Thread Tools | Display Modes |
#1 | Link |
Problems adding menu with Titlewriter to episode DVD done with DVD Shrink
So far I've been quite happy with way episode DVDs are re-authored with DVD Shrink since I could use PgcEdit easily to have the 'title'-key jump between episodes. Now that I'm returning to ripping some arc-run compilations from my original Buffy DVDs I'd like to have a small menu which depicts the episode titles so I know which eps are on a certain DVD.
What I want is actually quite simple:
The menu itself is very basic, since I do not need any language or chapter selection (I can do this during playback using my remote); it's a simple page with 4 buttons, each of which jumps to the corresponding episode: Code:
> ep 1 ep 2 ep 3 ep 4 Whenever an ep is finished, the player jumps back to the menu but it does not select the following ep as the one to be played next. The first ep is always selected no matter which ep stopped playing. You see, I'm very fond of this method cause it saves quite some time compared to having to reauthor the whole stuff, even if DVDlab saves some time already cause one does not have to demultiplex streams. I've also tried to fool around a little using PgcEdit but when I open the DVD manipulated with Titlewriter I do get an error message (pls see attached screenshot). So here are my questions:
TIA! Last edited by Chetwood; 10th September 2004 at 16:56. |
#3 | Link |
PgcEdit daemon
Try to add the menu with PgcEdit's Import Menu function: right click on the VTST 1 / TTN 1 entry in the right panel, and select "Import Menu".
Also, use the "DVDShrink Remote Buttons" macro (with all options enabled). Then post your DVD commands here: go to the menu Info -> DVD Commands, then type Ctrl-A and Ctrl-C to copy the whole text, and paste it in your reply. I will then try to explain what you want...
r0lZ PgcEdit homepage (hosted by VideoHelp) Mirror (in Belgium) Unofficial mirror (in Poland) Last edited by r0lZ; 11th September 2004 at 00:52. |
#4 | Link | |
PGC Navigator in Training
2COOL |
#5 | Link | |
thanks for stepping in
should have no influence on the proper importing of the external menu? Usually I skip those two boxes cause I don't want this behaviour, however for this attempt I checked all boxes as you said. So here's the code: Code:
DVD "M:/test"
DVD-TEXT General Name: ""
Provider ID: ""
Number of VTS: 4
VMG (VIDEO_TS.IFO)
VMG / FP-PGC
********** pre commands:
[00 A1 00 00 00 01 00 05] 1 if ( gprm(0) == 1 ".." ) then { Goto line 5 }
[00 A1 00 00 00 02 00 06] 2 if ( gprm(0) == 2 ".." ) then { Goto line 6 }
[00 A1 00 00 00 03 00 07] 3 if ( gprm(0) == 3 ".." ) then { Goto line 7 }
[30 02 00 00 00 01 00 00] 4 (JumpTT) Jump to Title 1
[30 02 00 00 00 02 00 00] 5 (JumpTT) Jump to Title 2
[30 02 00 00 00 03 00 00] 6 (JumpTT) Jump to Title 3
[30 02 00 00 00 04 00 00] 7 (JumpTT) Jump to Title 4
********** post commands:
********** cell commands:
VMGM / LU 1 (en):
VMGM / LU 1 (en) / 1 Title
[30 06 00 00 00 00 00 00] 1 (JumpSS) Jump to First Play PGC
VTS 1 (VTS_01_0.IFO)
VTSM 1 / LU 1 (en):
VTSM 1 / LU 1 (en) / 1 Title
[71 00 00 0B 00 00 00 00] 1 Set gprm(11) =(mov) 0 ".."
[71 00 00 0D 00 00 00 00] 2 Set gprm(13) =(mov) 0 ".."
[30 06 00 02 00 C0 00 00] 3 (JumpSS) Jump to VMGM PGC 2
VTSM 1 / LU 1 (en) / 2 (0:00)
[71 00 00 0C 04 00 00 00] 1 Set gprm(12) =(mov) 1024 ".."
