Old 9th October 2004, 08:03   #1  |  Link
VCD MASTER
NO PAIN, NO GAIN
The best possible way to do a good capture depends, first of all, of the frame size, rata in kb per second and audio encoding on-the-run.
While a lot of codecs offers a lot of weird options in the capture control, they miss the most important fact in the capture process: the motion detection. Motion detection is the key factor in digital video processing (no matters if you're capturing analog sources, if you are trying some usb devices that does the convertion directly or if you're ripping or re-encoding some high quality digital source, as DV cameras, DVD and those like that).
Consider that a high motion video, like a lot butterflys flying, doesn't have the same motion than a nun prying !!!!!
The subdivision of the overlay or simulated overlay with some direct-x controlers works independently zone to zone, and the motion detection applies stadistical development trying to find the best promedy in every zone of the overlay or non-overlay captured frame, and, of course, the possibilty of apply those procedures implies a very high CPU work.
If you have a PENTIUM III or bigger, feel blessed. Pentium always be the most complete processor in this galaxy until that the apocalipsis come!!!...........and if you have a PENTIUM IV, feel blessed twice !!!...Forget about Xeon, Amd, and so on, 'cause they're processors designed for optimized data-base, game non-bitmap software and text processing works, and the video processing is left forgotten 'cause Direct-x tryes (with very poor results) to be a weird hardware solution made in software, with the dramatical consecuence of higher CPU usage, more higher disk consume and forcing both video capture and video card devices to work always on they tresholds of performance.
The capture process done through VGA devices takes free a lot of work to the central processor, specially if your VGA card supports overlay frames, and specially too if you're capturing with audio compression, cause the sincronicity between audio and video layers consumes a lot of CPU recurses too.
So, the key factors in a good capture are:
1. A decent CPU, Pentium will always be the best.
2. A decent and multi-thread operating system (Linux or Win 2000) dedicated only for video works (You gotta know how to install more than one operating system in your PC; another windows systems works patetic on capture process, a lot of dropped frames, specially win 98SE and win XP, CONSIDER THAT DROPPED FRAMES OVER THE 10% TOTAL FRAME COUNT WILL MAKE YOUR CAPTURE DEVICE PROCESSOR CRASH !!!!!!), with NO SERVICE PACKS OR SOME LIKE THAT ADDED, just an antivirus software, capture and video editing-processing-rendering software and no more.
3. Think always in your final work...if you're trying to do some vcd or multimedia video, how do you think to obtain a professional results capturing at the same frame size ?????.
Forget about Ulead Video Studio, WinVcr, and almost any MPEG capture software, 'cause they doesn't let you do ANY FRAME FORMAT CHANGE, and they always works over Direct-x and simulated capture drivers over the microsoft standard video format.
The frame size is almost the same idea that the MP3 compression algorithm.......MP3 always works over WAV files, and the compression factor is 11:1; and now add video......a lot more complex.
A good capture frame size for multimedia or vcd final video is 448x336 or bigger, and dont think that you can use a bizarre frame size (477x253 or some like that, this causes a lot of interlace and flicked frames), 'cause the frame subdivision always works IN A 8 FACTOR SIZE !!!.
And, a good capture size for bigger formats (DV, DVD, and so on) depends of the zoom abilities for the used codec in caprture process.
4.So, once the Operating System, VGA card and frame size troubles solved, take a look to your capture software...try and try and become a vampire wasting nights and nights trying to find the best performance software, and when you get crazy, try IUVCR.......simply the best, little and simple capture software, just think about this:
efficiency , vanguard and all the stuff related IMPLY SIMPLICITY
(is E=MC2 a complex formula ????? ).
Re-become a vampire looking for a good codec, and later try XVID4....try to do some high zooms in your capture with Vegas Video or Premiere, and you will see why I'm choosing it.
5.On video processing forget about frameserves, excepts the marriage VIRTUALDUB-TMPGENC, where you can pre-zoom your source to a bigger frame size; but, better even, join the poligamy with ffdshow and all its compatible software, cause ffdshow isn't a frameserver, is an embeded video filter...frameserving always introduces quality-loosing because they work over caches, not over real events !!!!
6.Dont waste lot of space using div-x codecs for your multimedia rendering.......just use VCD, that offers a very decent space consume per minute (10 mb) and, mainly, doesn't requieres too much CPU resorces.........can be played even Pentium I computers.
7.And, finally, dont do contrast manipulation for no-pixelation optimization........a darky video is a matter of ugly work quality, and a characteristic of a low quality video production.
See ya, keep enjoying the video paradise !!!!!!!!!!!!!!
