Go Back   Doom9's Forum > Video Encoding > (Auto) Gordian Knot
Old 9th May 2004, 21:50   #1  |  Link
outlaw_nl
outlaw_nl's Avatar
EXCEPTION: Range check error
does anyone have any idea what this error means?
[9-5-2004 12:08:50] Input dir: E:\031127_2138\VIDEO_TS
[9-5-2004 12:08:50] Output file: E:\Kill.Bill.DVD.Xvid.avi
[9-5-2004 12:08:50] Audio: English
[9-5-2004 12:08:50] Subtitles: English
[9-5-2004 12:08:50] Codec: XviD
[9-5-2004 12:08:50] Target size: 700Mb
[9-5-2004 12:08:50] Custom audio settings: VBR MP3 with average bitrate: 128Kbps
[9-5-2004 12:08:50] Started encoding.
[9-5-2004 12:08:50] Demuxing and indexing.
[9-5-2004 12:15:40] Analyzing source.
[9-5-2004 12:40:26] Source is considered to be progressive.
[9-5-2004 12:40:28] Found 189741 frames
[9-5-2004 12:40:28] Encoding audio.
[9-5-2004 13:32:13] Indexing subtitles.
[9-5-2004 13:35:37] Compressing subtitles.
[9-5-2004 13:35:41] Audio size: 87,412,256 bytes (83.36 Mb)
[9-5-2004 13:35:41] Overhead: 7,589,632 bytes (7.24 Mb)
[9-5-2004 13:35:41] Subtitles size: 276,565 bytes (0.26 Mb)
[9-5-2004 13:35:41] Video size: 638,724,747 bytes (609.14 Mb)
[9-5-2004 13:35:41] Running compressibility test.
[9-5-2004 13:35:41] Job finished.
this happens after I decrypted with latest DVDDecrypter v3.2.2.0. Its a slow pc but I cant believe thats the problem?
outlaw_nl is offline   Reply With Quote
Old 10th May 2004, 07:08   #2  |  Link
outlaw_nl
outlaw_nl's Avatar
this is the last part of the created .log file, any help?
LoadPlugin("C:\PROGRA~1\AutoGK\filters\mpeg2dec3dg.dll")
LoadPlugin("C:\PROGRA~1\AutoGK\filters\autocrop.dll")
LoadPlugin("C:\PROGRA~1\AutoGK\filters\undot.dll")
function getOrder(clip c) {
order = GetParity(c) ? 1 : 0
return order }
movie = mpeg2source("E:\gk_tmp\Kill.Bill.DVD.Xvid.d2v")
cropclip = autocrop(movie,mode=0,wmultof=4,hmultof=4,samples=10,aspect=0,threshold=35)
c_width = width(cropclip)
c_height = round(height(cropclip) / 0.911392405063291)
input_par = float(c_width)/float(c_height)
fixed_aspect = input_par > 1.4 ? 0.911392405063291 : 0.888888888888889
c_height = round(height(cropclip) / fixed_aspect)
out_width = 640
out_height = round(float(out_width) / input_par)
hmod = out_height - (floor(out_height / 16 ) * 16)
out_height = (hmod > 4) ? (out_height + (16 - hmod)) : (out_height - hmod)
new_aspect = (float(out_width) / float(out_height)) / fixed_aspect
autocrop(movie,mode=0,wmultof=4,hmultof=4,samples=10,aspect=new_aspect,threshold=35)
Undot()
LanczosResize(out_width,out_height)
SelectRangeEvery(300,15)
[9-5-2004 23:46:36] Job finished.
Old 10th May 2004, 17:22   #3  |  Link
therealjoeblow
See my post about this and how I fixed it at:
http://forum.doom9.org/showthread.ph...&pagenumber=99
It's something to do with a codec that lost it's settings, follow my uninstall/reinstall procedure, that cured it for me.
Cheers,
The REAL Joe
therealjoeblow is offline   Reply With Quote
Old 12th May 2004, 17:21   #4  |  Link
outlaw_nl
outlaw_nl's Avatar
fixed, thanks :)
thanks, reinstalling everything fixed that one
however now i have another one :P
Crash reason: Access Violation
Crash context:
An out-of-bounds memory access (access violation) occurred in module 'ntdll'.
shit
Old 13th May 2004, 02:32   #5  |  Link
ookzDVD
DVD Rebuilder!
ookzDVD's Avatar
Hmmm.... it seems the EXCEPTION RANGE CHECK ERROR is still a mystery.
Noone can surely solve this problem without reinstalling the apps.
@lenox,
Is that possible the the plugins which in the default avisynth directory override the LoadPlugin() in your .avs ?
Thank you.
PS. I have the same exception problem too.
I'm not sure which one can make this thing happen seen I've been installing DVD2SVCD package, and install the 1.21 update.
I've tried back to the latest version which work fine with me
but still got the error. I can load the _comptest.avs in the VirDubMod
with no problem/error.
Stranges... hmmm
Thank you.
ookzDVD is offline   Reply With Quote
Old 10th July 2009, 22:19   #6  |  Link
Exodus43
I need help with this. I am running windows 7, which basically is a mix of xp and vista, so if anyone solved this for vista, please help. I tried unistalling/reinstalling like the post mentioned about, and it didnt solve anything.
Any ideas?
Exodus43 is offline   Reply With Quote