[71 A0 0B 0C 08 00 00 05] 2 if ( gprm(11) == 5 ".." ) then { Set gprm(12) =(mov) 2048 ".." }
[71 A0 0B 0C 0C 00 00 07] 3 if ( gprm(11) == 7 ".." ) then { Set gprm(12) =(mov) 3072 ".." }
[71 A0 0B 0C 10 00 00 09] 4 if ( gprm(11) == 9 ".." ) then { Set gprm(12) =(mov) 4096 ".." }
[71 A0 0B 0C 04 00 00 0B] 5 if ( gprm(11) == 11 ".." ) then { Set gprm(12) =(mov) 1024 ".." }
[71 A0 0B 0C 00 00 00 03] 6 if ( gprm(11) == 3 ".." ) then { Set gprm(12) =(mov) 0 ".." }
[00 A1 00 0C 00 00 00 09] 7 if ( gprm(12) == 0 ".." ) then { Goto line 9 }
[46 00 00 00 00 0C 00 00] 8 (SetHL_BTN) Set Highlighted Button =(mov) gprm(12)
[71 00 00 0B 00 02 00 00] 9 Set gprm(11) =(mov) 2 ".."
[71 00 00 0F 00 02 00 00] 10 Set gprm(15) =(mov) 2 ".."
[71 00 00 0B 00 03 00 00] 12 Set gprm(11) =(mov) 3 ".."
[20 04 00 00 00 00 00 02] 13 LinkPGCN PGC 2
********** menu buttons commands:
VOB ID 1, Cell ID 1 (First NAV pack=0)
1 Group, Start button=0, Select button=0, Action button=0
button 1: [30 02 00 00 00 01 00 00] (JumpTT) Jump to Title 1
button 2: [30 02 00 00 00 02 00 00] (JumpTT) Jump to Title 2
button 3: [30 02 00 00 00 03 00 00] (JumpTT) Jump to Title 3
button 4: [30 02 00 00 00 04 00 00] (JumpTT) Jump to Title 4
VTST 1 / TTN 1 (21:34) Title 1
[71 00 00 00 00 01 00 00] 1 Set gprm(0) =(mov) 1 ".."
[51 00 00 81 00 00 00 00] 2 (SetSTN) Set Audio stream = 1
[51 00 00 00 81 00 00 00] 3 (SetSTN) Set Sub-picture stream = 1, off
[71 00 00 00 00 01 00 00] 5 Set gprm(0) =(mov) 1 ".."
[30 08 00 00 01 00 00 00] 6 (CallSS) Call the First Play PGC, resume cell 1
VTS 2 (VTS_02_0.IFO)
VTSM 2: no menu.
VTST 2 / TTN 1 (21:35) Title 1
[71 00 00 00 00 02 00 00] 1 Set gprm(0) =(mov) 2 ".."
[71 00 00 00 00 02 00 00] 5 Set gprm(0) =(mov) 2 ".."
VTS 3 (VTS_03_0.IFO)
VTSM 3: no menu.
VTST 3 / TTN 1 (21:36) Title 1
[71 00 00 00 00 03 00 00] 1 Set gprm(0) =(mov) 3 ".."
[51 00 00 00 80 00 00 00] 3 (SetSTN) Set Sub-picture stream = 0, off
[71 00 00 00 00 03 00 00] 5 Set gprm(0) =(mov) 3 ".."
VTS 4 (VTS_04_0.IFO)
VTSM 4: no menu.
VTST 4 / TTN 1 (21:36) Title 1
[71 00 00 00 00 00 00 00] 1 Set gprm(0) =(mov) 0 ".."
[30 08 00 00 01 00 00 00] 5 (CallSS) Call the First Play PGC, resume cell 1
This code results in the following behaviour: The DVD starts with no menu but with the first ep instead and I can use the title-button to jump between eps as I usually do when I rip with DVD Shrink and implement no menu. I'm looking forward to your explanations on what commands to manipulate to achieve the desired behaviour. Thanks for your time. Last edited by Chetwood; 11th September 2004 at 09:06. |
#6 | Link | |
PgcEdit daemon
Re: thanks for stepping in
However, I recommand checking the last option, because you will have a menu. Therefore, jumping back to the first title will in fact jump back to the menu. See next post...
r0lZ PgcEdit homepage (hosted by VideoHelp) Mirror (in Belgium) Unofficial mirror (in Poland) |
#7 | Link |
PgcEdit daemon
[EDIT:] The correct solution is explained here.