VCD MASTER is offline
Old 9th October 2004, 14:04   #2  |  Link
Wilbert
Good ???
A decent CPU will suffice. If you have a decent one, it doesn't really matter whether you use a Pentium or AMD. Yes, I know that a Pentium is faster wrt processing and encoding. But, it will also be more expensive.
This is really not necessary. You should have a separate partition of capping though.
3. (...) A good capture frame size for multimedia or vcd final video is 448x336 or bigger
You should cap both fields. Thus 448x480 (width depends on your cap device/drivers, see analog cap guide).
So, we should forget about AviSynth. Yeah, right ...
This is nonsense. If you disagree I suggest you post some evidence.
VCD is bad quality (half of the info lost, etc.). We can do better now ...
I agree with this one.
Wilbert is offline
Old 9th October 2004, 18:45   #3  |  Link
VCD MASTER
TRY IT !
Talking in "expensive" terms, it depends of your objective...cheeper becomes the most expensive, not only in video.......and expensive isn't always the best, the key factor is: BALANCE...if yuo really want to be expensive, buy a Mainframe or DVW processor !!!!
Ok, add a lot of work to your processor handling and admining 2 different partitions, even when you're capturing with a bigger data rate, above 12000 kbps (with an overloaded Microsoft system with service pack, a lot of temporals and an enormous shell; do you know about all the underground processes that a capture implies?)......had you tried XVID 4 using Quantizer at 1,and Motion Detection on Ultra High, and the pixel motion detection enabled ?
Try and manipulate ffdshow settings in playing, not capturing, but, most important, use some Divx or video settings calculator and take a look in the relationship between Width and Height.....and 448 x 480, both, are 8 factors too...but better that this, always be 480 x 480, just the middle point between VCD and DVD. That's why I'm talking about the zoom properties of XVID4 codec !!!
If you're are married with AviSinth it's a matter of romanticism, not of practicity.
Frameserver is concibed for a non-expensive hard disk space wasting in a ripping process...had you tried loading whole VOB's in VIRTUALDUB? (Including pre-ripped subtitles in the subtitler plugin) .......if you have a good capture, why insert this on a frameserver (it would be good if the frameserver enhances the video parameters, most even, if it can do video noise reduction)...what do you prefer.....an external frameserver or an embeded filter ??? what is the lower job measure ???...but the best frameserving process will be always using one pc with videowin signal conversion (or a DVD playing in real-time the original source, analog signal on DVD is even more bigger than 720 x 480)and other pc with an usb capture device that does compression in real-time, specially if you're producing DVD....but you think I'm an expensive guy !!
But now, if there's in this galaxy a prebuilding process that expends less time than the original source duration (talking in facts of quality), meet me with the witch !
OK, gimme your email and i'll send you some, if you don't have enuff space in your inbox (attachments here are very little), i'll put it on my own server for download and I'll send you the url, and some login and password valid only for a day.
Cheepest, most of times, become the most expensive.....and expensive, almost always, isn't the best.
Old 9th October 2004, 19:59   #4  |  Link
FredThompson
FredThompson's Avatar
Re: TRY IT !
You appear to be in the classic position of knowing just enough to get yourself in trouble yet not knowing enough to know that you don't know what you don't know.
Oh...you're also being quite rude.
Reclusive fart.
Collecting Military, Trains, Cooking, Woodworking, Fighting Illini, Auburn Tigers
FredThompson is offline
Old 9th October 2004, 21:40   #5  |  Link
VCD MASTER
NOT SO RUDE
If I'm becoming rude, just forget about...As I can see you're very addicted to cheaper software solutions in video processing, so if it's your way to understand it, that's your way.
Just think about making 15 o 20 video editions at week (Marriages, Birthdays, Football games for fans, Animations and Institutional Presentations for Business and stuff like that), you just can't wait until a frameserver or a software encoder does everything for you, specially when an edition process follows and/or preceds that process.
How much time wastes a Ripping process ?
If you have a good dvd/cd/burner/reader device that can work, as minimal, at 52x, a whole dvd spends between 18 and 35 minutes, course, if you're using a good ripping solution (that permits audio layer selection and subtitles too), like smartripper, dvd shrink, dvd2one or dvd santa (this last, best of all); and, course, if you dont want to kill your reader/burner device using a stand-alone ripping software that reads at intervals of 10-40 second; and so on, if your device can be swithable to SMART mode on reading and finally if your Operative System is configured to handle a SWAP or PAGEFILE bigger that 1GB (there's when you'll see the difference between PENTIUM and the others...)
