It also help, but I think it is faster to modify directly the originals.
jsoto
Old 20th October 2004, 01:55   #9  |  Link
blutach
Country Member
blutach's Avatar
@jsoto
Many thanks for that. I see under your method that the VOBs are modified in their original folder, whereas under 2COOL's method, a different destination folder can be used, which I think is safer.
However, as you have pointed out, there is extra time copying the VOBs back to the original folder.
BTW, why do we uncheck Autocopy menu files to new destination? What's wrong with copying the menu files?
Best regards
Les
Old 20th October 2004, 02:24   #10  |  Link
2COOL
2COOL's Avatar
Oh, just to cut down on process 6 as there are some large menu files out there.
2COOL
Old 20th October 2004, 09:32   #11  |  Link
jsoto
Just a Member
You are right. But if you are going to "directly" overwrite the original VOBs with the new ones, where is the advantage in terms of safety?
jsoto
Old 20th October 2004, 11:11   #12  |  Link
blutach
Country Member
blutach's Avatar
@jsoto...Agreed
Les
Old 20th October 2004, 12:20   #13  |  Link
CoNS
reMember
I'm curious...! What's that stripping-mocking-bird-thing for anyway?! (see my unanswered post above)
Old 20th October 2004, 18:58   #14  |  Link
jsoto
Just a Member
Well, not absolutely sure what does a IFOedit's mock strip, but, I believe it does:
A) IFO Tables adjustment (the exact table depends if it is a VOB extras or menu extras strip, and in the last case if it is a VTS or a VMGM one)
- Vxxx_C_ADT reconstruction
- Vxxx_VOBU_ADMAP reconstruction
- Vxxx_PGCI_UT / Vxx_PGCI. I believe only the cell attributes (like sectors and so on)
In the first pass reading the VOBs, IFOedit gets all the required info for the adjustment of these tables.
B) VOB modifications
B.1) Pointers adjustments: This is the more complicated part
In http://dvd.sourceforge.net/dvdinfo/dsi_pkt.html you can see the structure of the DSI part in a Nav pack. The most of these bytes/pointers are recalculated. There are some options in VOB experts part of Vob Extras dialog to select "groups" of pointers to be adjusted.
B.2) PUOPs / Macrovision removing
When do you need to do a mock strip?
In general, it is a safe way to reconstruct the DVD pointer structure (as I pointed out, there are thousands of them), and should be the first thing to be done in the case of VOB manipulations.
In the past, the methods for blanking/replacing cells are basically to replace the cells in a brute way inside the VOB. The resulting DVD was not playable, but after a mock strip, all the pointers are readjusted and the DVD plays again.
jsoto
Old 21st October 2004, 02:38   #15  |  Link
blutach
Country Member
blutach's Avatar
Should a mock strip (and GET VTS Sectors) therefore be done as the last thing before burning?
Les
Old 21st October 2004, 02:48   #16  |  Link
2COOL
2COOL's Avatar
Only if testing the playback is successful.
Mock strip > Get VTS Sectors > Preview to Test > Burn backup
2COOL
Old 21st October 2004, 09:39   #17  |  Link
blutach
Country Member
blutach's Avatar
Thnx 2COOL.
Les
Old 21st October 2004, 22:54   #18  |  Link
CoNS
reMember
So each and every time you've "messed" with a disk, you'll have to do a mock strip to be sure that the ifo files are ok?
Does that also apply to changes made to the DVD with DVD-Rebuilder, PgcEdit, VobBlanker, MenuEdit, IfoEdit etc.?
Old 21st October 2004, 23:24   #19  |  Link
blutach
Country Member
blutach's Avatar
Gents,
I've found that when mock stripping (under the 2COOL method - which changes the VOBs), the VOBs have different sizes. They are aproximately 1,048,574KB, but not quite - some a few hundred less with the final VOB making up the difference. Therefore, the mock strip must alter the VOBs too. This seems intuitively strange.
Similarly, after a mock strip of menus, I did a file compare on the VOBs (the sizes were the same), but there were many differences.
Why is this so?
However, chapter times (which were altered slightly when using VOBBlanker), are re-aligned perfectly with the original after a mock strip.
Also, after mock stripping (say the main movie in, for example, VTS_01*.VOB), a new set of VIDEO_TS.* is created. Is this compatible with the VIDEO_TS previously? Does it contain all the info required for whole disk???
Thanks in advance
Les
Old 22nd October 2004, 00:23   #20  |  Link
jsoto
Just a Member
@blutach
I cannot believe this....
A VOB file is made of 2048 byte sectors (called packs). You can join (in a binary way, of course) all of the files and split them between the two sectors you want, without affecting any pointer!!, neither internal nor the ones in the IFO . I think this is the efect you are seeing. So:
- Each file size MUST be a multiple of 2048 bytes
- The total file sizes MUST be the same than the originals.
[qoute]Similarly, after a mock strip of menus, I did a file compare on the VOBs (the sizes were the same), but there were many differences.[/quote] True. I've found differences in the DSI pointers which are calculated sligthly different than the ones calculated with pther tools (dvdauthor i.e.). But the differences are minor, and not really sure which ones are the most accurated. I'm talking about the offsets to VOBU 120, 60, 30, 10, 7.5, 7.0, 6.5, 6.0, 5.5, 5.0, 4.5, 4.0, 3.5, 3.0, 2.5, 2.0, 1.5, 1.0, 0.5 seconds forward and backward.
Still present in 1.5.0.6? I've to check, I was thinking I had fixed this (minor ) bug.
@CoNS
No, only if you have done any "dangerous" manipulation or if your test (before burn) does not work. Ah!, other very useful "test" (faster than IFOedit) is to load the files in dvdshrink. When dvdhrink loads a DVD, a lot of IFO pointers are tested.
jsoto
Thread Tools
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