As I can see, your DVDLab menu is a Title menu, not a Root menu. This will not allow to use the Title menu button to skip to the next title. You should however enable this function when applying 'DVDShrink Remote Buttons', if you want to use option 1 of point 3 explained below. Important: You should import the Title menu in the VMGM, not in the VTS 1 (this will replace the title menu PGC created by 'DVDShrink Remote Buttons' function). Here is what you should have as the starting point (changes are highlighted in bold): Code:
VMG (VIDEO_TS.IFO)
VMG / FP-PGC
VMGM / LU 1 (en):
VMGM / LU 1 (en) / 2 (0:00)
VTSM 1: no menu.
VTSM 2: no menu.
VTSM 3: no menu.
VTSM 4: no menu.
If you selected the last checkbox in the DVDShrink Remote Buttons dialog, you will also return to the menu when the last title has finished playing. At this point, the menu should play when you start the DVD, and you will be able to jump to the menu with the Title button of the remote. [*] To be able to use also the Root Menu button on the remote, you must add root menus entries for each VTS: Right-click on the 'VTST 1 / TTN 1 (21:34) Title 1' entry, and select 'New Menu'. A new Root menu will be created and automatically selected. Do the same operations for Titles 2, 3 and 4. (Highlighted in blue) [*] At this point, you have 2 options. 1) The default pre-command of the Root menus you have just created are jumps to the FP-PGC. This means that, when using the Root Menu button, you will jump to the next title (except when in Title 4, which will return to the Title menu, because of the modification done at point 1). This is what you wanted to do with the Title menu button. Note that this works only if you selected the 'Always allow the "Title Menu" button to jump to the next title' option in 'DVDShrink Remote Buttons'. 2) If you want to go to the menu whenever you use the Root menu (regardless of the title you are in), then change the '(JumpSS) Jump to First Play PGC' in each Root menu by: Code:
[30 06 00 00 00 42 00 00] 1 (JumpSS) Jump to VMGM Title menu [*] The DVDShrink behavior is to play the next title when the current title has finished playing. If you want to return to the menu instead, you have to change the Title's post commands also. Change the '(CallSS) Call the First Play PGC, resume cell 1' by '(CallSS) Call the VMGM Title menu, resume cell 1' (highlighted in pink) [*] You want to automatically highlight the button that lead to the next title when you return to the menu. See the commands in the 'VMGM / LU 1 (en) / 2 (0:00)' PGC: The trick used by DVDLab is to use the GPRM 11 to store a value that is compared to know what button must be highlighted. The button number is then set in the GPRM 12. Remember that the value for a button is actually the button number * 1024. Then, the GPRM 12 is transferred in the SPRM 8 (highlighted button number), before displaying the menu. As you can see, line 1 initialize the GPRM 12 to 1024 (button 1). This is the default button. Line 2 highlight button 2 if GPRM 11 == 5, line 3 highlight button 3 if GPRM 11 == 7, line 4 highlight button 4 if GPRM 11 == 9, and Line 5 highlight button 1 again if GPRM 11 == 11. (Line 6 set GPRM 12 to 0 if GPRM 11 == 3. This is used to avoid changing the current highlighted button.) The problem is that DVDShrink do not initialize the GPRM 11. So we must do that manually. Add a Set GPRM 11 command as the verry first pre-command of each Title. The GPRM 11 must be initialized respectively with values 5, 7, 9 and 11 (highlighted in green).[/list=1] Code:
VMG (VIDEO_TS.IFO)
VMG / FP-PGC
[30 06 00 00 00 42 00 00] 4 (JumpSS) Jump to VMGM Title menu
VMGM / LU 1 (en):
VTSM 1 / LU 1 (en):
VTSM 1 / LU 1 (en) / 1 (dummy) Root - Chapters: n/a, Programs: 0, Cells: 0
[71 00 00 0B 00 05 00 00] 1 Set gprm(11) =(mov) 5 ".."
[71 00 00 00 00 01 00 00] 2 Set gprm(0) =(mov) 1 ".."