But now, if you haven't tried to manipulate the VCD settings in a good encoder, like TMPGENC (including frame size and matrix values, XVCD, KVCD and all the family of innovations), how can you say that about VCD or MPEG-1 processes ??? If you don't know about matrix manipulations and compression algorithms I think I'm in the wrong place, 'cause this seems to be an open forum for costumers, not for developers.
Talking avout VCD, I'm suggesting that as an easy accesible media distribution, 'cause you can't forever know the hardware limitations of your costumers, but most of all, 'cause not everybody can pay for a DVD video editting process, talking in terms of common people.
Of course, if a costumer wants some DVD or simmilar work, you proceed as it is, and there's is when you will see WHO is WHO in the almost infinite software solutions for this...and when you'll see WHO is WHO in the PC processors family.
I have two pc's to do frameserving 'cause the time factor is very important when you work with video...and I have my own DVW when a DVD work becomes, 'cause it's hardware with a main operative system dedicated exclusively to digital video encoding.
Frameserving through hardware devices, at this time, doesn't become a way to do video processing as you're trying to clasify my last comment; hardware technology is more and more accesible as time goes by, and the complete dependency of software at this time of transition isn't recommendable.
I won't spend lots and lots of words talking about minor details between a way and another way, so that's why I'm sending you the list of software that I've tried until I've taken the option of working with my cuttie babes: IUVCR, XVID4, ADOBE PREMIERE, PINNACLE, UMSPRO AND VEGAS and, course, TMPGENC and VIRTUALDUB...and another new jewel from Germany: PVR.
Want some of these or complete list? Send me some message and I'll put it on my webserver available for download, just for a day, considere that this forum only lets apply 16000 characters on replies.
XVideoConverter[2].exe 5.564 Kb Aplicación 04/07/2004 13:45
XVideoConverter[1].exe 5.684 Kb Aplicación 14/06/2004 19:06
XVideoConverter.exe 5.564 Kb Aplicación 10/06/2004 13:47
Xmuxer.zip 989 Kb 12/06/2004 04:06
XMPEG_5.0.3_Setup.exe 1.889 Kb Aplicación 04/07/2004 13:32
xdvdripper[1].exe 1.494 Kb Aplicación 04/07/2004 13:28
xdvdripper.exe 1.412 Kb Aplicación 07/06/2004 11:46
x-dvd-ripper.exe 1.270 Kb Aplicación 07/06/2004 11:35
wwbvmsetup.exe 7.855 Kb Aplicación 04/07/2004 13:24
wvcr111t.exe 4.399 Kb Aplicación 11/06/2004 12:49
winvdrpro_setup.exe 2.509 Kb Aplicación 11/06/2004 02:32
WinDVR_v3[1].0.zip 1 Kb 13/06/2004 17:58
WinDVR_2_Trial_v2[1].0.34_by_Queequeg.zip 1 Kb 13/06/2004 19:12
WinDVR_2_build_2[1].043.91.zip 1 Kb 13/06/2004 19:08
WinDVR2 Trial Version.zip 1 Kb 13/06/2004 19:14
WinDVR.exe 5.879 Kb Aplicación 13/06/2004 18:46
WinCopyDVD_STD.exe 2.092 Kb Aplicación 08/06/2004 14:50
webcamlocator.zip 2.414 Kb 04/07/2004 12:41
wcp21.exe 5.803 Kb Aplicación 04/07/2004 12:37
