#1 | Link |
Changing Embedded XVID aspect ratio?
Is there any utility to change xvid embedded aspect ratio? I've come across some video files that seems to have wrong aspect ratio in xvid encoded video and i don't seem to find any utility to fix it to correct one. I'm using XBOX Media Center that's based on mplayer. I have couple of files that are 640x480 resolution but show as 1.21 but are really 1.33 but for now i haven't found anyway to patch or remove aspect flags from avi file without re-encoding video.
#2 | Link |
AFAIK there is no such software yet. It should be possible but no one has written it. I am also looking for it as well.
Opensource will not take over the world. But it will sure improve the lives of most of it! _______________________________________________ Inkscape - Scallable Vector Graphics for everyone. The GIMP - Free raster graphics and photo editing software. Planeshift - Free 3D MMORPG. Cause everyone needs some fun. |
#3 | Link |
Im also searching for that.
I tried to write a simple patching utility some time ago but it was more complicated than i thought, the values and the position where they are stored seem to change if you use different options in xvid. And i have absolutely no idea how to really read the avi file structure. ![]() |
#5 | Link | |
yakisoooobaaa!!
But what the application should do is change the AR in the MPEG4 bitstream, not in the particular container header (although that would make a nice addition) |
#6 | Link |
I am almost finished with a program that will change the aspect ratio in XviD AVIs. It was not a simple task, unfortunately. I hope to have it done and released within a few days, assuming no unforeseen problems.
#7 | Link | |
Life's clearer in 4K UHD
Will it be an XviD only application. And will the signalling work when the AVI stream is muxed into an MP4 container? I can test MP4's in hardware if you like? Cheers
#8 | Link | |
#9 | Link | |
#10 | Link | |
#11 | Link |
The video must be in an AVI container, and OpenDML is not supported (maybe an AVI could be split into <1 gig pieces with VirtualDub, run the tool on each piece, and rejoin them). It should work on other MPEG-4 video streams inside AVI.
EDIT: Yes, it changes the aspect ratio stored in the MPEG-4 stream, not in any AVI headers. |
#12 | Link | |
#13 | Link | ||
![]() Quote:
![]() its license free (meaning its totally legal to spread tools with .mp4 support) and opensource libraries are available from mpeg4ip and gpac ![]()
#14 | Link |
I have it working now, I will release a preview. It is written in C#, so you will need the .NET v1.1 Framework to run it (available at WindowsUpdate). It is command-line for now but I am most likely going to make it a GUI app.
Usage: rp <src_path> <dest_path> <ar_info> <ar_info> must be: 1 (Square Pixels) 2 (4:3 PAL Pixel Shape (12:11)) 3 (4:3 NTSC Pixel Shape (10:11)) 4 (16:9 PAL Pixel Shape (16:11)) 5 (16:9 NTSC Pixel Shape (40:33)) par:<par_width>:<par_height> (Pixel Aspect Ratio) dar:<frame_width>:<frame_height>:<dar_width>:<dar_height> (Display Aspect Ratio) Examples: rp c:\play.avi c:\play-new.avi 1 rp c:\play.avi c:\play-new.avi par:10:11 rp c:\play.avi c:\play-new.avi dar:640:480:16:9 EDIT: I will release the source code once I finish up a bit more. EDIT2: Download link removed. See this thread for the new version. Last edited by Moitah; 14th June 2004 at 21:37. |
#15 | Link |
ok i now tested the par option with a 3ivx, xvid and divx5 stream and it seems to work great
![]() i tested the resize by remuxing from .avi to .mp4 i noticed that the display of the old ar stored is repeated various times. i assume thats because the value gets changed on every keyframe, right? also its maybe important to mention that the options 2-5 will only work with DVD input, with SVCD input you will have to use other values if i understood it right. xvid currently doesnt offer these values, but the 3ivx encoder does (if you want to find out which values these are) also i noticed that by using .net the download increases from 5KB to 25MB :/ and .net tools will also not work on non windows systems if i understood it right, maybe it would have been better to write a commandline tool in a way its platform independant, but well i am no dev, i cant really say much about this... thanks for this tool! ![]() ps: what does "RP" stand for?
Between the weak and the strong one it is the freedom which oppresses and the law that liberates (Jean Jacques Rousseau) I know, that I know nothing (Socrates) MPEG-4 ASP FAQ | AVC/H.264 FAQ | AAC FAQ | MP4 FAQ | MP4Menu stores DVD Menus in MP4 (guide) Ogg Theora | Ogg Vorbis use WM9 today and get Micro$oft controlling the A/V market tomorrow for free Last edited by bond; 6th June 2004 at 12:41. |
#17 | Link |
I'm crap with 'non GUI' tools and can't make it work!
I would like to test an AVI to MP4 muxed stream (without B-VOP's) to see if they work in hardware ![]() Can anybody post one please? Cheers
#18 | Link | |
yakisoooobaaa!!
Moitah,
very nice to see this idea realised ![]() Quote:
Best of luck ; ) |
#19 | Link | |||
![]() Quote:
#20 | Link |
Don't mean to add stones to burden, but would it be possible to add custom resolutions?
(I'm currently wrangling '2001: A Space Odyssey', which has an AR of 2.21:1)
I love CLI up to a point ... which is usually located somewhere below thirty character lines. |