[51 00 00 81 00 00 00 00] 3 (SetSTN) Set Audio stream = 1
[51 00 00 00 81 00 00 00] 4 (SetSTN) Set Sub-picture stream = 1, off
[30 08 00 00 01 42 00 00] 2 (CallSS) Call the VMGM Title menu, resume cell 1
VTSM 2 / LU 1 (en):
VTSM 2 / LU 1 (en) / 1 (dummy) Root - Chapters: n/a, Programs: 0, Cells: 0
[71 00 00 0B 00 07 00 00] 1 Set gprm(11) =(mov) 7 ".."
[71 00 00 00 00 02 00 00] 2 Set gprm(0) =(mov) 2 ".."
VTSM 3 / LU 1 (en):
VTSM 3 / LU 1 (en) / 1 (dummy) Root - Chapters: n/a, Programs: 0, Cells: 0
[71 00 00 0B 00 09 00 00] 1 Set gprm(11) =(mov) 9 ".."
[71 00 00 00 00 03 00 00] 2 Set gprm(0) =(mov) 3 ".."
[51 00 00 00 80 00 00 00] 4 (SetSTN) Set Sub-picture stream = 0, off
VTSM 4 / LU 1 (en):
VTSM 4 / LU 1 (en) / 1 (dummy) Root - Chapters: n/a, Programs: 0, Cells: 0
[71 00 00 0B 00 0B 00 00] 1 Set gprm(11) =(mov) 11 ".."
[71 00 00 00 00 00 00 00] 2 Set gprm(0) =(mov) 0 ".."
Good luck!
r0lZ PgcEdit homepage (hosted by VideoHelp) Mirror (in Belgium) Unofficial mirror (in Poland) Last edited by r0lZ; 12th September 2004 at 12:58. |
#8 | Link | |||
not unexpected
I'm not quite sure in which order to manipulate the files. I've kept backups of my original ifos so I can start from scratch anytime I want. So am I right when I first use the DVD Shrink macro (regardless of what item is selected in the left window of PgcEdit) and only then import my menu template in the VMGM? Cause if I'd do it the other way round the DVD Shrink macro would replace the newly created menu which would leave me with the title-button navigation scheme but no menu. In short this is what I did:
Now when I watch this DVD before trying any other manipulations (like root menu) I get these results:
BUT (contrary to the results from using Titlewriter) I do not have ANY highlighted buttons in the menu! I can still select the episodes cause whenever I move the mouse over an area the button usually would show up the cursor changes to a hand so I know that there's a button, I just don't see it. As such it's pointless to try the other manipulations which would usually result in the following ep's button being selected in the menu . For the moment I ignored the problem and tried to add new menus to each VTS to make the remote's 'menu' button make me return to the menu regardless which ep was currently playing. This worked as well. My next problem however is that now 2 buttons (menu and title) return to the menu and I want them to act differently. IMO 2Cool's idea of using the tile-button to jump between eps is still the intutive way to go so I've made up my mind concerning the navigation on my reauthored DVDs:
#9 | Link | ||||
PgcEdit daemon
I have also found one problem in the logic: the Title menu actually reset the GPRM 11 to 0 before calling the PGC 2, which is the real menu. This is not what we want, so remove the first pre-command: Code:
[71 00 00 0D 00 00 00 00] 1 Set gprm(13) =(mov) 0 ".."
[30 06 00 02 00 C0 00 00] 2 (JumpSS) Jump to VMGM PGC 2
I don't have the time now, but I will explain later how to import your menu as a Root menu, keeping the ability to call the next title with the Title button. Quote:
#10 | Link | |
PgcEdit daemon
I've found in my PMs the warning message you tried to attach in the first post of the thread. The message is:
I think it is best to know when such errors are detected by PgcEdit, hence the warning. But most players doesn't use that value.