vxpsetup[1].exe 1.314 Kb Aplicación 04/07/2004 12:27
vxpsetup.exe 1.963 Kb Aplicación 11/06/2004 13:03
vml100.zip 692 Kb 04/07/2004 12:24
vks.zip 7.571 Kb 04/07/2004 12:23
vkp214.zip 7.195 Kb 04/07/2004 12:11
VirtualDub14c_asf.zip 342 Kb 28/06/2004 20:56
videotoaudioconverter.exe 3.441 Kb Aplicación 04/07/2004 21:52
videoslice_setup.exe 1.893 Kb Aplicación 12/06/2004 03:08
videoset.exe 557 Kb Aplicación 04/07/2004 11:59
videofixer.exe 1.373 Kb Aplicación 04/07/2004 11:58
videodvdduplicator.zip 293 Kb 04/07/2004 11:55
VideoConvertSetup.zip 5.427 Kb 04/07/2004 11:54
videocleaner_setup.exe 1.913 Kb Aplicación 08/06/2004 15:09
vhhesetup.exe 4.967 Kb Aplicación 04/07/2004 11:16
vfjSetup.exe 960 Kb Aplicación 04/07/2004 11:07
vctsetup.exe 1.905 Kb Aplicación 04/07/2004 11:05
vcsetup.exe 554 Kb Aplicación 04/07/2004 11:01
vcdgear355.zip 2.467 Kb 04/07/2004 11:00
vcdcut.exe 2.100 Kb Aplicación 08/06/2004 15:29
VCDCUT PRO V4.12.exe 657 Kb Aplicación 11/06/2004 03:11
vcd2tk.zip 2.925 Kb 09/06/2004 00:35
tytoolnodvd.zip 197 Kb 09/06/2004 00:27
tvsSetup.exe 404 Kb Aplicación 03/07/2004 14:02
tocs12.zip 72 Kb 09/06/2004 00:15
TinCam.exe 4.909 Kb Aplicación 03/07/2004 14:00
s_fp.zip 1.887 Kb 02/07/2004 14:22
swf2avi.exe 1.436 Kb Aplicación 03/07/2004 13:49
svconv11.zip 134 Kb 03/07/2004 13:45
svconv10.zip 268 Kb 03/07/2004 13:44
Super_DVD_Creator.exe 2.774 Kb Aplicación 04/07/2004 10:56
Super DVD Ripper v2.00 Full + Key.exe 927 Kb Aplicación 07/06/2004 18:36
subtitlesource_20030618.zip 216 Kb 16/06/2004 15:16
StreamingServer.zip 3.688 Kb 04/07/2004 10:34
sthsvcd_55.exe 803 Kb Aplicación 09/06/2004 00:14
steeper10.zip 613 Kb 03/07/2004 13:33
snr.zip 19 Kb 09/06/2004 00:01
SnatchItInstaller.exe 778 Kb Aplicación 03/07/2004 10:13
slideshow.exe 516 Kb Aplicación 03/07/2004 10:11
sleep.zip 1.159 Kb 03/07/2004 10:09
sfplayer.exe 3.790 Kb Aplicación 03/07/2004 13:08
setup_magicdvdripper.exe 1.499 Kb Aplicación 08/06/2004 23:53
setup[1].exe 2.481 Kb Aplicación 02/07/2004 14:36
SETUPEX.exe 4.444 Kb Aplicación 03/07/2004 10:05
setupdtr.exe 2.254 Kb Aplicación 09/06/2004 00:01
setupdtm.exe 796 Kb Aplicación 03/07/2004 09:55
setup.exe 716 Kb Aplicación 02/07/2004 14:31
sdvdr.exe 864 Kb Aplicación 08/06/2004 23:45
sdvdinst.exe 865 Kb Aplicación 07/06/2004 11:49
sdvdc.exe 4.644 Kb Aplicación 10/06/2004 20:30
scdvd.exe 2.305 Kb Aplicación 02/07/2004 14:27
sc2.zip 552 Kb 02/07/2004 14:23
rmtoall.exe 2.701 Kb Aplicación 02/07/2004 14:03
rmconvt.exe 2.975 Kb Aplicación 02/07/2004 13:59
rmconverter.zip 315 Kb 02/07/2004 13:47
rmconverter.exe 1.828 Kb Aplicación 26/06/2004 14:45
ripitall.zip 2.753 Kb 08/06/2004 23:41
rgb.zip 18 Kb 08/06/2004 23:29
rfjSetup.exe 881 Kb Aplicación 02/07/2004 13:44
ReMPEG2v152.zip 435 Kb 08/06/2004 23:28
ReJump_Movie_Joiner + crack.exe 1.487 Kb Aplicación 12/06/2004 14:26
Rejump Movie Converter v1.0 + crack.exe 325 Kb Aplicación 12/06/2004 14:28
RealFixer.exe 905 Kb Aplicación 12/06/2004 14:35
RealCloneDVDSetup.exe 1.062 Kb Aplicación 01/07/2004 10:44
realalt122.exe 5.659 Kb Aplicación 12/06/2004 16:58
