15th October 2004, 06:56 | #41 | Link |
The hands of fate
Finding Nemo also brings this error with build 3:
(VTS01 encodes flawlessly, VTS09 is the problem here) Procedure Name: Item Module Name: VTS Error Number: 9 Error Description: Subscript out of range Error Source: ErrorHandler Error Line: 5 Call Stack: Item --> VTS EnableDemuxing --> ExecuteProgram DummyScan --> NewCells ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions NewCheckPalette --> NewCells ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions Compare_Codes --> Commands Hex2Command --> Commands Compare_Codes --> Commands Hex2Command --> Commands Hex2Command --> Commands ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions priv_LangCodeToLangName --> CLsDVD ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions GetIFOParams --> NewCells ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions GetIFOParams --> NewCells ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions GetIFOParams --> NewCells ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions GetIFOParams --> NewCells ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions GetIFOParams --> NewCells ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions GetIFOParams --> NewCells ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions GetIFOParams --> NewCells ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions GetIFOParams --> NewCells ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions ByteHandle --> GlobalFunctions GetIFOParams --> NewCells GetIFODetails --> ReplacementFile StartNuMenu4u --> ExecuteProgram go_Click --> MainForm |
15th October 2004, 23:08 | #43 | Link |
OmegaZero
Can i have the log. Use the debug screen - point to the working dir eg c:\nm4u\nemo, and let it zip up all the files i need. The log and IFOs are the most important thanks Last edited by Zeul; 15th October 2004 at 23:12. |
16th October 2004, 09:08 | #44 | Link |
Missing .M2V files
When trying to import script made b y numenu into Scenarist, it can't compile it cuz whatever CCE encoded (not everything but most) is not in "new_m2v" folder. That's with Star Wars IV A New Hope DVD
16th October 2004, 23:22 | #45 | Link |
I just copied Van Helsing (Zone 2). And all went perfect.
The Menu is "Progressive" according to my eyes. But DVD2AVI (aka DGIndex) say it's "interlaced". This happend really often with Zone 2 DVD. So is their a way to tell NuMenu to use progressive settings, for CCE, even if DVD2AVi report interlaced ? (I know you can choose "verify script". But I mean automated). I know there's a way to choose Scan = Zig-Zag (choose "field order"=TFF). But I think their's nothing to do the same for "progressive frame flag" |
17th October 2004, 01:10 | #46 | Link | |
The hands of fate
*EDIT: Sent you the zip Zeul* Last edited by OmegaZero; 17th October 2004 at 01:30. |
18th October 2004, 05:42 | #47 | Link | |
"Walking Tall" Scenrist error
I tried backing up "Walking Tall" today, and I had these Scenarist errors from doing the menu by numenu RC3
18th October 2004, 20:28 | #50 | Link | |
18th October 2004, 20:42 | #52 | Link | |
I did select the right directory in debug e-mail facility, but left the numenu4u at default. |
19th October 2004, 00:33 | #55 | Link |
Finally a new release
15/10/04 NuMenu4u RC2 Build 4 Bug Fixes: Alteration to the sub starttime - occasional button not compiled Variety of bug fixes to correct copying files when dif4u threshold is higher When called from dif4u the first drive that had a valid dvd structure would be used , not the intended drive Settings now saved again Some changes to stop overflow error Major change to the AVS script editor. many of the parameters were never passed into the NTSC scripts, Deinterlacing now provides the correct scripts Major fix to the passing of the encoded m2v files into the NEW_M2V folder for scenarist. Major fix to a dumb error that wouldn't allow any menu PGCs to be created in non-processed VTSs - this would cause a variety of scenarist compile errors if VIDEO_TS.VOB was being processed Fix to scanning for dummy cells - where cell demux needs to be invoked first Enhancements: A new special script for PAL deinterlacing should now be used - I have not included any particular script for this - use your own Added ability to specify whether the menus are progressive or interlaced by default (in the Quality settings) NB see the note! New installer that will remove previous version and ALL settings if wanted - Recommended As a footnote; I have extensively tested the debug screen with the working directory in a variety of places and with different filenames inc spaces, and everytime I have success. To recap the menu in the main screen should be the one presently being worked upon. Then press the 'select working directory' button in the debug screen and select the full path to your directory, so if the VIDEO_TS folder inside the working dir had this path c:\ZeulTest\Test\VIDEO_TS then you would select c:\ZeulTest\Test as the working directory. For clarification the path chosen is now displayed in the working directory field. Zeul http://www.numenu4u.com/NuMenu4u.exe Last edited by Zeul; 19th October 2004 at 08:13. |
19th October 2004, 09:18 | #57 | Link |
Feature request
I would like to be able to select priority on the whole process so it doesn't clog up my PC so much.
Is it ok to do something on the computer while Numenu4u runs or should I just get away from PC while numenu4u works? Another thing, should I turn off screensaver while running numenu4u? |
19th October 2004, 10:42 | #58 | Link | |
Re: Build 4
20th October 2004, 01:17 | #60 | Link |
I just finished the DVD BONUS of Van Helsing.
All works perfectly. My deiterlace script was correctly used, and the new setting "progressive/interlaced" for CCE is excellent for PAL dvds. (I must add that I have changed to scenarist 2.7.Beccause I read that to many had problems with version 3.0 with Scenaid, Numenu, etc.. ) So I had no scenarist error either. Thanks a lot for this new build. |