#11 | Link | |||
So when I jump to another ep with the title key I can always jump to the beginning of the previous ep (rather than it's last chapter) and so effectively move back and forth between eps even if they are in different titlesets which is very convenient. Curiuosly enough this does not work with PowerDVD 5 on my PC nor a Daytek DVD 708 but it does with 2 standalones I've tried so far. In the meantime I'm gonna do my 4 ep template again, this time using a Root Menu. That is as soon as I find out the difference between Root Menu and Title Menu. Where can I read more about that? The problem for is that when I do not use different VTS in DVDlab Pro but put all 4 movies under VTS 1 I end up with all 4 eps put into Vts_01_1.vob and so I cannot import this menu in my DVD Shrink rip since this one comes with Vts_01_1.vob - Vts_04_1.vob. Last edited by Chetwood; 12th September 2004 at 11:44. |
#12 | Link | |
Re: not unexpected
I thought Dimad would tried to implement it but I guess he forgot about it. Maybe rolZ could try it out since he can parse the buttons info in the navpacks. EDIT: I think using this commands will work. http://www.dvd-replica.com/DVD/sethlbtn.php?p=10 http://www.dvd-replica.com/DVD/sethlbtn.php?p=30
2COOL Last edited by 2COOL; 12th September 2004 at 09:52. |
#13 | Link |
PgcEdit daemon
Correct solution
OK. This time, I think I have the solution.
First, begin by applying the "DVDShrink Remote Buttons" macro. The only option that must be checked is "Always allow the 'Title Menu' button to skip to the next title". The rest is up to you. However, I recommand also the "At the end of the last title, automatically loop back to the first title" option. After the changes explained below, this will display the menu, with the first episode button selected. Then, import your menu as the VMGM menu (highlighted in bold). This will replace the menu created by the DVDShrink macro, but we will create it again in step 1 below. This is what you should have: Code:
VMG (VIDEO_TS.IFO)
VMG / First-Play PGC
VMGM / LU 1 (en):
VTSM 1: no menu.
VTST 1 / TTN 1 (6:41) Title 1 - Chapters: 2, Programs: 2, Cells: 2
[30 08 00 00 01 00 00 00] 2 (CallSS) Call the First Play PGC, resume cell 1
VTSM 2: no menu.
VTST 2 / TTN 1 (6:41) Title 2 - Chapters: 2, Programs: 2, Cells: 2
VTSM 3: no menu.
VTST 3 / TTN 1 (8:00) Title 3 - Chapters: 2, Programs: 2, Cells: 3
VTSM 4: no menu.
VTST 4 / TTN 1 (0:04) Title 4 - Chapters: 1, Programs: 1, Cells: 1
[30 08 00 00 01 00 00 00] 1 (CallSS) Call the First Play PGC, resume cell 1 ### or Exit
Right-click on any PGC in the VMGM domain, and select "New PGC". A new PGC is created. Right click on the new PGC (PGC 3), and select the "Set Menu Type" function, and choose "Title menu". Then, double-click on the pre command of this new PGC, and change it to Code:
[30 06 00 00 00 00 00 00] 1 (JumpSS) Jump to First Play PGC (Hint: copy the hex bytes above between (but not including) the [ and ] characters, and paste replace them in PgcEdit.) [*] We need also the Root menus for all titles: Right click on the Title 1 entry, and select "New Menu". Then, change the default command to Code:
[30 06 00 02 00 C0 00 00] 1 (JumpSS) Jump to VMGM PGC 2 Repeat this point for Titles 2, 3 and 4. The root menus are now calling the PGC 2 of the VMGM menu, which is the real menu, with the buttons. So, calling the Root Menu when playing an episode will actually display your menu. [*] We need to add the commands to automatically select the button that jumps to the next ep: Select Title 1, and add a pre-command 1. Change the NOP with Code:
[71 00 00 0B 00 05 00 00] 1 Set gprm(11) =(mov) 5 ".." Repeat this step for title 2, 3 and 4, but with the values 7, 9 and 11 respectively: Code:
[71 00 00 0B 00 07 00 00] 1 Set gprm(11) =(mov) 7 ".." [71 00 00 0B 00 09 00 00] 1 Set gprm(11) =(mov) 9 ".." [71 00 00 0B 00 0B 00 00] 1 Set gprm(11) =(mov) 11 ".." Code:
[30 06 00 02 00 C0 00 00] 4 (JumpSS) Jump to VMGM PGC 2 Code:
[30 08 00 02 01 C0 00 00] 2 (CallSS) Call the VMGM PGC 2, resume cell 1 Code:
VMG (VIDEO_TS.IFO)
VMGM / LU 1 (en):
VMGM / LU 1 (en) / 1 (dummy) - Chapters: n/a, Programs: 0, Cells: 0
VMGM / LU 1 (en) / 2 (0:00) 4b. - Chapters: n/a, Programs: 1, Cells: 1
[71 00 00 0B 00 03 00 00] 1 Set gprm(11) =(mov) 3 ".."