qc-setup.exe 115 Kb Aplicación 01/07/2004 09:55
Pvido110.exe 1.176 Kb Aplicación 01/07/2004 09:00
PSINSTALL.EXE 2.474 Kb Aplicación 08/06/2004 23:26
pparty.zip 1.970 Kb 01/07/2004 08:50
PlatoDVDRipperSetup[1].exe 3.677 Kb Aplicación 30/06/2004 20:48
PlatoDVDRipperSetup.exe 3.702 Kb Aplicación 07/06/2004 21:46
piwc2_3b.exe 266 Kb Aplicación 30/06/2004 19:53
PICVIDEO2.EXE 820 Kb Aplicación 08/06/2004 23:13
PGAE15Demo.zip 3.142 Kb 30/06/2004 19:53
pdftiff100.zip 3.025 Kb 30/06/2004 19:48
NeroInfoTool_1032.zip 160 Kb 10/06/2004 12:48
MyMoviesSetup126.exe 808 Kb Aplicación 30/06/2004 19:37
mvw-2003.exe 7.401 Kb Aplicación 22/06/2004 01:06
ms_setup.exe 51 Kb Aplicación 12/06/2004 14:52
mpgto120.zip 176 Kb 30/06/2004 19:35
mpegSCISSORS.zip 446 Kb 11/06/2004 22:24
MpegCut.zip 420 Kb 12/06/2004 04:05
mpegableX4live-Setup.exe 4.170 Kb Aplicación 29/06/2004 10:33
mpegablePlayer-Setup.exe 1.182 Kb Aplicación 29/06/2004 10:13
mpegableDSdecoder-Setup.exe 1.275 Kb Aplicación 29/06/2004 10:10
mpegableBroadcaster-Setup.exe 4.171 Kb Aplicación 29/06/2004 10:23
mpeg4maker_setup.exe 2.398 Kb Aplicación 30/06/2004 19:32
MPEG2i.exe 1.995 Kb Aplicación 28/06/2004 10:49
MPEG Video Wizard 2003.exe 1.305 Kb Aplicación 22/06/2004 01:27
mp3towav.exe 1.790 Kb Aplicación 28/06/2004 13:18
mp3rmconverter.exe 6.677 Kb Aplicación 28/06/2004 13:08
mp3recorder.exe 1.319 Kb Aplicación 28/06/2004 10:41
mp3cutterjoiner.exe 2.575 Kb Aplicación 28/06/2004 12:42
MP3CDRipper.exe 1.946 Kb Aplicación 12/06/2004 22:50
mmorph_eval[1].zip 2.796 Kb 28/06/2004 12:33
mmorph_eval.zip 1.571 Kb 28/06/2004 10:35
mmaze_eval.zip 1.764 Kb 28/06/2004 10:30
mlist13f.exe 1.895 Kb Aplicación 28/06/2004 10:26
mjpgr_eval.zip 1.419 Kb 28/06/2004 12:22
minimp3recorder.exe 891 Kb Aplicación 28/06/2004 10:19
mediatorSE.zip 444 Kb 28/06/2004 20:42
mediator.zip 184 Kb 04/07/2004 21:30
MediaOne .exe 732 Kb Aplicación 28/06/2004 10:17
MedianJC_v2.6.2.exe 1.571 Kb Aplicación 28/06/2004 10:15
MediaFixer.exe 1.099 Kb Aplicación 12/06/2004 13:00
MCL-3_1_4.exe 1.312 Kb Aplicación 12/06/2004 22:42
Max_DVD_to_MPEG_Converter_v2[1].0.zip 1 Kb 10/06/2004 13:08
maxd2m.exe 2.166 Kb Aplicación 08/06/2004 23:08
maxd2a.exe 1.361 Kb Aplicación 08/06/2004 23:01
Manual_VirtualDubMod.exe 2.911 Kb Aplicación 17/06/2004 03:22
MagicDVDRipper12[1].exe 1.226 Kb Aplicación 28/06/2004 10:10
MagicDVDRipper12.exe 1.226 Kb Aplicación 07/06/2004 11:30
magicdvd.exe 1.916 Kb Aplicación 28/06/2004 10:07
magicdemo.exe 6.281 Kb Aplicación 30/06/2004 19:19
lossless.exe 113 Kb Aplicación 28/06/2004 10:02
LOMALKA[1].RU-WinDVR_All_Versions.zip 296 Kb 13/06/2004 18:09
KVCDTemplates.zip 29 Kb 10/06/2004 15:22
JPGWIZ.EXE 3.394 Kb Aplicación 08/06/2004 22:56
JP2PLUGIN.EXE 712 Kb Aplicación 08/06/2004 22:41
JoyDVDRipper2000.exe 1.554 Kb Aplicación 08/06/2004 10:10
iuVCR_v4[1].0.0.227.zip 11 Kb 14/06/2004 00:32
iuvcr_setup.exe 1.145 Kb Aplicación 13/06/2004 23:47
itdvd-ripper.exe 1.473 Kb Aplicación 27/06/2004 21:10
IPViewer503.zip 5.852 Kb 27/06/2004 21:06
