Old 13th October 2004, 03:51   #1  |  Link
PGC Navigator in Training
2COOL's Avatar
Turning Subtitles OFF by Default v2.0 using PgcEdit
HTML guide hosted by r0lZ.
10/10/2004: This is my 2nd version of my 2nd half of my first guide. PgcEdit v.0.3.5 used at this time.
Old 16th February 2006, 15:10   #2  |  Link
nbarzgar's Avatar
DVD without menu, problem turning subs off
thanks for the guides, 2COOL. Hope, somebody is watching this thread still.
I'd like to turn the subs on my re-authored DVD off. It's "movie-only" from DVD-RB and when I follow this guide, it works fine with the first cell of the only PGC left (it seems to me) in the 1st and only VTS.
EDIT: forgot to mention that it works in the FIRST cell ONLY, the following have subs turned on again... :-( EDIT.
Can you point to a work-around or possible error I made?
I include the screenshot from the PGC-table.
"There are more things in heaven and earth, Horatio,
Than are dreamt of in your philosophy." Shakespeare, Hamlet
nbarzgar is offline   Reply With Quote
Old 16th February 2006, 16:54   #3  |  Link
Use the standard command:
(SetSTN) Set Sub-picture Stream = 0
But if they are "forced" then use DVDSubEdit to change to "normal".
frank is offline   Reply With Quote
