20th June 2004, 06:35 | #1 | Link |
Request for Version()
Would it be possible to modify the Version() command so that if a video is loaded already, it simply prints the version string on screen?
If no video is loaded, function as it does now. Alternatively, the version could be displayed in the Info() display. Also, could Version() be fixed so it does not generate an error in WMP9? |
20th June 2004, 07:46 | #2 | Link |
AviSynth Enthusiast
If you really want, you can use Subtitle(VersionString()).
Also, although it would be possible to modify Version to accept the following: Code:
AVISource("foo.avi") Version(last) Code:
AVISource("foo.avi") Version() Last edited by stickboy; 20th June 2004 at 08:03. |
20th June 2004, 15:19 | #3 | Link | |
Avisynth 3.0 Developer
if Subtitle(VersionString()) works, then it should be made as such.
There is no point in modifying filters when a trivial line of code performs as well. Quote:
I doubt the parser is smart enought to make the distinction. |
20th June 2004, 19:54 | #5 | Link | ||
AviSynth Enthusiast
function Foo(clip "c") { return Default(c, MessageString("bye")) } MessageString("hi") Foo() You also can see this behavior with BlankClip, which I think is the only internal function that takes an optional clip as its first argument. Quote:
20th June 2004, 20:50 | #7 | Link |
AviSynth Enthusiast
Either implicitly:
AVISource("foo.avi") # since the resulting clip was not assigned to a variable, # AviSynth automatically assigned it to the variable <last> Subtitle(VersionString()) Code:
c = AVISource("foo.avi") # since the resulting clip *was* assigned to a variable, # <last> is unassigned at this point last = c Subtitle(VersionString()) Code:
c = AVISource("foo.avi") c.Subtitle(VersionString()) # alternatively: Subtitle(c, VersionString()) Last edited by stickboy; 20th June 2004 at 20:57. |