innodvdripper.exe 1.622 Kb Aplicación 08/06/2004 22:38
impeg-converter.exe 2.388 Kb Aplicación 27/06/2004 20:52
ImgTool_0.99.4.zip 99 Kb 10/06/2004 11:55
ImageAnalyzer.exe 1.852 Kb Aplicación 12/06/2004 02:48
icuii602a.exe 3.471 Kb Aplicación 27/06/2004 20:47
i2m_11.zip 2.930 Kb 27/06/2004 20:39
hvc2.exe 7.485 Kb Aplicación 30/06/2004 19:01
huffyuv_220.zip 33 Kb 08/06/2004 22:34
HT_Video_Editor_6[1].0_v1.0.0.1.zip 26 Kb 30/06/2004 09:50
htwebcam30shareeng.exe 4.850 Kb Aplicación 27/06/2004 19:52
httvr10engdemo.exe 3.842 Kb Aplicación 27/06/2004 18:54
htsplitter20shareeng.exe 7.027 Kb Aplicación 27/06/2004 18:45
htencoder60shareeng.exe 7.677 Kb Aplicación 27/06/2004 17:36
htburndvd31shareeng.exe 6.634 Kb Aplicación 27/06/2004 16:51
htavitodvdshareeng.exe 3.269 Kb Aplicación 27/06/2004 16:36
hsp.exe 6.364 Kb Aplicación 27/06/2004 16:28
GoCCE.zip 57 Kb 12/06/2004 15:02
flyvcd14.zip 2.040 Kb 27/06/2004 15:43
flaskmpeg_078_39.zip 916 Kb 08/06/2004 22:34
flaskmpeg_0594_intel.zip 481 Kb 08/06/2004 22:29
flaskmpeg_0594_amd.zip 377 Kb 10/06/2004 15:26
FlasKMPEGXiS30e.zip 1.307 Kb 10/06/2004 15:29
FlashPlayer.exe 108 Kb Aplicación 27/06/2004 15:36
flashcreate.exe 792 Kb Aplicación 27/06/2004 15:35
flashconvert20.exe 1.868 Kb Aplicación 27/06/2004 15:33
fconvert20.exe 1.868 Kb Aplicación 27/06/2004 14:42
fblender.zip 19 Kb 08/06/2004 22:24
ezmp3c.zip 1.204 Kb 27/06/2004 14:34
ezcdr_inst.exe 3.470 Kb Aplicación 27/06/2004 14:19
ezc10eng.exe 591 Kb Aplicación 27/06/2004 14:09
epgr130.exe 981 Kb Aplicación 27/06/2004 13:47
eo136.zip 3.835 Kb 27/06/2004 13:44
easyxvc100.zip 585 Kb 10/06/2004 15:48
EasyXVC.zip 555 Kb 12/06/2004 22:37
EasyDVDCopy.exe 1.961 Kb Aplicación 08/06/2004 00:57
easy movie splitter.exe 718 Kb Aplicación 11/06/2004 21:09
e2swf-01.zip 158 Kb 27/06/2004 12:54
dvtool049.exe 509 Kb Aplicación 12/06/2004 02:32
dvmpeg6demo.exe 3.712 Kb Aplicación 27/06/2004 12:54
DVDtoVCDRipper[2].EXE 845 Kb Aplicación 27/06/2004 12:45
DVDtoVCDRipper[1].EXE 845 Kb Aplicación 12/06/2004 18:07
DVDtoVCDRipper.EXE 1.045 Kb Aplicación 08/06/2004 10:27
DVDTOMPEG.exe 826 Kb Aplicación 07/06/2004 11:37
DVDtoDVDCopyTrialVersion2_0.exe 8.065 Kb Aplicación 27/06/2004 12:41
dvdtoavi.exe 974 Kb Aplicación 27/06/2004 12:22
dvdta.exe 792 Kb Aplicación 27/06/2004 12:20
dvdsetup.exe 1.592 Kb Aplicación 27/06/2004 11:59
dvdrips.exe 1.437 Kb Aplicación 07/06/2004 11:42
dvdripper.exe 1.028 Kb Aplicación 27/06/2004 11:51
DVDRegionFree21.exe 733 Kb Aplicación 27/06/2004 13:58
dvdrabbitprohour.exe 3.856 Kb Aplicación 08/06/2004 22:15
DVDPro5.0.1Trial.EXE 5.020 Kb Aplicación 10/06/2004 11:01
dvdmb-0_2_9.exe 4.806 Kb Aplicación 27/06/2004 11:48
DVDLabelersetup.exe 6.469 Kb Aplicación 27/06/2004 11:37
dvdcopy_setup.exe 2.536 Kb Aplicación 26/06/2004 21:30
DVDCopy[1].exe 172 Kb Aplicación 26/06/2004 21:24
dvdcopy.exe 1.414 Kb Aplicación 26/06/2004 21:24
dvdcloner.exe 2.414 Kb Aplicación 26/06/2004 21:19
dvdaudioextractor.exe 1.172 Kb Aplicación 26/06/2004 21:09
DVD2one_v1[1].4.0.zip 72 Kb 09/06/2004 09:26
dvd2one140.exe 141 Kb Aplicación 08/06/2004 22:00