[20 04 00 00 00 00 00 02] 2 LinkPGCN PGC 2
VMGM / LU 1 (en) / 3 (dummy) (Title) - Chapters: n/a, Programs: 0, Cells: 0
VTSM 1 / LU 1 (en):
VTSM 2 / LU 1 (en):
VTSM 3 / LU 1 (en):
VTSM 4 / LU 1 (en):
[30 08 00 02 01 C0 00 00] 1 (CallSS) Call the VMGM PGC 2, resume cell 1 ### or Exit
r0lZ PgcEdit homepage (hosted by VideoHelp) Mirror (in Belgium) Unofficial mirror (in Poland) Last edited by r0lZ; 12th September 2004 at 13:07. |
#14 | Link | |||
PgcEdit daemon
@2COOL
In the thread you mentionned above, you wrote: Quote:
As far as I know, selecting the button with a SetHL_BTN command in the IFOs will not work if the "force selection button number" is not 0. 0 means "do not change the highlighted button", not "no highlighting". Also, the Dimad reply was: Quote:
As you said, he forgot about it. Quote:
However, note that changing the "force selection button number" in the first nav pack of your menu (using VOBEdit) seems to work also for animated menus. This is why I added the First NAV Pack information in PgcEdit.
r0lZ PgcEdit homepage (hosted by VideoHelp) Mirror (in Belgium) Unofficial mirror (in Poland) Last edited by r0lZ; 12th September 2004 at 13:47. |
#15 | Link |
PgcEdit daemon
About the menu buttons not visibles on some players: you found a bug in PgcEdit 0.3.3 (and below)!
I am working to fix it. Anyway, you can fix the problem with IfoEdit: Load VIDEO_TS.IFO in IfoEdit, then click on the VMGM_MAT section. At the end of the section (offset [00000155]), change the Number of Sub-picture streams in VMGM from 0 to 1. Save. That's all! [EDIT:] Bug found and fixed. The new version will be available soon.
r0lZ PgcEdit homepage (hosted by VideoHelp) Mirror (in Belgium) Unofficial mirror (in Poland) Last edited by r0lZ; 12th September 2004 at 16:03. |
#16 | Link | |
You ROCK!
Do you think it's possible to add these few steps as a macro similar to the one you did with the DVD Shrink remote buttons, i.e. also offering several checkboxes one can choose from? As well, I'd need one menu with only 3 eps (due to 5.1 sound and longer eps). Would PgcEdit automatically adjust the imported menu or would I have to change some lines, e.g. delete Code:
#17 | Link | ||
PgcEdit daemon
Re: You ROCK!
Hint: keep a backup of all your menus. You will soon have a collection usable in many cases. However, you may use the 4 eps menu for a 3 eps DVD. The only thing important to do is to disable the button 4 with MenuEdit or DVDRemake (or VOBEdit: difficult but free).
r0lZ PgcEdit homepage (hosted by VideoHelp) Mirror (in Belgium) Unofficial mirror (in Poland) Last edited by r0lZ; 12th September 2004 at 19:32. |
#18 | Link | ||
some more questions
How about mentioning the one that comes with Titlewriter 1.64, it's done in Shockwave similar to those at DVDshrink.info. I'd like to contribute somehow but as you've seen with my menu my design skills suck big time (granted, it was only a rushed test but crappy nonetheless).Anyway, I'd like to know if there's any important difference between using a Root menu and a titleset menu. Quote:
#19 | Link | |||
PgcEdit daemon
The Root menus are called with the Menu button, and are local to the titleset. You may only jump (directly) to the TTNs in the same titleset. The trick described above is to use the Root menu to actually jump to PGC 2 of the Title menu, which in turn jump to the 4 eps, via the button commands. Using a Title menu to jump to titles on multiple titlesets is the good way to go. However, you wanted also the Title button to skip to the next title, hence the difficulties... Quote:
#20 | Link | ||
some minor glitches
I've found two minor glitches so far:
| Thread Tools | |
| Display Modes | |