DVD2DIVXVCD_trial.exe 1.170 Kb Aplicación 12/06/2004 18:02
dvd2cdr.exe 3.959 Kb Aplicación 09/06/2004 09:39
dvd-vcd-converter-plus.exe 1.650 Kb Aplicación 08/06/2004 22:23
DVD-SETUP-EN.EXE 8.050 Kb Aplicación 27/06/2004 12:18
dvd-ripper[1].exe 1.451 Kb Aplicación 27/06/2004 11:55
dvd-ripper.exe 1.222 Kb Aplicación 08/06/2004 22:19
dvd-audio-ripper.exe 1.216 Kb Aplicación 26/06/2004 21:13
dMC-r10.exe 1.484 Kb Aplicación 08/06/2004 20:23
dMC-PowerPack.exe 379 Kb Aplicación 08/06/2004 20:19
dMC-File-Selector.exe 804 Kb Aplicación 08/06/2004 20:18
dMC-Aux-Input.exe 534 Kb Aplicación 08/06/2004 20:16
dMC-AAC-Codec.exe 431 Kb Aplicación 08/06/2004 20:15
dBpowerAMP-codec-QT-mp4.exe 260 Kb Aplicación 08/06/2004 20:14
dBpowerAMP-codec-Nero-mp4.exe 251 Kb Aplicación 08/06/2004 20:13
dBpowerAMP-codec-mp4.exe 577 Kb Aplicación 08/06/2004 20:10
dBpowerAMP-codec-mp4-aacenc-alter.exe 327 Kb Aplicación 08/06/2004 20:12
dBpowerAMP-codec-mp4-aac-decode.exe 583 Kb Aplicación 08/06/2004 20:12
dBpowerAMP-codec-FAAC-mp4.exe 259 Kb Aplicación 08/06/2004 20:08
dBpowerAMP-codec-Compaact-mp4.exe 226 Kb Aplicación 08/06/2004 20:08
dBpowerAMP-codec-aactomp4.exe 347 Kb Aplicación 08/06/2004 20:07
dBpowerAMP-codec-aac-aacenc-alter.exe 327 Kb Aplicación 08/06/2004 20:06
WinDVR3[1].exe 11.695 Kb Aplicación 27/06/2004 23:55
WinDVR3.exe 11.702 Kb Aplicación 13/06/2004 01:51
VideoCharge_Install[1].exe 8.999 Kb Aplicación 04/07/2004 11:45
VideoCharge_Install.exe 8.764 Kb Aplicación 04/07/2004 11:29
vcdesy20.exe 8.421 Kb Aplicación 03/07/2004 14:16
VCDEasy_v1.1.5_Setup.exe 9.823 Kb Aplicación 10/06/2004 11:49
VCDEasy2_Setup.exe 8.421 Kb Aplicación 10/06/2004 14:38
spywebcamlighten.exe 14.447 Kb Aplicación 03/07/2004 13:31
and so on......
Old 9th October 2004, 22:57   #6  |  Link
Wilbert
This forum is about analog capping. I suggest you stick to it, and don't start about dvd ripping.
I also suggest that you only react on stuff what you don't agree with.
I think Fred said it quite nicely, but I will give some additional comments:
Yes, I know a little bit about capping. Of course, you shouldn't do any additional stuff when capping.
But, if you do additional stuff and your CPU usage is 90-100% I wish you good luck with capping using your second OS.
No. In general, people use huffyuv/mjpeg/dv for capping, and not without any reason. If, for some reason, you do want to use an "end" mpeg4 codec, you should use ffvfw and not DivX/XviD. The latter doesn't cope to well with noise and motion estimation (link can be found in the analogue capping guide).
and grass is green ..., isn't it?
Yes, I know a little bit about AviSynth. I guess you don't, otherwise you wouldn't make this remark.
I suggest you do some reading about frameserving and what AviSynth (or VDub) can do for you to enhance the quality of your encoding (hint: read the analogue cap guide), before making more of these nonsense arguments.
Yes, I try it sometimes. The latest version still can't open them.
Yes, I'm aware that VDubMod can open them.
Posting two pics is sufficient:
1) Open your cap directly in TMPGEnc (or CCE if you prefer), encode to SVCD (or DVD if you prefer), and use a max bitrate.
2) Open your cap in AviSynth (or VDub if you prefer), open your script or vdr-file in TMPGEnc/CCE and you the same encoding settings.
Now, post screenshots of a common frame.
Look, it's very simple. XVCD or KVCD is *not* VCD. VCD itself is bad quality.
We are talking about analog capping here. If you actually try to learn something about VDub or AviSynth you will notice it is actually possible to get good quality using *free* video editors. Of course, it might happen that you want something that these editors can't do.
And yes, that might be a reason to use VCD. But, it doesn't change the fact that VCD is bad quality.
Look, it's very simple. It all depends on the quality that you want and the time you (= your PC) can spend on it. If you don't mind bad quality, or you are in a hurry (and thus using hardware encoder or capping directly to ffvfw/xvid without postprocessing or whatever) resulting in bad quality. Well, I have no problem with that. That's always a trade of we will have to make.
Wilbert is offline
Old 10th October 2004, 01:29   #7  |  Link
VCD MASTER
.......that's why I'm talking about a dedicatted operative system.......
So...... who said that Pentium is a more expensive processor ????????
Obviously, you will never use a codec for a multimedia production...
...It seems to be you're one of Avs developers, just put a graphical interface and no code manipulation and I'll consider to change my opinion.....
So that's why I'm talking about Virtualdub as frameserver.
Ok, you'll see those later of this post !
Of course my horse !!! (Who is being intransigent there ?? )We are talking about analog capping here. If you actually try to learn something about VDub or AviSynth you will notice it is actually possible to get good quality using *free* video editors
Ok, ok, honey is not for donkeys.
Course, if you don't try something else.
Try MATROX USB......
It seems to be that you're time spending lovers, but, most of all, if I'm remarked for making new suggestions, take a look at yourselves...this is like an Artur's King Round Table, where no one else can become.
Old 10th October 2004, 02:06   #8  |  Link
Arachnotron
Alias fragger
Arachnotron's Avatar
Maybe the fact that two of the most experienced forum members (and one inexperienced one ) completely disagree with you should tell you something.
Do try to read some of the information available to you here on Doom9 before sticking your foot in your mouth. And just for kicks, try doing a forum search on the username "Wilbert" to get an impression of just what kind of experience backs up Wilberts statements.
Arachnotron is offline
Old 10th October 2004, 02:55   #9  |  Link
VCD MASTER
Woaaaaaaaaa, I was making my sample when this thread arrived.
Experienced????
Try my sugestions and later write about them.
Do you wanna know my stuff....ok dudes, take a look at
www.canalrcn.com
Old 10th October 2004, 13:24   #10  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Gentlemen (you should know who I mean ), a forgotten rule : Never feed the troll.
Boulder is offline
Old 11th October 2004, 13:56   #11  |  Link
VCD MASTER
Just silence, ironies...
Who remains quiet, grants....
Old 11th October 2004, 14:39   #12  |  Link
echooff
Hi Everyone
Vcd is poor quality. True, there are people who still want it, but that doesn't change the fact that vcd is poor quality. With the current low price of a recordable dvd anyone doing
is serving their customers poorly. Not trying to start a arguement of vcd vs dvd but just keep in mind, buggy whips are big sellers in certain places around the world, but I don't want one.
Live like there is no tomorrow!
Plan for your 100th birthday.
echooff is offline
Old 11th October 2004, 15:10   #13  |  Link
jggimi
Moderator Emeritus
jggimi's Avatar
I have split off the conversation started by VCD MASTER as it has nothing to do, really, with the FAQ, but everything to do with his personal opinons on what's best, and doesn't belong in the FAQ thread.
I would like to point out that Doom9's forum has Rule #12, which states:
...Do not ask "what's best" because this question cannot be answered objectively. Each and everyone has their own view about what's best in a certain area. The best is what works best for you!
Now in this particular case, VCD MASTER hasn't asked "What's best?" but instead declared his personal opinions.
The reason that section of Rule 12 exists is to limit personal opinion from causing tempers to flare, and ill will to rise.
Unfortunately, this thread has not produced any positive discussion, and continues to degenerate.
Thread closed. Anyone who opens a new thread to attempt to continue this useless conversation will be in violation of Rule 16. Questions or comments may be sent to me via PM. And VCD MASTER, please see your PM from me as well.
"It is easier for a camel to pass through the eye of a needle if it is lightly greased."
Kehlog Albran, The Profit
jggimi is offline
